This is to some degree a personal preference of mine. Probably not terribly important on modern GPUs, in most cases. It comes down to the organization of work in a 2D setting, when the structure of the block is overlaid on the data set (or the “work”).
Let’s consider a simple example, a 32x32 data set. To drive the point home, let’s consider a data set consisting of byte quantities. The 16x16 block structure would be like this:
b1 b1 b1 b1 b1 b1 b1 b1 b1 b1 b1 b1 b1 b1 b1 b1 b2 b2 b2 b2 b2 b2 b2 b2 b2 b2 b2 b2 b2 b2 b2 b2
b3 b3 b3 b3 b3 b3 b3 b3 b3 b3 b3 b3 b3 b3 b3 b3 b4 b4 b4 b4 b4 b4 b4 b4 b4 b4 b4 b4 b4 b4 b4 b4
We see that effectively this data set is broken into 4 quadrants, for a 16x16 block, where each block is responsible for one quadrant (this assumes canonical index generation, i.e. int idx = threadIdx.x+blockDim.x*blockIdx.x
and int idy = threadIdx.y+blockDim.y*blockIdx.y
Now suppose that the first step in my computation is for each thread to load its respective value from global memory. For block b1
, the first warp will load the first half of the first row of data, and the first half of the second row of data. For our 1-byte element case, that is 16 bytes starting at address offset 0 and 16 bytes starting at address offset 32. Is that, by definition, a fully or perfectly coalesced load? It is not.
Is that important? Maybe, but probably not in many/most cases. If we posit 32-bit elements instead of 8-bit elements, and we also posit a “modern” GPU like Pascal or newer, that has its L1 cache broken into 4 32-byte sectors per cacheline, then the load inefficiency probably goes away. It is still not a “perfectly coalesced” load in terms of what I consider to be canonical CUDA teaching (all threads in the warp are loading adjacent elements, or elements that fall within the same L1 cacheline), but the advancement in GPU architecture I think makes the point moot; it still achieves 100% efficiency using the definition of bytes requested/bytes retrieved.
Another benefit for me personally is that I usually like to be able to study a piece of code statically (meaning, inspect it with my eyes) and quickly come to the conclusion as to whether or not it will “nicely coalesce” (I have a fairly simple method to do this, which I teach when I am teaching CUDA). In my opinion, for me personally, that is a bit easier to do if there is not this breakpoint in the middle of each warp.
even in the 1-byte per element case, we could observe that the load of the first warp in b1
would load some elements needed by the first warp in b2
. The GPU caches will tend to provide some benefit in this case, depending on locality of block execution. Certainly the L2 cache can provide some benefit, even if b1
and b2
happen to be on different SMs, as long as they execute close enough to each other temporally. If b1
and b2
happen to be on the same SM, then they can benefit from the L1 also, potentially.
It’s not a first-level consideration, just something that appeals to the thought processes I put in my head in Fermi/Kepler days. Which is why I said:
Your choice of 16x16 block shape is a commonly used choice, and should give good results in many/most situations.
