Why are there still so many trainable parameters even after freezing all the layers?
• Hardware (T4/V100/Xavier/Nano/etc)
NVIDIA RTX A5000
• Network Type (Detectnet_v2/Faster_rcnn/Yolo_v4/LPRnet/Mask_rcnn/Classification/etc)
YOLOv4 Object Detection with ResNet 18 Backbone
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
Command ‘tlt’ not found, did you mean:
• Training spec file(If have, please share here)
Training spec (train.yaml)
random_seed: 42
yolov4_config {
  big_anchor_shape: "[(40, 30), (50, 25), (80, 50)]"
  mid_anchor_shape: "[(20,10), (30, 16), (40, 20)]"
  small_anchor_shape: "[(8, 5), (16, 8), (10, 20)]"
  box_matching_iou: 0.5
  matching_neutral_box_iou: 0.5
  arch: "resnet"
  nlayers: 18
  arch_conv_blocks: 2
  loss_loc_weight: 1.0
  loss_neg_obj_weights: 1.0
  loss_class_weights: 1.0
  label_smoothing: 0.0
  big_grid_xy_extend: 0.05
  mid_grid_xy_extend: 0.1
  small_grid_xy_extend: 0.2
  freeze_bn: true
  freeze_blocks: [0, 1, 2, 3, 4, 5, 6, 7]
  force_relu: false
training_config {
  batch_size_per_gpu: 4
  num_epochs: 100
  enable_qat: false
  checkpoint_interval: 3
  learning_rate {
    soft_start_cosine_annealing_schedule {
      min_learning_rate: 1e-8
      max_learning_rate: 1e-5
      soft_start: 0.3
  visualizer {
    clearml_config {
      project: "TAO Toolkit ClearML Demo"
      task: "YOLOV4"
      tags: "YOLOV4"
      tags: "training"
      tags: "resnet18"
      tags: "unpruned"
    enabled: True
  regularizer {
    type: L1
    weight: 3e-5
  optimizer {
    adam {
      epsilon: 1e-7
      beta1: 0.9
      beta2: 0.999
      amsgrad: false
  # Make sure to change the path below to the model to resume training from
  #resume_model_path : "/workspace/tao-experiments/object_detection/models/pretrained_resnet18/pretrained_object_detection_vresnet18/resnet_18.hdf5"
  pretrain_model_path:  "/workspace/tao-experiments/object_detection/models/pretrained_resnet18/pretrained_object_detection_vresnet18/resnet_18.hdf5"
eval_config {
  average_precision_mode: INTEGRATE
  batch_size: 8
  matching_iou_threshold: 0.5
nms_config {
  confidence_threshold: 0.001
  clustering_iou_threshold: 0.5
  force_on_cpu: false
  top_k: 200
augmentation_config {
  hue: 0.1
  saturation: 1.5
  exposure:1.5
  vertical_flip:0.1
  horizontal_flip: 0.5
  jitter: 0.4
  output_width: 512
  output_height: 512
  output_channel: 3
  randomize_input_shape_period: 3
  mosaic_prob: 0.2
  mosaic_min_ratio:0.1
dataset_config {
  data_sources: {
      tfrecords_path: "/workspace/tao-experiments/object_detection/data/train/tfrecords/train*"
      image_directory_path: "/workspace/tao-experiments/object_detection/data/train/"
  include_difficult_in_training: true
  image_extension: "jpg"
  target_class_mapping {
      key: "aeroplane"
      value: "aeroplane"
  validation_data_sources: {
      tfrecords_path: "/workspace/tao-experiments/object_detection/data/val/tfrecords/val*"
      image_directory_path: "/workspace/tao-experiments/object_detection/data/val/"
This leaves the network structure (truncated below)
2024-01-30 14:36:49,231 [TAO Toolkit] [WARNING] tensorflow 137: From /usr/local/lib/python3.8/dist-packages/keras/backend/tensorflow_backend.py:973: The name tf.assign is deprecated. Please use tf.compat.v1.assign instead.
