What is CUVID raw YUV input?
This post concerns NVDEC, the decoder library inside the Nvidia Video Codec SDK.
To map frames that have been demuxed, cuvidMapVideoFrame is provided.
Lines 1109-1116 from cuviddec.h as part of Nvidia Video Codec SDK 12.1.14:
//! \fn CUresult CUDAAPI cuvidMapVideoFrame64(CUvideodecoder hDecoder, int nPicIdx, unsigned long long *pDevPtr,
//!                                           unsigned int * pPitch, CUVIDPROCPARAMS *pVPP);
//! Post-process and map video frame corresponding to nPicIdx for use in cuda. Returns cuda device pointer and associated
//! pitch of the video frame
extern CUresult CUDAAPI cuvidMapVideoFrame64(CUvideodecoder hDecoder, int nPicIdx, unsigned long long *pDevPtr,
                                             unsigned int *pPitch, CUVIDPROCPARAMS *pVPP);
As the docs note, this lets you access a CUdeviceptr which contains your decoded memory. Part of this operation is supplying to the decoder a CUVIDPROCPARAMS struct, which contains information about how to interpret the video output.
Lines 940-964 from cuviddec.h as part of Nvidia Video Codec SDK 12.1.14:
//! \struct CUVIDPROCPARAMS
//! Picture parameters for postprocessing
//! This structure is used in cuvidMapVideoFrame API
typedef struct _CUVIDPROCPARAMS
    int progressive_frame;                        /**< IN: Input is progressive (deinterlace_mode will be ignored)                */
    int second_field;                             /**< IN: Output the second field (ignored if deinterlace mode is Weave)         */
    int top_field_first;                          /**< IN: Input frame is top field first (1st field is top, 2nd field is bottom) */
    int unpaired_field;                           /**< IN: Input only contains one field (2nd field is invalid)                   */
    // The fields below are used for raw YUV input
    unsigned int reserved_flags;                  /**< Reserved for future use (set to zero)                                      */
    unsigned int reserved_zero;                   /**< Reserved (set to zero)                                                     */
    unsigned long long raw_input_dptr;            /**< IN: Input CUdeviceptr for raw YUV extensions                               */
    unsigned int raw_input_pitch;                 /**< IN: pitch in bytes of raw YUV input (should be aligned appropriately)      */
    unsigned int raw_input_format;                /**< IN: Input YUV format (cudaVideoCodec_enum)                                 */
    unsigned long long raw_output_dptr;           /**< IN: Output CUdeviceptr for raw YUV extensions                              */
    unsigned int raw_output_pitch;                /**< IN: pitch in bytes of raw YUV output (should be aligned appropriately)     */
    unsigned int Reserved1;                       /**< Reserved for future use (set to zero)                                      */
    CUstream output_stream;                       /**< IN: stream object used by cuvidMapVideoFrame                               */
    unsigned int Reserved[46];                    /**< Reserved for future use (set to zero)                                      */
    unsigned long long *histogram_dptr;           /**< OUT: Output CUdeviceptr for histogram extensions                           */
    void *Reserved2[1];                           /**< Reserved for future use (set to zero)                                      */
} CUVIDPROCPARAMS;
Included in this struct are a selection of fields to be used with “raw YUV input”. What is this? The sample code pretends they don’t exisit. The docs do not acknowledge them either. I am unable to find any examples or even reference to these fields online.
To clarify, this refers to the API Programmers Guide distrubuted with the SDK. If there are other pieces of documentation that relate to the Video Codec SDK, please let me know!
