Hi everyone,
I am testing the performance of matrix multiplication and encountered a confusing result.
I wrote a very simple (naive) GEMM kernel as follows:
__global__ void gemm_naive(int M, int N, int K,
DATA_TYPE alpha, DATA_TYPE beta,
DATA_TYPE *C, const DATA_TYPE *A, const DATA_TYPE *B) {
int row = blockIdx.y * blockDim.y + threadIdx.y;
int col = blockIdx.x * blockDim.x + threadIdx.x;
if (row < M && col < N) {
DATA_TYPE sum = 0.0;
for (int i = 0; i < K; i++) {
sum += A[row * K + i] * B[i * N + col];
C[row * N + col] = alpha * sum + beta * C[row * N + col];
I also tested cuBLAS by calling cublasDgemm with exactly the same matrix sizes and data:
CUDA_CHECK(cudaEventRecord(start));
CUBLAS_CHECK(cublasDgemm(handle, CUBLAS_OP_N, CUBLAS_OP_N,
N_SIZE, M_SIZE, K_SIZE, &alpha,
d_B, N_SIZE, d_A, K_SIZE, &beta,
d_C_cublas, N_SIZE));
CUDA_CHECK(cudaEventRecord(stop));
CUDA_CHECK(cudaEventSynchronize(stop));
When profiling with nsys, I surprisingly found that cuBLAS was slower than my naive kernel. This is the opposite of what I expected.
So my questions are:
Is this an expected phenomenon?
Could my way of calling cuBLAS be incorrect?
Or are these two implementations not actually performing equivalent computations?
Here are some kernel profiling results from nsys (key fields only):
//cublas:
cutlass::Kernel<cutlass_80_tensorop_d884gemm_64x64_16x4_nn_align1>
Duration: ~348 ms
grid: <<<632, 12, 1>>>
block: <<<128, 1, 1>>>
Registers Per Thread: 126
Shared Memory executed: 102,400 bytes
Theoretical occupancy: 8.3 %
//Naive kernel:
gemm_naive(int, int, int, double, double, double *, const double *, const double *)
Duration: ~305 ms
grid: <<<188, 157, 1>>>
block: <<<32, 32, 1>>>
Registers Per Thread: 40
Shared Memory executed: 8,192 bytes
Theoretical occupancy: 66.7 %
