we have computers with 2 v100 cards installed. we found that gpu1 is much faster than gpu0 ( abount 2-5x) by using same program and same dataset. we use ubuntu 16.04 , and cuda 9.1 ,cudnn 7.
we have two computers each installed 2 v100 cards and one computer installed 4 1080ti cards. the 4-card machine works well.
the two v100 machines both show gpu0 much slower than gpu1.
njuffa
October 13, 2018, 10:58pm
#2
From the application side, what guarantees proper load balancing between GPUsin a dual GPU configuration?
When you swap the two GPUs in their PCIe slots, does the slowness stay with the slot or follow the GPU?
Are the PCIe slots of both GPUs configured as gen3 x16?
Has power supply and cooling been checked for the slow GPU?
Is this a system with multiple CPU sockets?
we think the cards are installed correctly.
we use nvidia-smi to show the status :
| NVIDIA-SMI 396.26 Driver Version: 396.26 |
| 0 Tesla V100-PCIE… Off | 00000000:02:00.0 Off | 0 |
| N/A 60C P0 31W / 250W | 11MiB / 16160MiB | 0% Default |
| 1 Tesla V100-PCIE… Off | 00000000:03:00.0 Off | 0 |
| N/A 82C P0 77W / 250W | 6615MiB / 16160MiB | 100% Default |
we use the same program to run gpu0 and gpu1.
the gpu0 and gpu1 boths work. but gpu0 is much slower than gpu1.
we have 2 machines ,both installed 2 v100 cards. and they get the same result ( i.e. gpu0 is much slower than gpu1).
Any suggestion?
60C is quite hot for an idle GPU, especially when there is another active GPU in the server
Possibly a cooling issue. Did you install these V100 GPUs yourself? or did you purchase them pre-installed in an OEM server that is properly certified for Tesla V100 PCIE?
What server are these GPUs installed in?
You would be less likely to run into a corresponding cooling problem with 1080ti cards, as they provide their own cooling.
krzysg
October 15, 2018, 9:47am
#5
Can you run:
nvidia-smi -q
sudo lspci -vv -s 00000000:02:00.0
sudo lspci -vv -s 00000000:03:00.0
to provide some more info.
It would be also good to find out what does it mean ‘slower’:
are memory transfers to/from GPUs slow, or
computations on GPU are slow, or
both
I know that from application point of view it might be hard to answer but you can run bandwidthTest (from CUDA samples) on both cards and it would give some answers.
==============NVSMI LOG==============
Timestamp : Tue Oct 16 07:19:18 2018
Driver Version : 396.26
Attached GPUs : 2
GPU 00000000:02:00.0
Product Name : Tesla V100-PCIE-16GB
Product Brand : Tesla
Display Mode : Enabled
Display Active : Disabled
Persistence Mode : Disabled
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : 0321218058028
GPU UUID : GPU-3519976c-00d2-497b-8bd1-9711acddfc24
Minor Number : 0
VBIOS Version : 88.00.1A.00.03
MultiGPU Board : No
Board ID : 0x200
GPU Part Number : 900-2G500-0000-000
Inforom Version
Image Version : G500.0200.00.03
OEM Object : 1.1
ECC Object : 5.0
Power Management Object : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU Virtualization Mode
Virtualization mode : None
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x02
Device : 0x00
Domain : 0x0000
Device Id : 0x1DB410DE
Bus Id : 00000000:02:00.0
Sub System Id : 0x121410DE
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays since reset : 0
Tx Throughput : 0 KB/s
Rx Throughput : 0 KB/s
Fan Speed : N/A
Performance State : P0
Clocks Throttle Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
FB Memory Usage
Total : 16160 MiB
Used : 11 MiB
Free : 16149 MiB
BAR1 Memory Usage
Total : 16384 MiB
Used : 4 MiB
Free : 16380 MiB
Compute Mode : Default
Utilization
Gpu : 0 %
Memory : 0 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
Single Bit
Device Memory : 0
Register File : 0
L1 Cache : 0
L2 Cache : 0
Texture Memory : N/A
Texture Shared : N/A
CBU : N/A
Total : 0
Double Bit
Device Memory : 0
Register File : 0
L1 Cache : 0
L2 Cache : 0
CBU : 0
Total : 0
Aggregate
Single Bit
Device Memory : 0
Register File : 0
L1 Cache : 0
L2 Cache : 0
CBU : N/A
Total : 0
Double Bit
Device Memory : 0
Register File : 0
L1 Cache : 0
L2 Cache : 0
CBU : 0
Total : 0
Retired Pages
Single Bit ECC : 0
Double Bit ECC : 0
Pending : No
Temperature
GPU Current Temp : 59 C
GPU Shutdown Temp : 90 C
GPU Slowdown Temp : 87 C
GPU Max Operating Temp : 83 C
Memory Current Temp : 55 C
Memory Max Operating Temp : 85 C
Power Readings
Power Management : Supported
Power Draw : 30.71 W
Power Limit : 250.00 W
Default Power Limit : 250.00 W
Enforced Power Limit : 250.00 W
Min Power Limit : 100.00 W
Max Power Limit : 250.00 W
Clocks
Graphics : 135 MHz
SM : 135 MHz
Memory : 877 MHz
Video : 555 MHz
Applications Clocks
Graphics : 1245 MHz
Memory : 877 MHz
Default Applications Clocks
Graphics : 1245 MHz
Memory : 877 MHz
Max Clocks
Graphics : 1380 MHz
SM : 1380 MHz
Memory : 877 MHz
Video : 1237 MHz
Max Customer Boost Clocks
Graphics : 1380 MHz
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Processes : None
GPU 00000000:03:00.0
Driver Model
Current : N/A
Pending : N/A
Serial Number : 0321218057997
