Here is my kernel code. When I launch it, it’s appear different problems (the computer’s get blocked, cuda errors like too many resources, bad configuration, launch time exceed, etc…) If you can see any fatal error, please tell me. Thanks!
#include <stdio.h>
#include "definidos.h"
#include <math.h>
__device__ unsigned int toolarge;
__device__ int alldone;
__device__ unsigned int donesofar;
__device__ float aveps;
__device__ float vareps;
__device__ int find_nearest(int n,unsigned int dim,float eps,
unsigned int *local_toolarge,float *local_aveps,float *local_vareps,
int *box, float *series, int *list, int b,unsigned int del,
float varz,float rt, unsigned int theil,int id);
__device__ void make_box(float *ser,int *list, int* box,unsigned int l,
unsigned int bs,unsigned int begin_col,unsigned int end_col,
unsigned int dim,unsigned int del,float eps);
__device__ void localdim(int tambox ,int ident, int numerohilos,int* begin_col, int* end_col);
__device__ void evaluate(int begin,int end,unsigned int dim,float epsilon,
int *local_alldone,unsigned int *local_donesofar,
int *nearest, int *box, float *series, int *list, int b,unsigned int del,
/* make_box(): This function generates the box matrix. Parallel version for SM architectures.
* -Arguments:
* float *ser: Time series array.
* int **box: Box matrix.
* int *list: List array.
* unsigned int l: Number of points.
* unsigned int bs: Box size.
* unsigned int begin_col: First column (from rank assigned).
* unsigned int end_col: Last column (from rank assigned).
* unsigned int dim: Embedding dimension.
* unsigned int del: Delay of vectors.
* float eps: Value of epsilon.
* -Return value:
* None.
__device__
int i,x,y;
int ib=bs-1;
int d = (dim-1)*del;
for (x=begin_col;x<=end_col;x++)
for (y=0;y<bs;y++)
box[y*bs+x] = -1;
for (i=d;i<l;i++)
x = (int)(ser[i-d]/eps)&ib;
if ((x >= begin_col) && ( x <= end_col))
y = (int)(ser[i]/eps)&ib;
list[i] = box[x*bs+y];
box[x*bs+y] = i;
/* localdim(): This function assigns a rank of points/columns to the actual process.
* -Arguments:
* int d: Number of points/columns.
* int id: Process identifier.
* int nprocs: Process number.
* int *begin: First point/column for the actual process.
* int *end: Last point/column for the actual process.
* -Return value:
* None.
__device__
int quotient,rem;
quotient = tambox/numerohilos;
rem = tambox % numerohilos;
if (rem == 0)
*begin_col = ident*quotient;
*end_col = *begin_col + quotient;
else
if (ident < rem)
*begin_col = ident*(quotient+1);
*end_col = *begin_col + quotient + 1;
else
*begin_col = rem*(quotient+1)+(ident-rem)*quotient;
*begin_col = *begin_col + 1;
/* evaluate(): This function resolves the part of the neighbour searching task assigned to the actual process.
* -Arguments:
* int begin: First point (from rank assigned).
* int end: Last point (from rank assigned).
* float epsilon: Value of epsilon.
* int *local_alldone: alldone local variable.
* unsigned int *local_donesofar: donesofar local variable.
* unsigned int *local_toolarge: toolarge local variable.
* float *local_aveps: aveps local variable.
* float *local_vareps: vareps local variable.
* -Return value:
* None.
__device__
float varz,float rt, unsigned int theil, int id)
int i;
for (i=begin;i<=end;i++)
if (!nearest[i])
nearest[i] = find_nearest(i,dim,epsilon,
local_toolarge,local_aveps,local_vareps,box,series,list,b,del,varz,rt,theil,id);
*local_alldone &= nearest[i];
*local_donesofar += (unsigned int)nearest[i];
/* find_nearest(): This function implements the neighbour searching task for the point n.
* -Arguments:
* int n: Point.
* -Return value:
* 0: No nearest neighbour found (with distance < epsilon).
* 1: Nearest neighbour found (with distance < epsilon).
