hello 541449841,
could you please also share the data-rate of your total 16-camera streams.
as you can see here… Topic 258111, CPHY has validate up-to 3.0 Gsps.
that’s also mentioned in the [Release Notes (r35.4.1) ]
2.3. Camera
- Issue 4175410
- There is a limitation on the C-PHY-supported data rate. C-PHY has been tested to work up to 3.0Gsps per trio, so there might be stream failures if data rate goes higher than 3.0Gsps.
BTW,
may I know which Jetpack release you’re using?
could you please moving to the latest release, i.e. JetPack 5.1.2 for verification.
thanks
