Why Turboquant saves DGX twice
hey thank you for the work,
Can you please tell me how much context token you inject during the benchtest ?
That’s very cool. I wonder what 24h of this would do for us and how we could best integrate the result in the vLLM ecosystem
8k, 32k, 64k, 128k. Tokenrate decreases. There is a result.md in the repos.
Honestly, we’re already happy if we find any CUDA kernel path for SM12x that actually runs. I also think that this “fallback” to Triton or Python is far too invisible to the average user. Attention is forced through FlashInfer by vLLM — whatever FlashInfer can’t do simply doesn’t work. Take INT4 AutoRound: you need the model (or MultiQuant with iter=0 loading) and can only run it sensibly on Marlin.
vLLM already has some kind of “autotuner” built in — which is frankly terrifying. Way too much “auto”. The autotuner assumes a meaningful candidate space of kernels to tune over. On SM12x, that space is often reduced to a single Triton fallback — or no native path at all. The autotuner then confidently selects the “best” option from a set of one, giving users false assurance that the system is properly optimized.
Triton generates PTX, which is then compiled to the concrete SM architecture via the LLVM backend path. For SM12x this means: Triton can generate kernels that run — but Triton has no native knowledge of SM12x-specific MMA tile sizes, shared memory layout, or warp scheduling. The generated code is functionally correct but not optimal — possibly significantly worse than handwritten CUDA. For simple ops (elementwise, reduction, dequant kernels) this is acceptable — Triton can utilize SM12x reasonably well there. For matmul and attention it hits the same wall as FlashInfer: without explicit MMA instructions targeting SM12x, you stay suboptimal regardless of what the autotuner reports.
Weight Quantization: Back to Basics with AutoRound
Up front: Weight quantization using the TQ/RQ solutions does not produce usable results. Therefore, back to the roots — Intel AutoRound. The iter=0 approach is built in as on-the-fly quantization. First measurements on GLM models show:
Calibrated vs RTN (on-the-fly):
RTN (iters=0) Calibrated (iters=200) Δ
INT2 0.53 0.56 +0.03
INT3 0.80 0.82 +0.02
INT4 0.94 (Reference)
Calibration improves only marginally (+0.02–0.03). This is disappointing — at INT2, cos=0.56 is probably still insufficient for usable inference.
The good news: quant-at-load — quantize BF16 → INT3/INT4 on load — holds its own.
And yes, the numbers show: RTN (iters=0) vs calibrated (iters=1000) is surprisingly close:
RTN (on-the-fly) Calibrated (best) Δ
INT3 Weight cos 0.810 0.820 +0.010
INT3 Logit cos 0.9995 0.9999 +0.0004
INT2 Weight cos 0.562 0.566 +0.004
The 1000 iterations of calibration (autoround best) only yield +1% weight cos for INT3 and virtually nothing for logit cos. This means RTN quant-at-load for INT3/INT4 is a valid approach — especially on DGX Spark where RAM is tight:
  • No AutoRound run needed
  • No second model on disk
  • Load BF16 → quantize on the fly → INT3 in GPU RAM → fused GEMM kernel dequantizes only inside the GEMM
Saves disk, saves calibration time, and quality is nearly identical.
Not sure about this PR, but does it means the turboquant is supported in vllm?
[Attention Backend] TurboQuant: 2-bit KV cache compression with 4x capacity by vibhavagarwal5 · Pull Request #38479 · vllm-project/vllm
There are many TQ implementations. TQ itself is straightforward — the only real constraint is the dimension. >64 you need a blockwise tq or a rotation. When it’s a power of two, you can swap the dense rotation for a fast WHT.
Just leaving this here in case you havent seen this Introduce PrismQuant :)
Im just deep in xfp. So thanx for collecting new approaches. It looks like there’s still headroom.
TurboQuant makes a DGX system more efficient in two simple ways. It uses much less memory, so you can run more work without worrying about space, and it also reduces how much data needs to move around, which helps things run faster. That’s why people say it saves DGX twice, you get both more room and better speed at the same time.
Yes — but we keep questioning, because everything has its price, and accuracy matters even more for KV. The literature is clear that TQ by itself isn’t useful; it has to be managed. That’s what the TQ implementations do: either windowed TurboQuant or paired with a trick like WHT, so the statistical accuracy comes close to meeting the requirement.
hey @flash3 , how’s the xfp going?
very good. just fighting with vision encoder and some special vllm stuff. models 122b and smaller should work properly. default cos is 0.98. resulting bit efficiency is between 3 and 4. model dependend. speed is 17% faster than marlins int4 autoround. tested + developed on dgx, tested also on rtx
Any news?
I started to use –kv-cache-dtype turboquant_k8v4 with fp8 models, vllm pr claims it has less quality loss than kv-tupe fp8 without performance penalty, but qwen mtp is broken with this combination.
This looks like the vLLM TurboQuant implementation. It’s not TQ4W or TQ3W of my MultiQuant.
I still don’t have it upstream on head.
MultiQuant is still available via GitHub - flash7777/vllm at multiquant · GitHub.
v2a runs on qwen 3.5 and qwen 3.6 models, I’m just migrating to vllm 0.2x to support deepseek v4 too.
Measurements on dgx
Metric XFP v1 (attn-only quant) Marlin INT4 AutoRound XFP v2 (+linear_attn quant) Best / Baseline XFP
long (400 tok) 17.3 tok/s 25.8 tok/s 29.9 tok/s 1.73×
medium (150 tok) 18.9 tok/s 29.6 tok/s 34.8 tok/s 1.84×
short (20 tok) 2.5 tok/s 2.5 tok/s 2.6 tok/s ~1× (latency-bound)
Math accuracy 98 % 94 % 98 % unchanged
LM head fp8 E4M3 fp8 E4M3 fp8 E4M3 same
KV cache fp8 fp8 fp8 same
XFP v2 beats Marlin by +16 % long / +18 % medium AND has +4 pp math.
GSM8K Quality (n=50, seed=0, ±stderr)
Model BF16 baseline XFP-V2a Δ
Qwen 3.5 35B-A3B 76.02% (full, 3 seeds) 76.0% ±6.1 within stderr
Qwen 3.5 122B-A10B n/a (>1 GPU for BF16) 98.0% ±2.0 (V2 ref full: 94.62%)
Qwen 3.6 27B (dense) 64.0% ±6.86 58.0% ±7.05 -6 pp within stderr
GLM-4.7-Flash 68.0% ±6.66 76.0% ±6.1 +8 pp (n=50 seed noise)
UPDATE:
All measurements w/o mtp or drafters.
