It is said that pgfortran is slower than ifort. The following code is tested:
program main
use omp_lib
double precision a
double precision b
double precision error
double precision exact
external f
double precision f
integer i
integer j
integer n
integer nx
integer ny
double precision pi
double precision total
double precision wtime
double precision x
double precision y
character(len=2) cnp
integer narg,ncore
integer,external :: iargc
narg = iargc()
if(narg>0)then
call getarg(1,cnp)
read(cnp,*) ncore
else
ncore = 1
endif
a = 0.0
b = 1.0
nx = 32768
ny = 32768
n = nx * ny
pi = 3.141592653589793D+00
exact = pi * pi / 6.0D+00
write ( *, '(a)' ) ' '
write ( *, '(a)' ) 'QUAD2D_OPENMP:'
write ( *, '(a)' ) ' FORTRAN90 version'
write ( *, '(a)' ) ' Estimate the integral of f(x,y) over [0,1]x[0,1].'
write ( *, '(a)' ) ' f(x,y) = 1 / ( 1 - x * y ).'
write ( *, * ) ' A = ', a
write ( *, * ) ' B = ', b
write ( *, * ) ' NX = ', nx
write ( *, * ) ' NY = ', ny
write ( *, * ) ' N = ', n
write ( *, * ) ' Exact = ', exact
wtime = omp_get_wtime ( )
call omp_set_num_threads(ncore)
total = 0.0D+00
!$omp parallel shared ( a, b, nx, ny ) private ( i, j, x, y )
!$omp do reduction ( + : total )
do i = 1, nx
x = ( ( 2 * nx - 2 * i + 1 ) * a + ( 2 * i - 1 ) * b ) / ( 2 * nx )
do j = 1, ny
y = ( ( 2 * ny - 2 * j + 1 ) * a + ( 2 * j - 1 ) * b ) / ( 2 * ny )
total = total + f ( x, y )
end do
end do
!$omp end do
!$omp end parallel
wtime = omp_get_wtime ( ) - wtime
total = ( b - a ) * ( b - a ) * total / dble ( nx ) / dble ( ny )
error = abs ( total - exact )
write ( *, * ) ' Estimate = ', total
write ( *, * ) ' Error = ', error
write ( *, * ) ' Time = ', wtime
! Terminate.
write ( *, '(a)' ) 'QUAD2D_OPENMP'
write ( *, '(a)' ) ' Normal end of execution.'
stop
end
function f ( x, y )
implicit none
double precision f
double precision x
double precision y
f = 1.0D+00 / ( 1.0D+00 - x * y )
return
end
When it is compiled by two compilers, the time would be 2,02s and 1.10s respectively for pgi fortran and intel fortran.
So is there any option to make pgi fortran faster?
