What apt package contains nvidia-suspend.service etc?
I just switched from using the Ubuntu PPA for installing Nvidia-related packages to using the Nvidia one.
The nvidia-kernel-common package provided by Ubuntu contains /lib/systemd/system/nvidia-suspend.service but the Nvidia one does not.
Which of the packages directly provided by Nvidia do I need in order to install nvidia-suspend.service and the other files needed to successfully suspend and resume?
For example, the Nvidia provided nvidia-kernel-common-515 package contains just:
lib/firmware/nvidia/515.65.07/gsp.bin
lib/modprobe.d/nvidia-graphics-drivers.conf
lib/udev/rules.d/71-nvidia.rules
sbin/ub-device-create
usr/share/doc/nvidia-kernel-common-515/changelog.Debian.gz
usr/share/doc/nvidia-kernel-common-515/copyright
usr/share/initramfs-tools/hooks/framebuffer-nvidia
Whereas the identically named package provided by Ubuntu contains:
  lib/firmware/nvidia/515.65.01/gsp.bin
* lib/systemd/system/nvidia-hibernate.service
* lib/systemd/system/nvidia-resume.service
* lib/systemd/system/nvidia-suspend.service
* lib/systemd/system-sleep/nvidia
* usr/bin/nvidia-powerd
* usr/bin/nvidia-sleep.sh
* usr/share/doc/nvidia-kernel-common-515/nvidia-powerd.service
I’ve marked the additional files with *.
If I look at the README, installed in /usr/share/doc/nvidia-driver-515, in the power management systemd section that covers nvidia-resume.service etc, it just says:
These files are installed and enabled by nvidia-installer automatically if
systemd is detected. Installation of systemd units can be disabled by
specifying the '--no-systemd' installer option.
I.e. the README doesn’t seem to cover the case where people are installing things via a package manager.
I don’t know, but you could try to help yourself with apt-file. i.e.:
apt-file search nvidia-suspend.service
Which will show you the package name(s) containing the file.
I’d tried apt-file but it only shows hits for nvidia-suspend.service for packages provided via Ubuntu rather than Nvidia.
I brute-forced things by downloading (but not installing) the .deb files for the latest version of every package provided by:
https://developer.download.nvidia.com/compute/cuda/repos/ubuntu2004/x86_64/
I then unpacked the downloaded .deb files and looked at the files each provides, I found various .service files (e.g. I could see that nvidia-powerd.service is provided by the nvidia-compute-utils package) but none contained nvidia-suspend.service.
I wonder if this is a bug or some issue with how Nvidia are packaging up the latest version of the driver etc.
A bit late to the party but at least for future reference to anyone else, the .service files are at time of writing within a tar (if I’m not mistaken) that’s embedded in nvidia’s installation shell script (e.g. https://us.download.nvidia.com/XFree86/Linux-x86_64/565.77/NVIDIA-Linux-x86_64-565.77.run).
If for example you download the above file, make it executable and run it with the -x|--extract option, you could then find the .service’s in ./NVIDIA-Linux-x86_64-565.77/systemd/system/.