__________________________________________________________________________________________________
Layer (type)                    Output Shape         Param #     Connected to
Input (InputLayer)              (None, 3, 512, 512)  0
Input_qdq (QDQ)                 (None, 3, 512, 512)  1           Input[0][0]
conv1 (QuantizedConv2D)         (None, 64, 256, 256) 9408        Input_qdq[0][0]
bn_conv1 (BatchNormalization)   (None, 64, 256, 256) 256         conv1[0][0]
activation_2 (ReLU)             (None, 64, 256, 256) 0           bn_conv1[0][0]
activation_2_qdq (QDQ)          (None, 64, 256, 256) 1           activation_2[0][0]
block_1a_conv_1 (QuantizedConv2 (None, 64, 128, 128) 36864       activation_2_qdq[0][0]
block_1a_bn_1 (BatchNormalizati (None, 64, 128, 128) 256         block_1a_conv_1[0][0]
block_1a_relu_1 (ReLU)          (None, 64, 128, 128) 0           block_1a_bn_1[0][0]
block_1a_relu_1_qdq (QDQ)       (None, 64, 128, 128) 1           block_1a_relu_1[0][0]
encoded_sm (Concatenate)        (None, 12288, 12)    0           sm_anchor[0][0]
        sm_bbox_processor[0][0]
encoded_detections (Concatenate (None, 16128, 12)    0           encoded_bg[0][0]
        encoded_md[0][0]
        encoded_sm[0][0]
decoded_predictions (YOLOv4Deco (None, 16128, 5)     0           encoded_detections[0][0]
NMS (NMSLayer)                  (None, 200, 6)       0           decoded_predictions[0][0]
Total params: 34,824,270
Trainable params: 34,790,646
Non-trainable params: 33,624
I have frozen the Batch Norm and all the blocks, why are basically all of the parameters trainable?
I cannot reproduce the result.
May I know where did you download the resnet_18.hdf5?
I use
ngc registry model download-version nvidia/tao/pretrained_object_detection:resnet18
CLI_VERSION: Latest - 3.37.0 available (current: 3.22.0). Please update by using the command 'ngc version upgrade'
Downloaded 82.38 MB in 8s, Download speed: 10.28 MB/s
   Transfer id: pretrained_object_detection_vresnet18
   Download status: Completed
   Downloaded local path: /home/rowden/github/nvidia-tao-exploration/pretrained_object_detection_vresnet18
   Total files downloaded: 1
   Total downloaded size: 82.38 MB
   Started at: 2024-02-01 09:14:33.994581
   Completed at: 2024-02-01 09:14:42.006398
   Duration taken: 8s
It would be nice to know what result you are getting also?
As an update the params are now as follows:
Total params: 34,824,182
Trainable params: 23,271,478
Non-trainable params: 11,552,704
I’m not sure what has changed, is this now expected, this seems a still abnormally large amount of trainable params
You can refer to my log.
20240131_forum_280677_log.txt (59.8 KB)
The main difference is the model structure in the summary log. The hdf5 file has not qdq node. Not sure why your log has it.
Maybe you load another model instead.
From your latest log, it is expected. You can calculate the params# column.
Ok well, its nice to know we get the same numbers now.
Is there any chance you can explain why the trainable params are so high?
My understanding would be that if I freeze all those blocks the remaining trainables would come from the 3x3 Conv just after the Input layer and the Fully Connected layer.
Are there really that many parameters in those two layers?
Sorry is there any more information on this?
You can try to double check with tao_tensorflow1_backend/nvidia_tao_tf1/core/templates/resnet.py at main · NVIDIA/tao_tensorflow1_backend · GitHub, tao_tensorflow1_backend/nvidia_tao_tf1/core/templates/resnet.py at main · NVIDIA/tao_tensorflow1_backend · GitHub and tao_tensorflow1_backend/nvidia_tao_tf1/core/templates/resnet.py at main · NVIDIA/tao_tensorflow1_backend · GitHub