__device__
int x,y,x1,x2,y1,i,i1;
int element,which = -1;
float dx,maxdx,mindx=1.1,factor;
int ibox = b-1;
x = (int)(series[n-(dim-1)*del]/eps)&ibox;
y = (int)(series[n]/eps)&ibox;
for (x1=x-1;x1<=x+1;x1++)
x2 = x1&ibox;
for (y1=y-1;y1<=y+1;y1++)
element = box[x2*b+(y1&ibox)];
while (element != -1)
if (labs(element-n) > theil)
maxdx = fabs(series[n]-series[element]);
for (i=1;i<dim;i++)
i1 = i*del;
dx = fabs(series[n-i1]-series[element-i1]);
if (dx > maxdx)
maxdx = dx;
if ((maxdx < mindx) && (maxdx > 0.0))
which = element;
mindx = maxdx;
element = list[element];
if ((which != -1) && (mindx <= eps) && (mindx <= varz/rt))
*local_aveps += mindx;
*local_vareps += mindx*mindx;
factor = fabs(series[n+1]-series[which+1])/mindx;
if (factor > rt)
*local_toolarge += 1;
return 1;
return 0;
__global__ void
kernel(int b, unsigned int mind, unsigned int maxd,
unsigned int del, unsigned int len, unsigned int theil, float rt,
float varz, int *cuda_list,int *cuda_nearest,int* cuda_box, float* cuda_series,
unsigned int ver,float inter,int stdo,float *cuda_fracfnn,float *cuda_aveps,
float *cuda_vareps)
// Block index
int bx = blockIdx.x;
int by = blockIdx.y;
// Thread index
int tx = threadIdx.x;
int ty = threadIdx.y;
int id = by*blockDim.x*blockDim.y*GRID_SIZE + bx *blockDim.x*blockDim.y+ty*blockDim.x+tx;
float epsilon;
int i;
unsigned int dim;
float eps0 = 1.0e-5;
int firstdata,begin,end,begin_col,end_col;
float local_aveps = 0.0,local_vareps = 0.0;
unsigned int local_toolarge = 0,local_donesofar = 0;
int local_alldone = 0;
localdim(b,id, NHILOS ,&begin_col,&end_col);
begin_col -= 1;
end_col -= 1;
for(dim = mind;dim <= maxd; dim++){
epsilon = eps0;
toolarge = 0;
alldone = 0;
donesofar = 0;
aveps = 0.0;
vareps = 0.0;
firstdata = (dim-1)*del;
localdim((len-firstdata),id,NHILOS,&begin,&end);
begin = (begin - 1) + firstdata;
end = (end - 1) + firstdata;
if (id == (NHILOS-1))
end = end - 1;
__syncthreads();
cuda_nearest[i] = 0;
while (!alldone && (epsilon < 2.*varz/rt))
local_alldone = 1;
make_box(cuda_series,cuda_list,cuda_box,len-1,b,begin_col,end_col,dim,del,epsilon);
alldone = 1;
__syncthreads();
evaluate(begin, end, dim, epsilon,&local_alldone,&local_donesofar,&local_toolarge,&local_aveps,&local_vareps,cuda_nearest,cuda_box,cuda_series,cuda_list,b,del,varz,rt,theil,id);
alldone &= (int) local_alldone;
donesofar += (unsigned int) local_donesofar;
__syncthreads();
epsilon *=sqrt(2.0);
if (!donesofar)
eps0=epsilon;
local_alldone=0;
local_donesofar=0;
if (donesofar==0)
//the thread should exit. I don't know how to do it
toolarge += (unsigned int) local_toolarge;
aveps += local_aveps;
vareps += local_vareps;
if (id==NHILOS-1)
aveps *= (1./(float)donesofar);
vareps *= (1./(float)donesofar);
cuda_fracfnn[dim-mind]=(float)toolarge/(float)donesofar;
cuda_aveps[dim-mind]=aveps;
cuda_vareps[dim-mind]=vareps;
__syncthreads();
local_toolarge = 0;
local_aveps = 0.0;
local_vareps = 0.0;
