Use tf.cast instead.
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py”, line 1356, in _do_call
return fn(*args)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py”, line 1341, in _run_fn
options, feed_dict, fetch_list, target_list, run_metadata)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py”, line 1429, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.ResourceExhaustedError: OOM when allocating tensor with shape[1024,324] and type float on /job:localhost/replica:0/task:0/device:GPU:0 by allocator GPU_0_bfc
[[{{node mrcnn_bbox_fc/random_uniform/RandomUniform}}]]
Hint: If you want to see a list of allocated tensors when OOM happens, add report_tensor_allocations_upon_oom to RunOptions for current allocation info.
During handling of the above exception, another exception occurred:
File “/home/safran/Mask-RCNN-series-master/process_video.py”, line 3, in
from visualize_cv2 import model, display_instances, class_names
File “/home/safran/Mask-RCNN-series-master/visualize_cv2.py”, line 27, in
model.load_weights(COCO_MODEL_PATH, by_name=True)
File “/home/safran/Mask-RCNN-series-master/model.py”, line 2130, in load_weights
saving.load_weights_from_hdf5_group_by_name(f, layers)
File “/usr/lib/python3/dist-packages/keras/engine/topology.py”, line 3205, in load_weights_from_hdf5_group_by_name
K.batch_set_value(weight_value_tuples)
File “/usr/lib/python3/dist-packages/keras/backend/tensorflow_backend.py”, line 2247, in batch_set_value
get_session().run(assign_ops, feed_dict=feed_dict)
File “/usr/lib/python3/dist-packages/keras/backend/tensorflow_backend.py”, line 188, in get_session
session.run(tf.variables_initializer(uninitialized_vars))
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py”, line 950, in run
run_metadata_ptr)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py”, line 1173, in _run
feed_dict_tensor, options, run_metadata)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py”, line 1350, in _do_run
run_metadata)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/client/session.py”, line 1370, in _do_call
raise type(e)(node_def, op, message)
[[node mrcnn_bbox_fc/random_uniform/RandomUniform (defined at /usr/lib/python3/dist-packages/keras/backend/tensorflow_backend.py:3631) ]]
Original stack trace for ‘mrcnn_bbox_fc/random_uniform/RandomUniform’:
File “”, line 1, in
File “/usr/lib/python3.6/idlelib/run.py”, line 144, in main
ret = method(*args, **kwargs)
File “/usr/lib/python3.6/idlelib/run.py”, line 474, in runcode
exec(code, self.locals)
File “”, line 971, in _find_and_load
File “”, line 955, in _find_and_load_unlocked
File “”, line 665, in _load_unlocked
File “”, line 678, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/home/safran/Mask-RCNN-series-master/visualize_cv2.py”, line 25, in
mode=“inference”, model_dir=MODEL_DIR, config=config
File “/home/safran/Mask-RCNN-series-master/model.py”, line 1837, in init
self.keras_model = self.build(mode=mode, config=config)
File “/home/safran/Mask-RCNN-series-master/model.py”, line 2038, in build
fc_layers_size=config.FPN_CLASSIF_FC_LAYERS_SIZE)
File “/home/safran/Mask-RCNN-series-master/model.py”, line 948, in fpn_classifier_graph
name=‘mrcnn_bbox_fc’)(shared)
File “/usr/lib/python3/dist-packages/keras/engine/topology.py”, line 576, in call
self.build(input_shapes[0])
File “/usr/lib/python3/dist-packages/keras/layers/wrappers.py”, line 154, in build
self.layer.build(child_input_shape)
File “/usr/lib/python3/dist-packages/keras/layers/core.py”, line 830, in build
constraint=self.kernel_constraint)
File “/usr/lib/python3/dist-packages/keras/legacy/interfaces.py”, line 87, in wrapper
return func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/keras/engine/topology.py”, line 397, in add_weight
weight = K.variable(initializer(shape),
File “/usr/lib/python3/dist-packages/keras/initializers.py”, line 212, in call
dtype=dtype, seed=self.seed)
File “/usr/lib/python3/dist-packages/keras/backend/tensorflow_backend.py”, line 3631, in random_uniform
dtype=dtype, seed=seed)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/ops/random_ops.py”, line 247, in random_uniform
rnd = gen_random_ops.random_uniform(shape, dtype, seed=seed1, seed2=seed2)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/ops/gen_random_ops.py”, line 820, in random_uniform
name=name)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/op_def_library.py”, line 788, in _apply_op_helper
op_def=op_def)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/util/deprecation.py”, line 507, in new_func
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/ops.py”, line 3616, in create_op
op_def=op_def)
File “/usr/local/lib/python3.6/dist-packages/tensorflow/python/framework/ops.py”, line 2005, in init
self._traceback = tf_stack.extract_stack()
I understand that this is a memory error, please guid me of what i have to do, I could not get any help online. If ur answere it to convert it using tensorrt then please guid me in the inference too
