I am trying to get CUDA mipmapped arrays to work, but am encountering an invalid argument error when performing a device to device cudaMemcpy2D. When changing the memcpy flag from DeviceToDevice to Default it however got past the function.
This made me investigate the types of memory I was feeding it. My source pointer was indeed device memory, and the destination pointer is the mipmapped array. However, this mipmapped array is noted down as unregistered host memory.
I made a little test program to rule out external influence and indeed it reports the same:
#include "cuda_runtime.h"
#include <iostream>
//Macro for checking cuda errors following a cuda launch or api call
#define CudaCheck(ans) { cudaCheck((ans), __FILE__, __LINE__); }
inline void cudaCheck(cudaError_t code, const char* file, int line, bool abort = true)
if (code != cudaSuccess)
std::cerr << "Cuda Check Failed: " << cudaGetErrorString(code) << " " << file << " " << line << std::endl;
if (abort) exit(code);
int main()
cudaMipmappedArray_t mipArray;
cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc(32, 32, 32, 32, cudaChannelFormatKindFloat);
int mipLevels = 5;
cudaExtent extent = make_cudaExtent(1024, 1024, 0);
CudaCheck(cudaMallocMipmappedArray(&mipArray, &channelDesc, extent, mipLevels));
cudaDeviceProp prop;
CudaCheck(cudaGetDeviceProperties(&prop, 0));
printf("Unified Virtual Addressing %i\n", prop.unifiedAddressing);
cudaPointerAttributes attributes;
CudaCheck(cudaPointerGetAttributes(&attributes, mipArray));
printf("Memory type for data %i\n", attributes.type);
reports:
Unified Virtual Addressing 1
Memory type for data 0
where the memory type: 0 corresponds to:
enum __device_builtin__ cudaMemoryType
cudaMemoryTypeUnregistered = 0, /**< Unregistered memory */
cudaMemoryTypeHost = 1, /**< Host memory */
cudaMemoryTypeDevice = 2, /**< Device memory */
cudaMemoryTypeManaged = 3 /**< Managed memory */
How come cudaMallocMipmappedArray does not allocate device memory as it states in the documentation?
