Hey,
I have a Thinkpad with a dedicated RTX 3070 mobile. I am using Ubuntu 21.04 with KDE and in nvidia-settings the system is set to work in the on-demand mode.
Recently I read on reddit that even probing the temperature causes the GPU to be awake. The power state can be checked in /sys/bus/pci/devices/0000\:01\:00.0/power_state and it always says D0, even after I have removed the sensor from the KDE widget that shows the temperature in the system tray.
Furthermore, nvidia-smi reports a process that is always running:
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1027686 G /usr/lib/xorg/Xorg 4MiB |
I am not sure whether this affects the power state.
How can I figure out what’s keeping my card awake and how I can turn it off when I don’t need it?
[edit]
Even after shutting down the X server via systemctl stop sddm.service it still reported the power state as D0. Might that be an issue with the driver?
