why result varied based on different number of threads per block?
I calculated PI with integral. Code is the same, but number of threads per block was different. I found the it was really strange that PI is 3.13903 when I set 256 threads
per block.
Can any one explain why?
Besides, if I changed dimension of blocks1 to (8,2,1), result will be totally wrong. WHY?
the cpu result is:3.14159
time elapsed:16.177
CUDA initialized.
Processing time: 0.732636 (ms)
gpu result is:3.14159
with 32 per thread
Acceleration ratio:22.0805Processing time: 0.486263 (ms)
with 64 per thread
Acceleration ratio:33.268Processing time: 0.397520 (ms)
with 128 per thread
Acceleration ratio:40.6948Processing time: 0.367128 (ms)
gpu result is:3.13903
with 256 per thread
Acceleration ratio:44.0636Processing time: 0.361455 (ms)
with 512 per thread
Acceleration ratio:44.7552Processing time: 0.480590 (ms)
with 1024 per thread
Acceleration ratio:33.6607
here is my code:
*  sample.cu
*  This is a example of the CUDA program.
#include <stdio.h>
#include <stdlib.h>
#include <cutil_inline.h>
#include <iostream>
#include <windows.h>
using namespace std;
/* Init CUDA                                                            */
#if __DEVICE_EMULATION__
bool InitCUDA(void){return true;}
#else
bool InitCUDA(void)
	int count = 0;
	int i = 0;
	cudaGetDeviceCount(&count);
	if(count == 0) {
		fprintf(stderr, "There is no device.\n");
		return false;
	for(i = 0; i < count; i++) {
		cudaDeviceProp prop;
		if(cudaGetDeviceProperties(&prop, i) == cudaSuccess) {
			if(prop.major >= 1) {
				break;
	if(i == count) {
		fprintf(stderr, "There is no device supporting CUDA.\n");
		return false;
	cudaSetDevice(i);
	printf("CUDA initialized.\n");
	return true;
#endif
double cpuPI(int num){
	double sum=0.0f;
	double temp;
	for(int i=0;i<num;i++){
		temp=(i+0.5f)/num;
		//  printf ("%f\n", temp);
		sum+=4/(1+temp*temp);
		//  printf ("%f\n", sum);
	return sum/num;
__global__ void reducePI1 (float *d_sum, int num) {
	int id=blockIdx.x*blockDim.x+threadIdx.x;//线程索引
	int gid=id;
	float temp;
	extern float __shared__ s_pi[];//
	s_pi[threadIdx.x]=0.0f;
	while(gid<num){
		temp=(gid+0.5f)/num;//
		s_pi[threadIdx.x]+=4.0f/(1+temp*temp);
		gid+=blockDim.x*gridDim.x;
	for(int i=(blockDim.x>>1);i>0;i>>=1){
		if(threadIdx.x<i){
			s_pi[threadIdx.x]+=s_pi[threadIdx.x+i];
		__syncthreads(); //
	if(threadIdx.x==0)
		d_sum[blockIdx.x]=s_pi[0];
__global__ void reducePI2(float *d_sum,int num,float *d_pi){
	int id=threadIdx.x;
	extern float __shared__ s_sum[];
	s_sum[id]=d_sum[id];
	__syncthreads();
		if(id<i)
			s_sum[id]+=s_sum[id+i];
		__syncthreads();
	//  printf("%d,%f\n",id,s_sum[id]);
	if(id==0){
		*d_pi=s_sum[0]/num;
		//  printf("%d,%f\n",id,*pi);
int main(int argc, char* argv[])
	DWORD t_S,t_E;
	float t;
	int n=100000;
	t_S=GetTickCount();
	cout<<"the cpu result is:";
	cout<<cpuPI(1000000000)<<endl;;
	t_E=GetTickCount();
	t=t_E-t_S;
	cout<<"time elapsed:"<<(float)t/1000<<endl;
	if(!InitCUDA()) {
		return 0;
	float *d_sum;
	float *d_pi;
	float h_pi=1;
	cudaMalloc(&d_sum,sizeof(float)*4);
	cudaMalloc(&d_pi,sizeof(float));
	int tn=16;
	dim3 threads1(tn,1,1);
	dim3 blocks1(2,2,1);// here to change dimension of blocks1
	dim3 blocks2(1,1,1);
	dim3 threads2(4,1,1);
	//test
	for(tn=32;tn<=1024;tn*=2)
		threads1.x=tn;
		unsigned int timer = 0;
		cutilCheckError( cutCreateTimer( &timer));
		cutilCheckError( cutStartTimer( timer));
		reducePI1<<<blocks1,threads1,sizeof(float)*tn>>>(d_sum,n);
		cutilCheckMsg("PI1 failed\n");
		reducePI2<<<blocks2,threads2,sizeof(float)*4>>>(d_sum,n,d_pi);
		cutilCheckMsg("PI2 failed\n");
		cudaMemcpy(&h_pi,d_pi,sizeof(float),cudaMemcpyDeviceToHost );
		cutilCheckMsg("Memcpy failed\n");
		cudaThreadSynchronize();
		cutilCheckError( cutStopTimer( timer));
		printf("Processing time: %f (ms)\n", cutGetTimerValue( timer));
		cout<<endl;
		cout<<"gpu result is:"<<h_pi<<endl;
		cout<<"with "<<tn<<" per thread"<<"   "<<endl;
		cout<<"Acceleration ratio:"<<(t/1000) / cutGetTimerValue( timer);
		cutilCheckError( cutDeleteTimer( timer));
	cudaFree(d_sum);
	cudaFree(d_pi);
	return 0;
HI
I don’t know if it’s your problem but
I know you can not use share memory variables
