I don’t get any difference in output whether I run with or without __syncthreads();
The output is always this:
dgg: inf, gg: 413284564992.000000
So I see no evidence of your claim that __syncthreads() makes a difference.
When I use this modified version of your file:
$ cat main.cu
#include<stdio.h>
#include <assert.h>
#include <math.h>
#define gpuErrchk(ans) { gpuAssert((ans), __FILE__, __LINE__); }
inline void gpuAssert(cudaError_t code, const char *file, int line, bool abort=true)
if (code != cudaSuccess)
fprintf(stderr,"GPUassert: %s %s %d\n", cudaGetErrorString(code), file, line);
if (abort) exit(code);
__host__ long NearestPowerOf2(long n)
if (!n) return n; //(0 == 2^0)
int x = 1;
while(x < n)
x <<= 1;
return x;
bool isPow2(unsigned int x)
return ((x&(x-1))==0);
__global__ void getGGandDGG(float *gg, float *dgg, float3 *xi, float3 *g, long N)
int j = threadIdx.x + blockDim.x * blockIdx.x;
int i = threadIdx.y + blockDim.y * blockIdx.y;
float gg_T, gg_tau, gg_beta;
float dgg_T, dgg_tau, dgg_beta;
gg_T = g[N*i+j].x * g[N*i+j].x;
gg_tau = g[N*i+j].y * g[N*i+j].y;
gg_beta = g[N*i+j].z * g[N*i+j].z;
dgg_T = (xi[N*i+j].x + g[N*i+j].x) * xi[N*i+j].x;
dgg_tau = (xi[N*i+j].y + g[N*i+j].y) * xi[N*i+j].y;
dgg_beta = (xi[N*i+j].z + g[N*i+j].z) * xi[N*i+j].z;
__syncthreads();
/*if(i==252 && j == 327){
printf("ggs T: %f, tau: %f, beta: %f\n", gg_T, gg_tau, gg_beta);
printf("dggs T: %f, tau: %f, beta: %f\n", dgg_T, dgg_tau, dgg_beta);
gg[N*i+j] = gg_T + gg_tau + gg_beta;
if (__isinf(gg[N*i+j])) {assert(0);};
dgg[N*i+j] = dgg_T + dgg_tau + dgg_beta;
if (__isinf(dgg[N*i+j])) {assert(0);};
template <bool nIsPow2>
__global__ void deviceReduceKernel(float *g_idata, float *g_odata, unsigned int n)
extern __shared__ float sdata[];
// perform first level of reduction,
// reading from global memory, writing to shared memory
unsigned int tid = threadIdx.x;
unsigned int blockSize = blockDim.x;
unsigned int i = blockIdx.x*blockSize*2 + threadIdx.x;
unsigned int gridSize = blockSize*2*gridDim.x;
float mySum = 0.f;
// we reduce multiple elements per thread. The number is determined by the
// number of active thread blocks (via gridDim). More blocks will result
// in a larger gridSize and therefore fewer elements per thread
while (i < n)
mySum += g_idata[i];
// ensure we don't read out of bounds -- this is optimized away for powerOf2 sized arrays
if (nIsPow2 || i + blockSize < n)
mySum += g_idata[i+blockSize];
i += gridSize;
// each thread puts its local sum into shared memory
sdata[tid] = mySum;
__syncthreads();
// do reduction in shared mem
if ((blockSize >= 512) && (tid < 256))
sdata[tid] = mySum = mySum + sdata[tid + 256];
__syncthreads();
if ((blockSize >= 256) &&(tid < 128))
sdata[tid] = mySum = mySum + sdata[tid + 128];
__syncthreads();
if ((blockSize >= 128) && (tid < 64))
sdata[tid] = mySum = mySum + sdata[tid + 64];
__syncthreads();
#if (__CUDA_ARCH__ >= 300 )
if ( tid < 32 )
// Fetch final intermediate sum from 2nd warp
if (blockSize >= 64) mySum += sdata[tid + 32];
// Reduce final warp using shuffle
for (int offset = warpSize/2; offset > 0; offset /= 2)
mySum += __shfl_down(mySum, offset);
#else
// fully unroll reduction within a single warp
if ((blockSize >= 64) && (tid < 32))
sdata[tid] = mySum = mySum + sdata[tid + 32];
__syncthreads();
if ((blockSize >= 32) && (tid < 16))
sdata[tid] = mySum = mySum + sdata[tid + 16];
__syncthreads();
if ((blockSize >= 16) && (tid < 8))
sdata[tid] = mySum = mySum + sdata[tid + 8];
__syncthreads();
if ((blockSize >= 8) && (tid < 4))
sdata[tid] = mySum = mySum + sdata[tid + 4];
__syncthreads();
if ((blockSize >= 4) && (tid < 2))
sdata[tid] = mySum = mySum + sdata[tid + 2];
__syncthreads();
if ((blockSize >= 2) && ( tid < 1))
sdata[tid] = mySum = mySum + sdata[tid + 1];
__syncthreads();
#endif
// write result for this block to global mem
if (tid == 0) g_odata[blockIdx.x] = mySum;
__host__ float deviceReduce(float *in, long N)
float *device_out;
gpuErrchk(cudaMalloc(&device_out, sizeof(float)*1024));
gpuErrchk(cudaMemset(device_out, 0, sizeof(float)*1024));
int threads = 512;
int blocks = min((int(NearestPowerOf2(N)) + threads - 1) / threads, 1024);
