When I insert a USB hard disk, the camera will have an error.
dmesg.txt (135.0 KB)
syslog.txt (1.1 MB)
Softversion
jp5.1.2
device:
orin NX
[ 2138.702636] fusb301 1-0025: fusb301_work_handler: int_sts[0x01]
[ 2138.703177] fusb301 1-0025: sts[0x11], type[0x10]
[ 2138.703496] fusb301 1-0025: fusb301_set_mode: mode (4)(4)
[ 2138.703822] fusb301 1-0025: fusb_update_state: a
[ 2139.339405] fusb301 1-0025: fusb301_set_mode: mode (1)(1)
[ 2139.339730] fusb301 1-0025: fusb_update_state: b
[ 2139.487821] fusb301 1-0025: fusb301_work_handler: int_sts[0x01]
[ 2139.488369] fusb301 1-0025: sts[0x11], type[0x10]
[ 2139.489131] fusb301 1-0025: fusb301_set_dfp_power: host current(1)
[ 2139.489133] fusb301 1-0025: fusb_update_state: 7
[ 2140.102629] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 2140.102631] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 2140.102640] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 2140.111762] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 2140.112338] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 2140.149910] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 2141.126634] tegra194-vi5 13e40000.host1x:vi1@14c00000: capture control message timed out
[ 2141.126649] tegra194-vi5 13e40000.host1x:vi0@15c00000: capture control message timed out
[ 2141.134981] tegra194-vi5 13e40000.host1x:vi1@14c00000: vi_capture_release: release channel IVC failed
[ 2141.134997] ------------[ cut here ]------------
[ 2141.135007] WARNING: CPU: 2 PID: 4642 at /data00/home/bytedancebuild002/master/L4T-public-source/bsp/jp5.1.2/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/fusa-capture/capture-vi.c:971 vi_capture_release+0x2b8/0x2e0
[ 2141.135008] Modules linked in: nfnetlink iptable_nat xt_MASQUERADE nf_nat nf_conntrack
[ 2141.144680] tegra194-vi5 13e40000.host1x:vi0@15c00000: vi_capture_release: release channel IVC failed
[ 2141.152828] nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c nvidia_modeset(OE) fuse mttcan can_dev can_raw can lzo_rle lzo_compress zram overlay ramoops reed_solomon option usb_wwan usbserial loop 8021q garp mrp
[ 2141.174047] ------------[ cut here ]------------
[ 2141.183335] wlan(OE)
[ 2141.183341] WARNING: CPU: 3 PID: 4645 at /data00/home/bytedancebuild002/master/L4T-public-source/bsp/jp5.1.2/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/fusa-capture/capture-vi.c:971 vi_capture_release+0x2b8/0x2e0
[ 2141.183342] snd_soc_tegra186_asrc snd_soc_tegra210_ope
[ 2141.190626] tegra194-vi5 13e40000.host1x:vi1@14c00000: capture control message timed out
[ 2141.190630] tegra194-vi5 13e40000.host1x:vi1@14c00000: vi_capture_release: release channel IVC failed
[ 2141.190642] ------------[ cut here ]------------
