when i use fp16 to inference with jetson nano,i found that is slower than fp32,. and i found that jetson nano is support fp16,so why is slower?
How do you apply the inference on Nano?
Do you use TensorRT?
If yes, it can automatically choose an optimal algorithm (either fp32 or fp16) if the best mode is used.
$ /usr/src/tensorrt/bin/trtexec --best ...
@AastaLLL yes , i use TensorRT, you mean tensorRT can optimal choose to use fp32 or fp16?
i have model.onnx(fp32),now i want to convert onnx to .trt, and i have convert successful! but is slower than fp16
Could you share the comment and corresponding benchmark data with us first?
F_Let_fp16.trt (156.1 KB)
F-Let.trt (267.5 KB)
F_Let.pth (276.3 KB)
convert_to_onnx.py (505 Bytes)
inference-Let-10.py (5.7 KB)
thank you very much
We try to gnereate the ONNX format from .pth file with convert_to_onnx.py.
However, it shows the below dependency error:
$ python3 convert_to_onnx.py
1.8.0
File "convert_to_onnx.py", line 11, in <module>
model = torch.load('F_Let.pth', map_location="cuda:0")
File "/home/nvidia/.local/lib/python3.6/site-packages/torch/serialization.py", line 593, in load
return _legacy_load(opened_file, map_location, pickle_module, **pickle_load_args)
File "/home/nvidia/.local/lib/python3.6/site-packages/torch/serialization.py", line 772, in _legacy_load
result = unpickler.load()
ModuleNotFoundError: No module named 'lenet'
Could you share the required LeNet class with us?
Or the converted ONNX file with us?
F-LeNet-0.pth (258.4 KB)
Uploading: F-LeNet-0.pth…
Thanks for updating the new .pth with us.
Unfortunately, it still request for a custom code when converting the .pth into ONNX format.
1.8.0
File "/home/nvidia/.local/lib/python3.6/site-packages/torch/serialization.py", line 592, in load
return _load(opened_zipfile, map_location, pickle_module, **pickle_load_args)
File "/home/nvidia/.local/lib/python3.6/site-packages/torch/serialization.py", line 851, in _load
ModuleNotFoundError: No module named 'models'
Do you mind to share the model definition with us?
Or could you attach a converted ONNX file for us checking?
