Measuring the productivity of a self-test test, 150 iterations
1 GPU (Open CL) devices are detected.
OpenCL device Name :GeForce GTX 750 Ti
OpenCL device Available :1
OpenCL device ImageSupport :1
OpenCL device OpenCL C Version:OpenCL C 1.2
OpenCL device OpenCL Version :OpenCL 1.2 CUDA
OpenCL device Driver Version :390.48
OpenCL device Version :OpenCL 1.2 CUDA
Default OpenCL device Name :GeForce GTX 750 Ti
Default OpenCL device Available :1
Default OpenCL device ImageSupport :1
Default OpenCL device OpenCL_C_Version:OpenCL C 1.2
Default OpenCL device OpenCL Version :OpenCL 1.2 CUDA
Default OpenCL device Driver Version :390.48
Default OpenCL device Version :OpenCL 1.2 CUDA
CudaEnabledDeviceCount 1
*** CUDA Device Query (Runtime API) version (CUDART static linking) ***
Device count: 1
Device 0: “GeForce GTX 750 Ti”
CUDA Driver Version / Runtime Version 9.10 / 9.10
CUDA Capability Major/Minor version number: 5.0
Total amount of global memory: 2001 MBytes (2098069504 bytes)
GPU Clock Speed: 1.11 GHz
Max Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536,65536), 3D=(4096,4096,4096)
Max Layered Texture Size (dim) x layers 1D=(16384) x 2048, 2D=(16384,16384) x 2048
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per block: 1024
Maximum sizes of each dimension of a block: 1024 x 1024 x 64
Maximum sizes of each dimension of a grid: 2147483647 x 65535 x 65535
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and execution: Yes with 1 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Concurrent kernel execution: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support enabled: No
Device is using TCC driver mode: No
Device supports Unified Addressing (UVA): Yes
Device PCI Bus ID / PCI location ID: 1 / 0
Compute Mode:
Default (multiple host threads can use ::cudaSetDevice() with device simultaneously)
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.10, CUDA Runtime Version = 9.10, NumDevs = 1
Test cv::cuda::cvtColor cicle count 150 cv::cuda::GpuMat 00:00:00.033
Test cv::cuda::threshold cicle count 150 cv::cuda::GpuMat 00:00:00.029
Test cv::cuda::bitwise_or cicle count 150 cv::cuda::GpuMat 00:00:00.021
Test cv::cuda::minMaxLoc cicle count 150 cv::cuda::GpuMat 00:00:00.128
Test cv::cuda::multiply cicle count 150 cv::cuda::GpuMat 00:00:00.165
Test cv::cvtColor cicle count 150 cv::UMat 00:00:00.044
Test cv::threshold cicle count 150 cv::UMat 00:00:00.004
Test cv::bitwise_or cicle count 150 cv::UMat 00:00:00.005
Test cv::minMaxLoc cicle count 150 cv::UMat 00:00:00.022
Test cv::multiply cicle count 150 cv::UMat 00:00:00.262
Questions:
Why when I use the OpenCV library functions implemented with OpenCL support (cv :: UMat) I get a performance gain in relation to the implementation of CUDA (cv :: cuda :: GpuMat)?
I may be something that is not included when working with Cuda?
Can I put the graphics card in a performance mode?
In what can be the reason of such low indicators in relation to OpenCL?