GPU UUID : GPU-1538c1cb-6887-99c4-7acf-1239d4d61991
Minor Number : 1
MultiGPU Board : No
Board ID : 0x300
Inforom Version
OEM Object : 1.1
ECC Object : 5.0
GPU Operation Mode
Current : N/A
Pending : N/A
IBMNPU
PCI
Bus : 0x03
Device : 0x00
Domain : 0x0000
Bus Id : 00000000:03:00.0
GPU Link Info
PCIe Generation
Max : 3
Current : 3
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Tx Throughput : 178000 KB/s
Rx Throughput : 1467000 KB/s
Fan Speed : N/A
Idle : Not Active
SW Thermal Slowdown : Active
FB Memory Usage
Total : 16160 MiB
Used : 6615 MiB
Free : 9545 MiB
BAR1 Memory Usage
Total : 16384 MiB
Used : 8 MiB
Free : 16376 MiB
Utilization
Gpu : 100 %
Memory : 9 %
Encoder : 0 %
Decoder : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
Ecc Mode
Current : Enabled
Pending : Enabled
ECC Errors
Volatile
Single Bit
Device Memory : 0
Register File : 0
L1 Cache : 0
L2 Cache : 0
CBU : N/A
Total : 0
Double Bit
Device Memory : 0
Register File : 0
L1 Cache : 0
L2 Cache : 0
CBU : 0
Total : 0
Aggregate
Single Bit
Device Memory : 0
Register File : 0
L1 Cache : 0
L2 Cache : 0
CBU : N/A
Total : 0
Double Bit
Device Memory : 0
Register File : 0
L1 Cache : 0
L2 Cache : 0
CBU : 0
Total : 0
Retired Pages
Single Bit ECC : 0
Double Bit ECC : 0
Pending : No
Temperature
GPU Current Temp : 82 C
Memory Current Temp : 82 C
Power Readings
Power Draw : 56.14 W
Clocks
Graphics : 367 MHz
SM : 367 MHz
Memory : 877 MHz
Video : 555 MHz
Applications Clocks
Graphics : 1245 MHz
Memory : 877 MHz
Graphics : 1245 MHz
Memory : 877 MHz
Max Clocks
Graphics : 1380 MHz
SM : 1380 MHz
Memory : 877 MHz
Video : 1237 MHz
Graphics : 1380 MHz
Clock Policy
Auto Boost : N/A
Processes
Process ID : 4715
Type : C
Used GPU Memory : 6604 MiB
02:00.0 3D controller: NVIDIA Corporation Device 1db4 (rev a1)
Subsystem: NVIDIA Corporation Device 1214
Physical Slot: 13
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 80
Region 0: Memory at d2000000 (32-bit, non-prefetchable)
Region 1: Memory at 383800000000 (64-bit, prefetchable)
Region 3: Memory at 383c00000000 (64-bit, prefetchable)
Capabilities: [60] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Address: 00000000fee00558 Data: 0000
Capabilities: [78] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset-
DevCtl: Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
LnkCap: Port #0 , Speed 8GT/s, Width x16, ASPM not supported, Exit Latency L0s <1us, L1 <4us
ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s, Width x16, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range AB, TimeoutDis+, LTR+, OBFF Via message
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [100 v1] Virtual Channel
Caps: LPEVC=0 RefClk=100ns PATEntryBits=1
Arb: Fixed- WRR32- WRR64- WRR128-
Ctrl: ArbSelect=Fixed
Status: InProgress-
VC0: Caps: PATOffset=00 MaxTimeSlots=1 RejSnoopTrans-
Arb: Fixed- WRR32- WRR64- WRR128- TWRR128- WRR256-
Ctrl: Enable+ ID=0 ArbSelect=Fixed TC/VC=01
Status: NegoPending- InProgress-
Capabilities: [250 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Capabilities: [258 v1] L1 PM Substates
L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
PortCommonModeRestoreTime=255us PortTPowerOnTime=10us
Capabilities: [128 v1] Power Budgeting <?>
Capabilities: [420 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [600 v1] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900 v1] #19
Capabilities: [ac0 v1] #23
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
03:00.0 3D controller: NVIDIA Corporation Device 1db4 (rev a1)
Physical Slot: 17
Latency: 0
Interrupt: pin A routed to IRQ 81
Region 0: Memory at d1000000 (32-bit, non-prefetchable)
Region 1: Memory at 383000000000 (64-bit, prefetchable)
Region 3: Memory at 383400000000 (64-bit, prefetchable)
Address: 00000000fee00578 Data: 0000
DevSta: CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend+
Status: InProgress-
Robert_Crovella:
our company buy the pre-installed machine. but I am sure that the seller is certified for Tesla V100 PCIE. do we need to open the machine to see the cooling fan of v100 ? we are not expert at the hardware.
njuffa
October 15, 2018, 11:47pm
#8
A V100 does not have its own fan. It is a passively cooled device that relies on adequate airflow being provided by the fans in the server enclosure.
Other than the unusually high temperature of GPU0 (59 deg C when completely idle, instead of about 40 deg C expected), I cannot spot anything unusual in the logs you posted.
So the hypothesis that GPU0 is slow because of thermal throttling still holds. You should be able to verify by putting a load on GPU0, then monitor nvidia-smi output for temperature and throttle reasons.
You can then turn to your system integrator to have them resolve the issue. Presumably they will find an non-operating fan bank (maybe defective, maybe not plugged in) or a major obstruction of airflow past GPU0.
NVIDIA Tesla partner companies are listed here: https://www.nvidia.com/en-us/data-center/where-to-buy-tesla/
