Hi NVIDIA experts
I found out there is an example of Fuse Configuration File as bellow in secure boot section
Could you please tell me Where I can get doc to explain each parameter in Fuse Configuration File?
thanks,
LImeng
Hi NVIDIA experts
thanks,
LImeng
The Fuse Configuration File is a crucial component in the secure boot process of the Jetson Orin Series, including the AGX, NX, and Nano modules. The provided context mentions that the Jetson Orin Fuse Specification Application Note contains more information about fuses and fuse names for the Orin SoC.
Unfortunately, the context does not provide a direct link to the Jetson Orin Fuse Specification Application Note. However, it does mention that the document is titled “Jetson Orin Fuse Specification Application Note” with a TBD (To Be Determined) document number, version, and date.
To obtain the document, you can try the following options:
Once you obtain the document, it should provide a detailed explanation of each parameter in the Fuse Configuration File, including their purpose, format, and any specific requirements or constraints.
In comparison to other Jetson modules, the Fuse Configuration File for the Jetson Orin Series is specific to the Orin SoC and may have different parameters and requirements than other modules, such as the Jetson Xavier or Jetson Nano.
To give you a better understanding of the Fuse Configuration File, here is a summary of the information provided in the context:
In summary, to get the documentation that explains each parameter in the Fuse Configuration File, you should try to obtain the Jetson Orin Fuse Specification Application Note through the NVIDIA website, support, or developer portal.
hello meng.li,
please visit download center for the Jetson Orin Fuse Specification.
besides.. you may see-also Jetson Orin Series Modules Fuse Update Field Services Bulletin for detail update to the FUSE_BOOT_SECURITY_INFO_0 fuse for ALL Jetson Orin Series Modules.
Is there any detailed example steps to show?
I have study some a secure boot related docs, but I am sure the correct things to enable a orin nano module into secure boot mode. If there is a detailed example steps, I can refer to it, and avoid breaking my orin nano module by accident.
thanks,
LImeng
hello meng.li,
please refer to developer guide, Burn Fuses with the Fuse Configuration file.
you may see-also Topic 300161 for the steps of burning fuses (flash and boot-up successfully) with Orin-NX-8GB for your reference,
In the link Topic 300161, the third step as below
(3) $ sudo ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only -u rsa_priv-3k.pem -v sbk.key jetson-agx-orin-devkit internal
Does this command flash all the secured images that includes bootloader images, kernel, dtb and rootfs into board?
thanks,
LImeng
hello meng.li,
it’s flash to internal storage (QSPI) only, it’s not flashing root file system.