as extern, because they have a kernell scope
(see programming manual)
I think too that you could have some sort
of “race condition” in the varialbe s_pi
in this code:
                if(threadIdx.x<i){
and in the variale s_sum in this code:
                if(id<i)
                __syncthreads();
when id is a thread id belonging to a warp
and id+1 is thread id belonging to the following warp.
In this case the pseudo casual order of warp execution
makes that sums inconsistent.
I think you should fix these points.
Rocco
You do not know that, because it is not correct. See Section B.2.3 of the very same CUDA programming guide:
sorry for my forgetfulness, shared memory has
a shorter scope of a thread block but I know what I said:
in this code an array of extern shared memory have no sense
and a simple shared definition is correct and sufficient
its content is not consistent every time
a new thread block (and a new kernel too) is executed
extern shared memory has really sense inside
a device subfunction called by another global function
in the same thread block to share/pass the same data.
so, why does he use “extern”?
Rocco
Read the part of the programming guide I quoted above. Extern declarations of the type you said are illegal allow shared memory allocation size to be determined at run time and not compile time.
Sorry but I’m not sure you understood what I meant
…for me extern shared memory have no sense here
with this code it not possible to understend why he use extern
and so why he have/want to use a dinamic runtime allocation
of shared memory
But the problem here is not the shared memory but a race condition,
as I wrote, so stop talking about shared memory here
I wanted only to warn about the use of extern in shared memory
to avoid inconsistence in data with a possible successive use of
extern shared memory…nothing more
but if you like to write a lot in these forums
here there is my problem :)
http://forums.nvidia.com/index.php?showtopic=193417
any suggestion or confirmation
will be very appreciate
thank you however in advance
Because the kernels are called with different block sizes and the shared memory buffers must be sized accordingly.
Neither of those two pieces of code you mentioned contain a memory race for the execution parameters used in the code. The real reason is the lack of a synchronization barrier in one place in the first kernel call, between the accumulation and shared memory reduction phases of the kernel. If the first kernel is rewritten like this:
        int gid=id;
        float temp;
// Accumulate
        while(gid<num){
// Ensure all accumulation is finished
	__syncthreads();
// parallel reduction
                if(threadIdx.x<i){
                __syncthreads(); //
        if(threadIdx.x==0)
it will work correctly (at least up to the useful accuracy limit of single precision floating point). The reason why it can fail now is because any given warp may begin the parallel reduction while another has yet to finish the accumulation phase of the code.
Which is also total nonsense. In the context of shared memory declarations, extern doesn’t mean what you keep incorrectly asserting it means. It only controls whether shared memory can be allocated at runtime or not. No other behaviour changes occur whether the shared memory is declared extern or not.
I know this, I’m trying to explain that this dynamic use of threads
is not necessary and then …use of dynamic allocation
of shared memory has no sense
With more threads in a block (>128) the algoritm is not faster
because the NVIDIA warp scheduler is really fantastic
and it does not introduce latency stoping and starting warps and blocks
executions on a SM.
Generally using more threads per blocks there are less resources per thread
depends on your algorithm
maybe you dont know but this condition you are describing is called “race condition” :)
and your code here is missing at least of one __syncthread() :)
…it is really correct but…
…behaviour changes using extern shared memory erroneously
such as … sharing data between blocks
only for this reason I wrote my warning although this is not
the correct situation.
