Hardware Platform - NVIDIA GeForce GTX 1070
DeepStream Version 6.2
TensorRT Version 8.5.2-1+cuda11.8
NVIDIA GPU Driver Version 525.85.12
I noticed a difference in getting results from the tensorRT engine in nvinfer plugin when using the model in deepstream and my individual app.
Initialization of the model and deserialization are equally successful, the mean scale values are completely the same, versions of the cuda, cudnn, cudart libraries are completely the same, but there is a difference in the results in the third significant digit.
I decided to check the values of the buffer coming to inference in the deepstream, then in order to avoid problems associated with preprocessing, I decided to compare the picture before preprocessing.In order to avoid problems related to scaling, the frame size corresponds to net’s input. Source frame size 3х224х224.
To do this, I copied the image from the device’s memory to the host as follows. In /opt/nvidia/deepstream/deepstream-6.2/sources/libs/nvdsinfer/nvdsinfer_context_impl.cpp at 522 before performing the function convertFcn i have added:
std::vector<unsigned char> origindata(batchInput.inputPitch * m_NetworkInfo.height, 0);
cudaMemcpy(origindata.data(), (unsigned char*)batchInput.inputFrames[i], sizeof(unsigned char)*origindata.size(), cudaMemcpyDeviceToHost);
std::ofstream bfs("/home/daria/Documents/deepstream/pr1/DS-test-rtsp/Build/DSBeforePreprocess.txt");
for(const auto dataElem: origindata)
bfs<<dataElem;
At the same time, I performed the procedure of reading the frame buffer using opencv and python:
img = cv.imread("/home/daria/Documents/deepstream/3.jpg")
img = np.reshape(img, (150528,))
np.savetxt("InputImage", img, fmt='%d', newline='|')
It should be noted here that in the resulting buffer from DeepStream there is a padding of 96 pixels/line filled with zeros. The size of the received buffer instead of the expected one (224* 224 * 3 ) corresponds to (256 * 224 * 3 ). Without taking this fact into account (ignoring padding), it should be noted that there is a difference in the buffers received.
This difference on all pixels does not exceed one in value, however, this difference eventually after preprocessing gives a difference in the resulting inference result.
Please tell me what this problem may be related to? and how to fix it…