[ 2141.190650] WARNING: CPU: 7 PID: 4643 at /data00/home/bytedancebuild002/master/L4T-public-source/bsp/jp5.1.2/kernel_src/kernel/nvidia/drivers/media/platform/tegra/camera/fusa-capture/capture-vi.c:971 vi_capture_release+0x2b8/0x2e0
[ 2141.190650] Modules linked in: nfnetlink iptable_nat xt_MASQUERADE nf_nat nf_conntrack nf_defrag_ipv6 nf_defrag_ipv4 libcrc32c nvidia_modeset(OE) fuse mttcan can_dev can_raw can lzo_rle lzo_compress zram overlay ramoops reed_solomon option usb_wwan usbserial loop 8021q garp mrp wlan(OE) snd_soc_tegra186_asrc snd_soc_tegra210_ope snd_soc_tegra186_dspk snd_soc_tegra186_arad snd_soc_tegra210_iqc snd_soc_tegra210_mvc snd_soc_tegra210_afc snd_soc_tegra210_dmic snd_soc_tegra210_adx snd_soc_tegra210_amx aes_ce_blk snd_soc_tegra210_mixer snd_soc_tegra210_i2s crypto_simd snd_soc_tegra210_admaif snd_soc_tegra210_sfc snd_soc_tegra_pcm cryptd aes_ce_cipher uvcvideo ghash_ce sha2_ce cfg80211 sha256_arm64 snd_soc_tegra210_adsp videobuf2_vmalloc sha1_ce cdc_acm snd_soc_tegra_machine_driver snd_hda_codec_hdmi snd_soc_tegra_utils r8168 snd_soc_simple_card_utils snd_soc_spdif_tx pwm_fan snd_hda_tegra nvgpu snd_hda_codec nvadsp fusb301 userspace_alert snd_soc_tegra210_ahub ina3221 wlan_cnss_core_pcie(OE)
[ 2141.190706] snd_hda_core tegra_bpmp_thermal tegra210_adma spi_tegra114 nvidia(OE) nv_ar0233 binfmt_misc nvmap GobiNet(OE) ip_tables x_tables [last unloaded: mtd]
[ 2141.190720] CPU: 7 PID: 4643 Comm: vi-output, ar02 Tainted: G OE 5.10.120-tegra #1
[ 2141.190721] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 202210.3-6362cf511-dirty 12/19/2023
[ 2141.190723] pstate: 60c00009 (nZCv daif +PAN +UAO -TCO BTYPE=--)
[ 2141.190725] pc : vi_capture_release+0x2b8/0x2e0
[ 2141.190726] lr : vi_capture_release+0x2b8/0x2e0
[ 2141.190727] sp : ffff80002f40bbe0
[ 2141.190727] x29: ffff80002f40bbe0 x28: 0000000000000000
[ 2141.190729] x27: ffff80002f6dba28 x26: ffff760943a6b880
[ 2141.190731] x25: ffff760943a6b570 x24: ffff76099da29e00
[ 2141.190732] x23: 00000000ffffff92 x22: ffff76099a85d900
[ 2141.190734] x21: ffff760943a160a0 x20: 0000000000000001
[ 2141.190735] x19: ffff760975833000 x18: 0000000000000000
[ 2141.190737] x17: 0000000000000000 x16: 0000000000000000
[ 2141.190738] x15: 0000000000000000 x14: 6320657361656c65
[ 2141.190740] x13: 72203a657361656c x12: 65725f6572757470
[ 2141.190741] x11: 61635f6976203a30 x10: 3030303063343140
[ 2141.190743] x9 : ffffd95a899edd5c x8 : 656c696166204356
[ 2141.190744] x7 : 0000000000000018 x6 : ffff80002f40b888
[ 2141.190745] x5 : ffff760cae82a998 x4 : 0000000000000000
[ 2141.190747] x3 : 0000000000000001 x2 : 0000000000000000
[ 2141.190748] x1 : 0000000000000000 x0 : 0000000000000000
[ 2141.190750] Call trace:
[ 2141.190752] vi_capture_release+0x2b8/0x2e0
[ 2141.190756] vi5_channel_error_recover+0x50/0x230
[ 2141.190757] tegra_channel_error_recover+0x7c/0xa0
[ 2141.190759] tegra_channel_kthread_capture_dequeue+0x134/0x1f0
[ 2141.190763] kthread+0x148/0x170