As you know, in C/C++, extern declaration is used exactly for sharing
data e.g. between functions and threads in multithread developing environment
I’m asking why our friend facat has not replied yet… :)
…did you read my post about a texture problem?? :)
I see. If I look at this simplified version of the original posters code:
#include <cmath>
#include <iostream>
double cpuPI(long num)
    double sum=0.0f;
#pragma omp parallel
#pragma omp for reduction(+:sum)
        for(long i=0;i<num;i++){
            double temp = (double(i) + 0.5)/double(num);
            sum+= 4./(1.+temp*temp);
    return sum/num;
extern float __shared__ buffer[];
__global__ void reducePI1 (float *d_sum, long num)
    volatile float * s_pi = &buffer[threadIdx.x];
    long gid=blockIdx.x*blockDim.x+threadIdx.x;
    long stride = blockDim.x * gridDim.x;
    *s_pi = 0.f;
    while(gid<num){
        float temp=(gid+0.5f)/float(num);
        *s_pi += 4.0f / (1.f + temp*temp);
        gid += stride;
    __syncthreads();
        if(threadIdx.x<i) *s_pi += *(s_pi + i);
        __syncthreads();
    if(threadIdx.x==0)
        d_sum[blockIdx.x + gridDim.x * blockIdx.y] = *s_pi;
__global__ void reducePI2(float *d_sum,long num,float *d_pi){
    volatile float *s_sum = &buffer[threadIdx.x];
    int id=threadIdx.x;
    *s_sum =d_sum[id];
    __syncthreads();
        if(id<i) *s_sum += *(s_sum+i);
        __syncthreads();
    if(id==0)
        *d_pi = *s_sum/float(num);
    const long n=8000000l;
    double h_pi_ref = cpuPI(n);
    cout.precision(10);
    cout<<"For n="<<n<<endl;
    cout<< "CPU result is "<<h_pi_ref<<endl;
float *d_sum, *d_pi;
    dim3 blocks1(4,1,1), blocks2(1,1,1);
    cudaMalloc(&d_sum,sizeof(float)*size_t(blocks1.x));
cout << "blocks = " << blocks1.x << endl;
    for(int tn=32;tn<=1024;tn*=2) {
        float h_pi = 0.f;
        dim3 threads1 = dim3(tn,1,1), threads2 = blocks1;
        reducePI2<<<blocks2,threads2,sizeof(float)*size_t(threads2.x)>>>(d_sum,n,d_pi);
double relerr = fabs(h_pi_ref-h_pi) / h_pi_ref;
        cout<<"threads = "<<tn<<", gpu result = "<<h_pi;
        cout<<", relative error = "<<relerr<<endl;
return (int)cudaThreadExit();
which does this when compiled and run:
avidday@cuda:~$ nvcc -arch=sm_20 -Xptxas="-v" -Xcompiler="-O3 -fopenmp" samplePI.cu -o samplePI.exe
ptxas info    : Compiling entry function '_Z9reducePI2PflS_' for 'sm_20'
ptxas info    : Used 11 registers, 56 bytes cmem[0], 4 bytes cmem[16]
ptxas info    : Compiling entry function '_Z9reducePI1Pfl' for 'sm_20'
ptxas info    : Used 22 registers, 48 bytes cmem[0], 4 bytes cmem[16]
avidday@cuda:~$ OMP_NUM_THREADS=4 ./samplePI.exe
For n=8000000
CPU result is 3.141592654
blocks = 4
threads = 32, gpu result = 3.141587973, relative error = 1.489992282e-06
threads = 64, gpu result = 3.141591787, relative error = 2.757364295e-07
threads = 128, gpu result = 3.141592026, relative error = 1.998454387e-07
threads = 256, gpu result = 3.141592503, relative error = 4.806345714e-08
threads = 512, gpu result = 3.141592503, relative error = 4.806345714e-08
threads = 1024, gpu result = 3.141592503, relative error = 4.806345714e-08
and which the visual profiler tells me takes this long on a GTX470
Kernel          GPU time	BlockDim.x
reducePI1	66673.2		32
reducePI1	33338.3		64
reducePI1	16671.9		128
reducePI1	8616.7		256
reducePI1	5386.37		512
reducePI1	4960.54		1024
I am left somewhat confused. I would greatly appreciate it if you could point out the errors in the code, because clearly I have gaps in my understanding of how CUDA actually works. If I have understood your analysis of the code posted in this thread correctly, the following all should apply:
    [*]The parallel shared memory reductions of each kernel contain memory races
    [*]The first kernel requires an additional syncthreads() call to function correctly
    [*]The use of externally declared shared memory is either illegal or somehow dangerous and unnecessary in this example
    [*]Increasing the thread count per block beyond 128 should make no difference to kernel performance in this case.
but for some reason the output appears to contradict all of those points. What am I doing wrong?
