Ayo, community and fellow developers. I have some questions. Sorry if I sound ridiculous, because I’m almost going crazy.
When I wanted to use CUDA, I was faced with two choices, CUDA Toolkit or NVHPC SDK. Here I use Ubuntu 22 x86_64 with nvidia-driver-545. In my opinion, the HPC SDK is more complete than the CUDA toolkit. They both have nvc, nvcc, and nvc++, but NVHPC has more features that I need such as cuFFT, cuTENSOR, cuSPARSE and cuBLAS. Too bad it doesn’t have cuDNN in it.
- Or, is there one, but I don’t know?
It looks like if I install cuda-toolkit-12-4
along with nvidia-cudnn
, they will be compatible. It’s just that HPC SDK may not be the same as cuda-toolkit.
- Or, is it possible that
cuda-toolkit
also has the same thing as HPC SDK? I do not think so. - I have wasted a lot of time, just trying to figure out what to choose by installing and uninstalling packages via the shell.
After installing nvhpc-24-3
, I couldn’t directly test the HPC Compilers. I had to run several commands in the shell first, as explained in the documentation. It seemed like a waste of time, so I just tried adding a few lines in ~/.bashrc.
NVARCH=`uname -s`_`uname -m`
export NVARCH
NVCOMPILERS=/opt/nvidia/hpc_sdk
export NVCOMPILER
MANPATH=$MANPATH:$NVCOMPILERS/$NVARCH/24.3/compilers/man
export MANPATH
PATH=$NVCOMPILERS/$NVARCH/24.3/compilers/bin:$PATH
export PATH
export PATH=$NVCOMPILERS/$NVARCH/24.3/comm_libs/mpi/bin:$PATH
export MANPATH=$MANPATH:$NVCOMPILERS/$NVARCH/24.3/comm_libs/mpi/man
export MODULEPATH=$NVCOMPILERS/modulefiles:$MODULEPATH
module load nvhpc
Now, all HPC Compilers are detected. But, there will always be a module: command not found
error every time I open a new shell. Is this module
thing really important? I commented out that # module ...
part, hence the error are gone for every new shell. Is that okay?
- What errors might occur? What do I seem to be missing?
If my case is for AI training and inference, 3D graphics rendering (OpenGL, DX, VK, Metal), cross-OS and cross-arch code compiling for further use in the .NET/Mono C# environment,
- Which should I choose, the NVHPC SDK or just the pure CUDA Toolkit?
- Or do I actually do programming using this tool, in Windows?
