/example
│-- CMakeLists.txt
│-- main.cu
cmake_minimum_required(VERSION 3.12)
project(SimpleCudaProject CUDA)
set(CMAKE_CUDA_STANDARD 17)
add_executable(SimpleCudaProject main.cu)
#include <cassert>
#include <cstdio>
#define CHECK(call) \
do { \
const cudaError_t error_code = call; \
if (error_code != cudaSuccess) { \
printf("CUDA Error:\n"); \
printf("File: %s\n", __FILE__); \
printf("Line: %d\n", __LINE__); \
printf("Error code: %d\n", error_code); \
printf("Error text: %s\n", cudaGetErrorString(error_code)); \
assert(0); \
exit(1); \
} while (0)
__global__ void warmup() {}
int main() {
for (size_t i = 0; i < 3; i++) {
warmup << <1, 1 >> > ();
float* buffer;
CHECK(cudaMallocManaged(&buffer, sizeof(float) * 48));
buffer[0] = 1;
cudaFree(buffer);
return 0;
This is so confused. Can anyone help me?
Hardware: RTX5070ti laptop
latest Win11 and latest vs2022
nvcc -V
Copyright (c) 2005-2025 NVIDIA Corporation
Built on Tue_May_27_02:24:01_Pacific_Daylight_Time_2025
Cuda compilation tools, release 12.9, V12.9.86
Build cuda_12.9.r12.9/compiler.36037853_0
nvidia-smi
Tue Jun 17 14:54:47 2025
| NVIDIA-SMI 576.57 Driver Version: 576.57 CUDA Version: 12.9 |
| GPU Name Driver-Model | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 5070 … WDDM | 00000000:01:00.0 On | N/A |
| N/A 50C P8 5W / 140W | 616MiB / 12227MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 2276 C+G …iceHub.ThreadedWaitDialog.exe N/A |
| 0 N/A N/A 12412 C+G C:\Windows\explorer.exe N/A |
| 0 N/A N/A 29160 C …d\Debug\SimpleCudaProject.exe N/A |
| 0 N/A N/A 29220 C+G …munity\Common7\IDE\devenv.exe N/A |