[ 2141.190766] ret_from_fork+0x10/0x38
[ 2141.190768] ---[ end trace 8a3042da67816afe ]---
[ 2141.204315] Modules linked in:
[ 2141.212626] snd_soc_tegra186_dspk
[ 2141.222102] nfnetlink iptable_nat
[ 2141.239357] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2141.239369] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2141.239370] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2141.239372] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2141.239383] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2141.239385] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2141.239386] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2141.239392] video4linux video3: vi capture release failed
[ 2141.239396] tegra-camrtc-capture-vi tegra-capture-vi: fatal: error recovery failed
[ 2141.243076] snd_soc_tegra186_arad
[ 2141.247802] xt_MASQUERADE
[ 2141.254752] snd_soc_tegra210_iqc
[ 2141.261698] nf_nat
[ 2141.268642] snd_soc_tegra210_mvc
[ 2141.275589] nf_conntrack
[ 2141.282539] snd_soc_tegra210_afc
[ 2141.289475] nf_defrag_ipv6 nf_defrag_ipv4
[ 2141.296429] snd_soc_tegra210_dmic
[ 2141.301953] libcrc32c
[ 2141.309699] snd_soc_tegra210_adx
[ 2141.309700] nvidia_modeset(OE)
[ 2141.309701] snd_soc_tegra210_amx aes_ce_blk
[ 2141.309703] fuse mttcan
[ 2141.309704] snd_soc_tegra210_mixer
[ 2141.309705] can_dev
[ 2141.309706] snd_soc_tegra210_i2s
[ 2141.309707] can_raw
[ 2141.309708] crypto_simd
[ 2141.309709] can
[ 2141.309709] snd_soc_tegra210_admaif
[ 2141.309711] lzo_rle
[ 2141.309711] snd_soc_tegra210_sfc
[ 2141.309712] lzo_compress
[ 2141.309713] snd_soc_tegra_pcm
[ 2141.309714] zram
[ 2141.309715] cryptd
[ 2141.309716] overlay
[ 2141.309716] aes_ce_cipher uvcvideo
[ 2141.309718] ramoops reed_solomon
[ 2141.309720] ghash_ce
[ 2141.309721] option usb_wwan usbserial
[ 2141.309723] sha2_ce
[ 2141.309724] loop
[ 2141.309725] cfg80211
[ 2141.309726] 8021q
[ 2141.309727] sha256_arm64
[ 2141.309728] garp
[ 2141.309728] snd_soc_tegra210_adsp
[ 2141.309729] mrp
[ 2141.309730] videobuf2_vmalloc
[ 2141.309731] wlan(OE)
[ 2141.309732] sha1_ce cdc_acm
[ 2141.309734] snd_soc_tegra186_asrc snd_soc_tegra210_ope snd_soc_tegra186_dspk
[ 2141.309736] snd_soc_tegra_machine_driver
[ 2141.309737] snd_soc_tegra186_arad
[ 2141.309738] snd_hda_codec_hdmi
[ 2141.309739] snd_soc_tegra210_iqc
[ 2141.309740] snd_soc_tegra_utils r8168
[ 2141.309741] snd_soc_tegra210_mvc snd_soc_tegra210_afc snd_soc_tegra210_dmic
[ 2141.309744] snd_soc_simple_card_utils
[ 2141.309745] snd_soc_tegra210_adx
[ 2141.309746] snd_soc_spdif_tx pwm_fan
[ 2141.309747] snd_soc_tegra210_amx aes_ce_blk snd_soc_tegra210_mixer
[ 2141.309750] snd_hda_tegra
[ 2141.309751] snd_soc_tegra210_i2s
[ 2141.309752] nvgpu
[ 2141.309753] crypto_simd
[ 2141.309754] snd_hda_codec
[ 2141.309755] snd_soc_tegra210_admaif