int smemSize = (threads <= 32) ? 2 * threads * sizeof(float) : threads * sizeof(float);
bool isPower2 = isPow2(N);
if(isPower2){
deviceReduceKernel<true><<<blocks, threads, smemSize>>>(in, device_out, N);
gpuErrchk(cudaDeviceSynchronize());
}else{
deviceReduceKernel<false><<<blocks, threads, smemSize>>>(in, device_out, N);
float *h_odata = (float *) malloc(blocks*sizeof(float));
float sum = 0.0;
gpuErrchk(cudaMemcpy(h_odata, device_out, blocks * sizeof(float),cudaMemcpyDeviceToHost));
for (int i=0; i<blocks; i++)
sum += h_odata[i];
cudaFree(device_out);
free(h_odata);
return sum;
__host__ int main(int argc, char **argv) {
long M = 512;
long N = 512;
float *host_xi_T, *host_xi_tau, *host_xi_beta;
float *host_g_T, *host_g_tau, *host_g_beta;
host_xi_T = (float*)malloc(M*N*sizeof(float));
host_xi_tau = (float*)malloc(M*N*sizeof(float));
host_xi_beta = (float*)malloc(M*N*sizeof(float));
host_g_T = (float*)malloc(M*N*sizeof(float));
host_g_tau = (float*)malloc(M*N*sizeof(float));
host_g_beta = (float*)malloc(M*N*sizeof(float));
FILE *fp_xi_T = NULL;
FILE *fp_xi_tau = NULL;
FILE *fp_xi_beta = NULL;
FILE *fp_g_T = NULL;
FILE *fp_g_tau = NULL;
FILE *fp_g_beta = NULL;
fp_xi_T=fopen("xi_T.raw", "r");
fp_xi_tau=fopen("xi_tau.raw", "r");
fp_xi_beta=fopen("xi_beta.raw", "r");
fp_g_T=fopen("g_T.raw", "r");
fp_g_tau=fopen("g_tau.raw", "r");
fp_g_beta=fopen("g_beta.raw", "r");
fread(host_xi_T, sizeof(float), M*N, fp_xi_T);
fread(host_xi_tau, sizeof(float), M*N, fp_xi_tau);
fread(host_xi_beta, sizeof(float), M*N, fp_xi_beta);
fread(host_g_T, sizeof(float), M*N, fp_g_T);
fread(host_g_tau, sizeof(float), M*N, fp_g_tau);
fread(host_g_beta, sizeof(float), M*N, fp_g_beta);
float3 *host_xi = (float3*)malloc(M*N*sizeof(float3));
float3 *host_g = (float3*)malloc(M*N*sizeof(float3));
for(int m=0;m<M*N;m++){
host_xi[m].x = host_xi_T[m];
assert(!isinf(host_xi[m].x));
host_xi[m].y = host_xi_tau[m];
assert(!isinf(host_xi[m].y));
host_xi[m].z = host_xi_beta[m];
assert(!isinf(host_xi[m].z));
host_g[m].x = host_g_T[m];
assert(!isinf(host_g[m].x));
host_g[m].y = host_g_tau[m];
assert(!isinf(host_g[m].y));
host_g[m].z = host_g_beta[m];
assert(!isinf(host_g[m].z));
fclose(fp_xi_T);
fclose(fp_xi_tau);
fclose(fp_xi_beta);
fclose(fp_g_T);
fclose(fp_g_tau);
fclose(fp_g_beta);
free(host_xi_T);
free(host_xi_tau);
free(host_xi_beta);
free(host_g_T);
free(host_g_tau);
free(host_g_beta);
float3 *device_g, *xi;
gpuErrchk(cudaMalloc((void**)&device_g, sizeof(float3)*M*N));
gpuErrchk(cudaMemset(device_g, 0, sizeof(float3)*M*N));
gpuErrchk(cudaMalloc((void**)&xi, sizeof(float3)*M*N));
gpuErrchk(cudaMemset(xi, 0, sizeof(float3)*M*N));
gpuErrchk(cudaMemcpy2D(xi, sizeof(float3), host_xi, sizeof(float3), sizeof(float3), M*N, cudaMemcpyHostToDevice));
gpuErrchk(cudaMemcpy2D(device_g, sizeof(float3), host_g, sizeof(float3), sizeof(float3), M*N, cudaMemcpyHostToDevice));
///////////////////vectors for gg and dgg////////////////////
float *device_gg_vector, *device_dgg_vector;
//////////////////////////////////GPU MEMORY///////////////
gpuErrchk(cudaMalloc((void**)&device_gg_vector, sizeof(float)*M*N));
gpuErrchk(cudaMemset(device_gg_vector, 0, sizeof(float)*M*N));
gpuErrchk(cudaMalloc((void**)&device_dgg_vector, sizeof(float)*M*N));
gpuErrchk(cudaMemset(device_dgg_vector, 0, sizeof(float)*M*N));
dim3 threadsPerBlockNN(16, 16);
dim3 numBlocksNN(M/16, N/16);
float gg, dgg;
dgg = gg = 0.0;
getGGandDGG<<<numBlocksNN, threadsPerBlockNN>>>(device_gg_vector, device_dgg_vector, xi, device_g, N);
gg = deviceReduce(device_gg_vector, M*N);
dgg = deviceReduce(device_dgg_vector, M*N);
printf("dgg: %f, gg: %f\n", dgg, gg);
I get this output:
$ nvcc -o main main.cu
nvcc warning : The 'compute_20', 'sm_20', and 'sm_21' architectures are deprecated, and may be removed in a future release (Use -Wno-deprecated-gpu-targets to suppress warning).
$ ./main
main: main.cu:259: int main(int, char**): Assertion `!isinf(host_xi[m].y)' failed.
Aborted (core dumped)
So you are reading in an inf value from one of your raw data files, and that inf value is propagating thru to the output.
