This is part of my code. I am measuring the inference time, using the Inception_v1 model, optimised with “trtexec” + FP16. I used tf2onnx to parse the TensorFlow graph.
I have put 2 timers:
- To measure the time when sending data from CPU to GPU
- Just the inference
QUESTIONS:
- Are the results given in seconds, milliseconds, etc? I am multiplying by 1000
- Why do inference time varies so much?
- Why is it taking too much time? In this GIT, the average seems to be 8ms
https://github.com/NVIDIA-AI-IOT/tf_to_trt_image_classification
RUN 1
RUN2
RUN 3
SCRIPT
def allocate_buffers(engine, batch_size, data_type):
This is the function to allocate buffers for input and output in the device (GPU) and host (CPU)
Args:
engine : The path to the TensorRT engine.
batch_size : The batch size for execution time.
data_type: The type of the data for input and output, for example trt.float32, np.float32.
Output:
h_input: Input in the host (CPU).
d_input: Input in the device (GPU).
h_output: Output in the host (CPU).
d_output: Output in the device (GPU).
stream: CUDA stream.
# Determine dimensions and create page-locked memory buffers (which won't be swapped to disk) to hold host inputs/outputs.
h_input = cuda.pagelocked_empty(batch_size * trt.volume(engine.get_binding_shape(0)), dtype=trt.nptype(data_type))
h_output = cuda.pagelocked_empty(batch_size * trt.volume(engine.get_binding_shape(1)), dtype=trt.nptype(data_type))
# Allocate device memory for inputs and outputs (the same size as host' input and output).
d_input = cuda.mem_alloc(h_input.nbytes)
d_output = cuda.mem_alloc(h_output.nbytes)
# Create a stream in which to copy inputs/outputs between the allocated memory from device and host; and run inference.
stream = cuda.Stream()
return h_input, d_input, h_output, d_output, stream
def load_images_to_buffer(pics, pagelocked_buffer):
This is the function to load (preprocessed) images to buffers in the host
preprocessed = np.asarray(pics).ravel()
np.copyto(pagelocked_buffer, preprocessed)
def load_labels(path, encoding='utf-8'):
"""Loads labels from file (with or without index numbers).
Args:
path: path to label file.
encoding: label file encoding.
Returns:
Dictionary mapping indices to labels.
with open(path, 'r', encoding=encoding) as f:
lines = f.readlines()
if not lines:
return {}
if lines[0].split(' ', maxsplit=1)[0].isdigit():
pairs = [line.split(' ', maxsplit=1) for line in lines]
return {int(index): label.strip() for index, label in pairs}
else:
return {index: line.strip() for index, line in enumerate(lines)}
def load_engine(trt_runtime, plan_path):
This function reads the engine from the file .trt and deserializes it
with open(plan_path, 'rb') as f:
engine_data = f.read()
engine = trt_runtime.deserialize_cuda_engine(engine_data)
return engine
# Modify x in [0:x] to display the numer of desired predictions
def postprocess_inception(output):
predictions_top = np.argsort(output)[::-1][0:1]
labels_top = [labels[p] for p in predictions_top]
scores_top = output[predictions_top]
return scores_top, labels_top
# Loads labels file
labels = load_labels(labels_path)
# Loads model file
engine = load_engine(trt_runtime, plan_path)
# Allocate buffers in CPU and GPU - calling TX2_classify.py (allocate_buffers)
h_input, d_input, h_output, d_output, stream = allocate_buffers(engine, 1, trt.float32)
# Context for executing inference using ICudaEngine
context = engine.create_execution_context()
# Image preprocessing
# Open image, convert each pixel to the triple 8-bit value, change size and apply a high-quality
# downsampling filter. Then it create an array of data type FP32 and normalizes it.
image = np.asarray(Image.open(image_path).convert('RGB').resize(size, Image.ANTIALIAS), dtype=np.float32)
image /= 255
# Load the preprocessed image into the CPU's buffer - calling TX2_classify.py (load_images_to_buffer)
load_images_to_buffer(image, h_input)
# Transfer input data from CPU to GPU.
start_0 = time.perf_counter()
cuda.memcpy_htod_async(d_input, h_input, stream)
time_CPUtoGPU = time.perf_counter() - start_0
print("CPUtoGPU(ms):", (time_CPUtoGPU * 1000))
print("\n")
for i in range (count):
# Run inference.
#context.profiler = trt.Profiler() ##shows execution time(ms) of each layer
start_1 = time.perf_counter()
context.execute(batch_size=1, bindings=[int(d_input), int(d_output)])
inference_time = time.perf_counter() - start_1
print("Inference_time(ms)")
print(inference_time * 1000)
print("\n")
# Transfer predictions back from the GPU to the CPU.
cuda.memcpy_dtoh_async(h_output, d_output, stream)
# Synchronize the stream.
stream.synchronize()
# Return the CPU output.
scores = h_output
pred = postprocess_inception(scores)
print(pred)
print("\n")