[ 2141.309755] nvadsp
[ 2141.309756] snd_soc_tegra210_sfc
[ 2141.309757] fusb301
[ 2141.309758] snd_soc_tegra_pcm
[ 2141.309759] userspace_alert
[ 2141.309760] cryptd
[ 2141.309761] snd_soc_tegra210_ahub
[ 2141.309762] aes_ce_cipher
[ 2141.309762] ina3221
[ 2141.309764] uvcvideo
[ 2141.309764] wlan_cnss_core_pcie(OE)
[ 2141.309765] ghash_ce
[ 2141.309766] snd_hda_core
[ 2141.309767] sha2_ce
[ 2141.309768] tegra_bpmp_thermal
[ 2141.309769] cfg80211
[ 2141.309769] tegra210_adma
[ 2141.309771] sha256_arm64
[ 2141.309771] spi_tegra114
[ 2141.309772] snd_soc_tegra210_adsp
[ 2141.309773] nvidia(OE)
[ 2141.309774] videobuf2_vmalloc
[ 2141.309775] nv_ar0233 binfmt_misc
[ 2141.309776] sha1_ce cdc_acm snd_soc_tegra_machine_driver
[ 2141.309779] nvmap
[ 2141.309780] snd_hda_codec_hdmi
[ 2141.309781] GobiNet(OE)
[ 2141.309782] snd_soc_tegra_utils
[ 2141.309783] ip_tables
[ 2141.309784] r8168
[ 2141.309784] x_tables [last unloaded: mtd]
[ 2141.309786] snd_soc_simple_card_utils
[ 2141.309789] snd_soc_spdif_tx pwm_fan snd_hda_tegra nvgpu
[ 2141.309793] CPU: 2 PID: 4642 Comm: vi-output, ar02 Tainted: G W OE 5.10.120-tegra #1
[ 2141.309795] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 202210.3-6362cf511-dirty 12/19/2023
[ 2141.309796] snd_hda_codec
[ 2141.309799] pstate: 60c00009 (nZCv daif +PAN +UAO -TCO BTYPE=--)
[ 2141.309800] nvadsp
[ 2141.309802] pc : vi_capture_release+0x2b8/0x2e0
[ 2141.309803] fusb301 userspace_alert
[ 2141.309805] lr : vi_capture_release+0x2b8/0x2e0
[ 2141.309807] snd_soc_tegra210_ahub
[ 2141.309808] sp : ffff80002f843be0
[ 2141.309809] ina3221
[ 2141.309810] x29: ffff80002f843be0
[ 2141.309812] wlan_cnss_core_pcie(OE)
[ 2141.309812] x28: 0000000000000000
[ 2141.309814] snd_hda_core
[ 2141.309815] x27: ffff80002f743a28
[ 2141.309816] tegra_bpmp_thermal
[ 2141.309818] x26: ffff760943ba8880
[ 2141.309819] tegra210_adma
[ 2141.309821] spi_tegra114
[ 2141.309822] x25: ffff760943ba8570
[ 2141.309823] nvidia(OE)
[ 2141.309824] x24: ffff76099bc6da00
[ 2141.309826] nv_ar0233
[ 2141.309827] x23: 00000000ffffff92
[ 2141.309828] binfmt_misc
[ 2141.309830] x22: ffff76099a85d200
[ 2141.309831] nvmap
[ 2141.309833] GobiNet(OE)
[ 2141.309834] x21: ffff760943a160a0
[ 2141.309835] ip_tables
[ 2141.309836] x20: 0000000000000001
[ 2141.309837] x_tables
[ 2141.309840] [last unloaded: mtd]
[ 2141.309841] x19: ffff760975835c00
[ 2141.309843] x18: 0000000000000010
[ 2141.309846] CPU: 3 PID: 4645 Comm: vi-output, ar02 Tainted: G W OE 5.10.120-tegra #1
[ 2141.309847] Hardware name: Unknown NVIDIA Orin NX Developer Kit/NVIDIA Orin NX Developer Kit, BIOS 202210.3-6362cf511-dirty 12/19/2023
[ 2141.309849] x17: 0000000000000000
[ 2141.309851] pstate: 60c00009 (nZCv daif +PAN +UAO -TCO BTYPE=--)
[ 2141.309852] x16: ffffd95a89905480
[ 2141.309854] pc : vi_capture_release+0x2b8/0x2e0
