What is the default Shared Memory size per block in GTX 480 ?
Hi.
I want to know what is the default configured shared memory size per block in GeForce GTX 480…
Also, how can i verify this by code (e.g. by making a function call)?
By default, GTX480 along with all compute capability 2.x devices have 48KB of shared memory per SM and 16KB of L1 cache.
You can check this with cudaGetDeviceProperties() and checking cudaDeviceProp::sharedMemPerBlock.
Are you sure that the devices have 48KB per SM by default? Or just 48KB is the maximum size? I have read somewhere in that forum that the devices uses only 16KB of Shared Memory and if i want to switch to 48KB i need to call cudaFuncSetCacheConfig() with cudaFuncCachePreferShared argument… Is this true?
Is this somewhere stated formally by Nvidia?
How can i use cudaDeviceProp::sharedMemPerBlock to read the current values / sizes?
If you compile for sm_2x, the default is 48Kb of shared memory, 16Kb of L1 cache. You can change the setting with cudaFuncSetCacheConfig.
See page 145 of the CUDA C Programming Guide.
Great! Thank you mfatica.
One more thing. I compile my programs with nvcc without using any sm_xx architecture statement. What is the default architecture for my case? Does the defaults above apply to my case?
Also, Gilles_C, please give me a code example of how to use cudaDeviceProp::sharedMemPerBlock to read the current values / sizes if you can (because i programming in C)…
Default compute capability is 1.0 regardless of the machine you are compiling on.
Here you are:
int dev = 0; // to be adjusted or queried according to your needs
    cudaDeviceProp props;
    cudaGetDeviceProperties(&props, dev);
    printf("Amount of shared memory per block is %d bytes\n", props.sharedMemPerBlock);
That’s ok! Thank you very much, all!
