hi,
for two month on and off I have been trying to write an Cuda addon to an application.
At first the plugin was a static library and I found a great deal of problems trying to get dynamics parallelism along with some othe thing that are not important now.
after reading all the docs, I had my hand off and following all the recommendations on these forums, blogs and other forums like stack overflood, nothing has worked and I keep getting the same unresolved references to some generated function generated by the the NVidia compiler.
I understood that since my project was a static library, that maybe this was the reason I could not get the link to work.
Finally I decided to play by the rules and make my project a dll.
after days and days trying to get it to work, it simply refuses to link and this time it does not even say what the error was. I simple get this message
2>C:\tmp>“C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.7\bin\nvcc.exe” -dlink -o ndSolverCuda_1.dir\Debug\ndSolverCuda_1.device-link.obj -Xcompiler “/EHsc /W4 /nologo /Od /FdndSolverCuda_1.dir\Debug\vc143.pdb /Zi /RTC1 /MDd /GR” -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.7\bin/crt" -L"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.7\lib\x64" “C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v11.7\lib\Win32\cudadevrt.lib” “C:\Program Files\NVIDIA GPU Computing
Toolkit\CUDA\v11.7\lib\Win32\cudart_static.lib” cudadevrt.lib 2>nvlink fatal : unexpected object after cudadevrt
so I decide to make a extreme minimalist project to expose the error, but that still have the same error.
I uploaded on the link below in case any one what to take a look and tell me what it is.
as it stand now it I can no resolve this issue, it simply means a death blow to the entire project.