[ 2141.309857] lr : vi_capture_release+0x2b8/0x2e0
[ 2141.309858] x15: ffff76099bc6df70
[ 2141.309859] sp : ffff80002f84bbe0
[ 2141.309860] x14: 6320657361656c65
[ 2141.309861] x29: ffff80002f84bbe0
[ 2141.309864] x28: 0000000000000000
[ 2141.309865] x13: 72203a657361656c
[ 2141.309867] x12: 65725f6572757470
[ 2141.309868] x27: ffff80002f733a28
[ 2141.309870] x26: ffff760943a6f880
[ 2141.309871] x11: 61635f6976203a30
[ 2141.309874] x10: 3030303063343140
[ 2141.309875] x25: ffff760943a6f570
[ 2141.309877] x24: ffff76099bc6bc00
[ 2141.309878] x9 : ffffd95a899edd5c
[ 2141.309880] x8 : 656c696166204356
[ 2141.309881] x23: 00000000ffffff92
[ 2141.309884] x22: ffff76099bd43f00
[ 2141.309885] x7 : 0000000000000018
[ 2141.309887] x6 : ffff80002f843888
[ 2141.309888] x21: ffff760943a160a0
[ 2141.309890] x20: 0000000000000001
[ 2141.309891] x5 : ffff760cae785998
[ 2141.309893] x4 : 0000000000000000
[ 2141.309894] x19: ffff760975833800
[ 2141.309897] x18: 0000000000000000
[ 2141.309897] x3 : 0000000000000001
[ 2141.309900] x2 : 0000000000000000
[ 2141.309901] x17: 0000000000000000
[ 2141.309903] x16: 0000000000000000
[ 2141.309904] x1 : 0000000000000000
[ 2141.309906] x0 : 0000000000000000
[ 2141.309907] x15: 0000ffff1bf33858
[ 2141.309909] x14: 0000000000000000
[ 2141.309911] Call trace:
[ 2141.309912] x13: 0000000000000000 x12: 0000000000000000
[ 2141.309915] vi_capture_release+0x2b8/0x2e0
[ 2141.309918] vi5_channel_error_recover+0x50/0x230
[ 2141.309921] tegra_channel_error_recover+0x7c/0xa0
[ 2141.309922] x11: 0000000000000000 x10: c9069eb714b9bb12
[ 2141.309925] tegra_channel_kthread_capture_dequeue+0x134/0x1f0
[ 2141.309930] kthread+0x148/0x170
[ 2141.309931] x9 : ffffd95a89ac9fc8
[ 2141.309935] ret_from_fork+0x10/0x38
[ 2141.309936] x8 : ffff76099bc6cac8
[ 2141.309938] ---[ end trace 8a3042da67816aff ]---
[ 2141.314663] x7 : ffff80002fbc3ca0 x6 : 000000000000016e
[ 2141.314665] x5 : 0000000000000000 x4 : ffff760cae7a6998
[ 2141.314668] x3 : ffff760cae7b6b70 x2 : 0000000000000000
[ 2141.314670] x1 : 0000000000000000 x0 : 0000000000000000
[ 2141.314672] Call trace:
[ 2141.314676] vi_capture_release+0x2b8/0x2e0
[ 2141.314680] vi5_channel_error_recover+0x50/0x230
[ 2141.314681] tegra_channel_error_recover+0x7c/0xa0
[ 2141.314683] tegra_channel_kthread_capture_dequeue+0x134/0x1f0
[ 2141.314688] kthread+0x148/0x170
[ 2141.314690] ret_from_fork+0x10/0x38
[ 2141.314692] ---[ end trace 8a3042da67816b00 ]---
[ 2141.385388] video4linux video4: vi capture release failed
[ 2141.385459] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2141.390960] tegra-camrtc-capture-vi tegra-capture-vi: fatal: error recovery failed
[ 2141.397940] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 2141.413370] video4linux video0: vi capture release failed
[ 2141.418956] tegra-camrtc-capture-vi tegra-capture-vi: fatal: error recovery failed
