What mean the “spi spi0.0: child node ‘controller-data’ not found” at TX1 R28.2?
Now I will use spi1 port mode.
[ 2.811458] spi-tegra114 7000d400.spi: Static pin configuration used
[ 2.811996] spi-tegra114 7000d400.spi: registered master spi0
[ 2.812113] spi spi0.0: setup 8 bpw, ~cpol, ~cpha, 40000000Hz
[ 2.812120] spi spi0.0: child node 'controller-data' not found
[ 2.812170] spi spi0.0: setup mode 0, 8 bits/w, 40000000 Hz max --> 0
[ 2.812589] spi-tegra114 7000d400.spi: registered child spi0.0
[ 2.812838] spi-tegra114 7000d600.spi: Static pin configuration used
[ 2.813317] spi-tegra114 7000d600.spi: registered master spi1
[ 2.813419] spi spi1.0: setup 8 bpw, ~cpol, ~cpha, 40000000Hz
[ 2.813424] spi spi1.0: child node 'controller-data' not found
[ 2.813470] spi spi1.0: setup mode 0, 8 bits/w, 40000000 Hz max --> 0
[ 2.813828] spi-tegra114 7000d600.spi: registered child spi1.0
[ 2.814052] spi-tegra114 7000d800.spi: Static pin configuration used
[ 2.814559] spi-tegra114 7000d800.spi: registered master spi2
[ 2.814662] spi spi2.0: setup 8 bpw, ~cpol, ~cpha, 40000000Hz
[ 2.814667] spi spi2.0: child node 'controller-data' not found
[ 2.814713] spi spi2.0: setup mode 0, 8 bits/w, 40000000 Hz max --> 0
