JiaZW
1
- use 01_video_encode tools
I-frame detection indicates that only the first frame is I-frame
detect code:
if((0x0==data[0] && 0x0==data[1] && 0x1==data[2] ))
int type = (data[3] & 0x7e) >> 1;
if (type == 32){
I_frage = 1; // I frame
By default the IDR interval is 256 frames. Please set to a smaller interval and give it a try.
JiaZW
4
Set IDR interval is 1 frame, still only the first frame is I-frame
It still causes my back-end ffmpeg decoding to fail
JiaZW
5
Set IDR interval is 20 frame,
JiaZW
6
Sometimes the decoding side can not get the first frame, so it will cause ffmpeg decoding error
Please refer to this and check if there is any deviation:
Xavier AGX : Video encoding crash - #15 by DaneLLL
Maybe –insert-spspps-idr is not set in your test.
system
Closed
10