[ 2142.328672] print_req_error: 352 callbacks suppressed
[ 2142.328677] blk_update_request: I/O error, dev sda, sector 196438992 op 0x1:(WRITE) flags 0x104000 phys_seg 128 prio class 0
[ 2142.345517] blk_update_request: I/O error, dev sda, sector 196440016 op 0x1:(WRITE) flags 0x104000 phys_seg 128 prio class 0
[ 2142.357795] blk_update_request: I/O error, dev sda, sector 196441040 op 0x1:(WRITE) flags 0x100000 phys_seg 20 prio class 0
[ 2142.369420] blk_update_request: I/O error, dev sda, sector 196441200 op 0x1:(WRITE) flags 0x104000 phys_seg 128 prio class 0
[ 2142.381691] blk_update_request: I/O error, dev sda, sector 196442224 op 0x1:(WRITE) flags 0x104000 phys_seg 128 prio class 0
[ 2142.394061] blk_update_request: I/O error, dev sda, sector 196443248 op 0x1:(WRITE) flags 0x100000 phys_seg 3 prio class 0
[ 2142.405597] blk_update_request: I/O error, dev sda, sector 196443272 op 0x1:(WRITE) flags 0x4000 phys_seg 128 prio class 0
[ 2142.417447] blk_update_request: I/O error, dev sda, sector 196444296 op 0x1:(WRITE) flags 0x0 phys_seg 49 prio class 0
[ 2142.428609] blk_update_request: I/O error, dev sda, sector 195522560 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[ 2142.444325] blk_update_request: I/O error, dev sda, sector 34839 op 0x1:(WRITE) flags 0x100000 phys_seg 1 prio class 0
[ 2142.455451] buffer_io_error: 24 callbacks suppressed
[ 2142.455455] Buffer I/O error on dev sda1, logical block 32791, lost async page write
[ 2142.529605] Buffer I/O error on dev sda1, logical block 32791, lost async page write
[ 2142.626107] Buffer I/O error on dev sda1, logical block 32791, lost async page write
[ 2142.895216] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 2143.170666] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x07 driverbyte=0x00
[ 2143.506787] usb 2-2: new SuperSpeedPlus Gen 2 USB device number 5 using tegra-xusb
[ 2143.534801] usb 2-2: New USB device found, idVendor=0781, idProduct=55ae, bcdDevice=80.55
[ 2143.534807] usb 2-2: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 2143.534809] usb 2-2: Product: Extreme 55AE
[ 2143.534811] usb 2-2: Manufacturer: SanDisk
[ 2143.534813] usb 2-2: SerialNumber: 32333337394D343032353732
[ 2143.541697] scsi host1: uas
[ 2147.163568] scsi 1:0:0:0: Direct-Access SanDisk Extreme 55AE 8055 PQ: 0 ANSI: 6
[ 2147.173925] scsi 1:0:0:1: Enclosure SanDisk SES Device 8055 PQ: 0 ANSI: 6
[ 2147.182576] sd 1:0:0:0: [sdb] 7813971617 512-byte logical blocks: (4.00 TB/3.64 TiB)
[ 2147.190690] sd 1:0:0:0: [sdb] Write Protect is off
[ 2147.195798] sd 1:0:0:0: [sdb] Mode Sense: 37 00 10 00
[ 2147.196004] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, supports DPO and FUA
[ 2147.205943] sd 1:0:0:0: [sdb] Optimal transfer size 1048576 bytes
[ 2147.262334] sdb: sdb1
[ 2147.263987] sd 1:0:0:0: [sdb] Attached SCSI disk
