Where can I report issues found in the documentation?
I am reading DOCA Flow - NVIDIA Docs and seeing some typos and broken links. Is there any prefered way of reporting such things? Thanks in advance.
Hello @synalice ,
Could you please point out the typos and broken links you found in this document?
Regards,
Chen
All of the issues I’ve found on this page so far:
  • In section Flow Life Cycle > Initialization Flow > Pipe Mode there are two pictures (one under the vnf bullet point and one under the switch bullet point) — vnf-mode-diagram and switch-mode-diagram. These pictures are shown as thumbnails and there is no way to view them in full. This is clearly not how it was intended to be.
  • In the same Flow Life Cycle > Initialization Flow > Pipe Mode section under the vnf bullet point there is also some code that is not formatted correctly (mono font, but no outline).
  • API section has a link to DOCA Library APIs page, that points to internal Nvidia’s Confluence instead of DOCA Library APIs - NVIDIA Docs.
  • “can cause the the application to fail”.
  • “Contorl pipe”
  • “forwarding can be s et either at creation time”
@synalice - Thank you for pointing this out. I’ve contacted the relevant team to correct the documentation.
Please let me know if you notice any other issues.
Regards,
Chen
From documentation:
Add field value or from src
(Ctrl+F the page for “Add field value or from” text to find it)
There might be a word missing here. I’m not sure what was meant by this.
Also, here is the error log message I’ve found:
[23:16:05:468025][1526377][DOCA][WRN][engine_port.c:1093][engine_port_stop] Port with driver id 0 has child not be stopped
I don’t think “has child not be stopped” is a valid English. Might be a typo.
That’s DOCA 3.0.0, but I doubt the message is different in 3.1.0.
