When working on elements of fragments directly, is it computed inside tensor core or CUDA core?
For example, taking bitwise operation of lower-nibble of each fragment element or taking square root of each element & assigning to another fragment’s same indexed element.
I only found examples like this:
    nvcuda::wmma::load_matrix_sync(c_frag, c + indexWarp * 16 * 16, ldc, nvcuda::wmma::mem_col_major);
    // all warp threads need to execute this
    for (int i = 0; i < c_frag.num_elements; i++)
        c_frag.x[i] += acc_frag.x[i];
    nvcuda::wmma::store_matrix_sync(c + indexWarp * 16 * 16, c_frag, ldc, nvcuda::wmma::mem_col_major);
What if the addition operation was square root instead? Does tensor core include a dedicated square-root unit inside?
        c_frag.x[i] = sqrt(acc_frag.x[i]);
Second question: if I “load” values into a fragment and if warp ends, can another warp load the same values without any load/store but directly using a defined fragment? Does CUDA allow usage of garbage values left from another block/grid/warp inside the same tensor core hardware(assuming same core was found by two different warps in different blocks). Only wondering if this can be used as a fast broadcasting mechanism from first block to all other blocks.
Lastly, is there any method to represent a scalar value as a 16x16 matrix and to define its square-root by some series of matrix-matrix multiplications (but fast inside tensor core) as a linear-algebraic way of optimizing it for hardwares that have no sqrt unit (from first question)?
the only thing that executes on the tensor core is the matrix-multiply op
load/store and fragment ops do not use TC (matrix-multiply) hardware. TC hardware has no sqrt capability. If you so a sqrt as a fragment op, and study the resultant SASS code, you can see that it is performed in a fashion similar to any other sqrt issued.
A fragment is loaded (by load_matrix_sync) into a register footprint that spans each thread in a warp. registers are local to threads; they are not directly accessible from other threads, whether those threads are in the same warp or different warps.
