Why using -g -G, the code will be blocked?
I am learning cutlass and I am compiling using command below:
nvcc -o sgemm_nt_1 sgemm_nt_1.cu -arch=sm_80 -std=c++17 -I ../cutlass/include -I ../cutlass/tools/util/include --expt-relaxed-constexpr -g -G
The code is : here like below:
So when I use command with -g -G, it will be blocked like:
~/temp_can$ ./sgemm_nt_1
Using device 0: NVIDIA A100 80GB PCIe  (SM80, 108 SMs)
M = 5120
N = 5120
K = 4096
Verification by comparison with cuBLAS is disabled, either because the CMake option CUTLASS_ENABLE_CUBLAS was explicitly set to OFF, or because CMake could not find cuBLAS.  If you would like to enable verification with cuBLAS, please set the CMake option CUTLASS_ENABLE_CUBLAS to ON, rerun CMake, and recompile this example.
^C
If it is without -g -G, it will be:
M = 5120
N = 5120
K = 4096
CUTE_GEMM:     [7017.5]GFlop/s  (30.6016)ms
Why? Simply because -g -G will result in a very big output file?
 * Copyright (c) 2023 - 2023 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
 * SPDX-License-Identifier: BSD-3-Clause
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice, this
 * list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright notice,
 * this list of conditions and the following disclaimer in the documentation
 * and/or other materials provided with the distribution.
 * 3. Neither the name of the copyright holder nor the names of its
 * contributors may be used to endorse or promote products derived from
 * this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
 * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
 * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <thrust/host_vector.h>
#include <thrust/device_vector.h>
#include <cute/tensor.hpp>
#include "cutlass/util/print_error.hpp"
#include "cutlass/util/GPU_Clock.hpp"
#if defined(CUTLASS_ENABLE_CUBLAS) && CUTLASS_ENABLE_CUBLAS != 0
#  include "cutlass/util/cublas_wrappers.hpp"
#endif
#include "cutlass/util/helper_cuda.hpp"
template <class MShape, class NShape, class KShape,
          class TA, class AStride, class ABlockLayout, class AThreadLayout,
          class TB, class BStride, class BBlockLayout, class BThreadLayout,
          class TC, class CStride, class CBlockLayout, class CThreadLayout,
          class Alpha, class Beta>
__global__ static
__launch_bounds__(decltype(size(CThreadLayout{}))::value)
void
gemm_device(MShape M, NShape N, KShape K,
            TA const* A, AStride dA, ABlockLayout blockA, AThreadLayout tA,
            TB const* B, BStride dB, BBlockLayout blockB, BThreadLayout tB,
            TC      * C, CStride dC, CBlockLayout       , CThreadLayout tC,
            Alpha alpha, Beta beta)
  using namespace cute;
  using X = Underscore;
  // Preconditions
  CUTE_STATIC_ASSERT(is_static<ABlockLayout>::value);
  CUTE_STATIC_ASSERT(is_static<BBlockLayout>::value);
  CUTE_STATIC_ASSERT(is_static<CBlockLayout>::value);
  CUTE_STATIC_ASSERT(is_static<AThreadLayout>::value);
  CUTE_STATIC_ASSERT(is_static<BThreadLayout>::value);
  CUTE_STATIC_ASSERT(is_static<CThreadLayout>::value);
  CUTE_STATIC_ASSERT_V(size(tA) == size(tC));
  CUTE_STATIC_ASSERT_V(size(tB) == size(tC));
  //CUTE_STATIC_ASSERT_V(shape<0>(blockA) == shape<0>(blockC));      // BLK_M
  //CUTE_STATIC_ASSERT_V(shape<0>(blockB) == shape<1>(blockC));      // BLK_N
  CUTE_STATIC_ASSERT_V(shape<1>(blockA) == shape<1>(blockB));        // BLK_K
  // Shared memory buffers
  __shared__ TA smemA[cosize_v<ABlockLayout>];
  __shared__ TB smemB[cosize_v<BBlockLayout>];
  auto sA = make_tensor(make_smem_ptr(smemA), blockA);               // (BLK_M,BLK_K)
  auto sB = make_tensor(make_smem_ptr(smemB), blockB);               // (BLK_N,BLK_K)
  // Represent the full tensors
  auto mA = make_tensor(make_gmem_ptr(A), make_shape(M,K), dA);      // (M,K)
  auto mB = make_tensor(make_gmem_ptr(B), make_shape(N,K), dB);      // (N,K)
  auto mC = make_tensor(make_gmem_ptr(C), make_shape(M,N), dC);      // (M,N)
  // Get the appropriate blocks for this thread block --
  // potential for thread block locality
  auto blk_shape = make_shape(size<0>(sA), size<0>(sB), size<1>(sB));// (BLK_M,BLK_N,BLK_K)
  auto blk_coord = make_coord(blockIdx.x, blockIdx.y, _);            // (m,n,k)
  auto gA = local_tile(mA, blk_shape, blk_coord, Step<_1, X,_1>{});  // (BLK_M,BLK_K,k)
  auto gB = local_tile(mB, blk_shape, blk_coord, Step< X,_1,_1>{});  // (BLK_N,BLK_K,k)
  auto gC = local_tile(mC, blk_shape, blk_coord, Step<_1,_1, X>{});  // (BLK_M,BLK_N)
  // Partition the copying of A and B tiles across the threads
  // TUTORIAL: Example of simple partitioning of A|B tiles over tA|tB
  //   Default is a raked partition, but can be changed with Step<X,Y> parameter
  auto tAgA = local_partition(gA, tA, threadIdx.x);                  // (THR_M,THR_K,k)
  auto tAsA = local_partition(sA, tA, threadIdx.x);                  // (THR_M,THR_K)
  auto tBgB = local_partition(gB, tB, threadIdx.x);                  // (THR_N,THR_K,k)
  auto tBsB = local_partition(sB, tB, threadIdx.x);                  // (THR_N,THR_K)
  // Define C accumulators and A/B partitioning
  // TUTORIAL: Example of partitioning via projections of tC
  // Partition sA (M,K) by the rows of tC
  auto tCsA = local_partition(sA, tC, threadIdx.x, Step<_1, X>{});   // (THR_M,BLK_K)
  // Partition sB (N,K) by the cols of tC
  auto tCsB = local_partition(sB, tC, threadIdx.x, Step< X,_1>{});   // (THR_N,BLK_K)
  // Partition gC (M,N) by the tile of tC
  auto tCgC = local_partition(gC, tC, threadIdx.x, Step<_1,_1>{});   // (THR_M,THR_N)
  // Allocate the accumulators -- same size as the projected data
  auto tCrC = make_fragment_like(tCgC);                              // (THR_M,THR_N)
  // Clear the accumulators
  clear(tCrC);
#if 0
  if(thread0()) {
    print("mA\n");
    print(mA.shape()); print("\n"); print(mA.stride());
    print("\n\ngA\n");
    print(gA.shape()); print("\n"); print(gA.stride());
    print("\n\ntAgA\n");
    print(tAgA.shape()); print("\n"); print(tAgA.stride());
    print("\n\nsA\n");
    print(sA.shape()); print("\n"); print(sA.stride());
    print("\n\ntAsA\n");
    print(tAsA.shape()); print("\n"); print(tAsA.stride());
    print("\n\n");
#endif
#if 0
  if(thread0()) {
    print("mB\n");
    print(mB.shape()); print("\n"); print(mB.stride());
    print("\n\ngB\n");
    print(gB.shape()); print("\n"); print(gB.stride());
    print("\n\ntBgB\n");
    print(tBgB.shape()); print("\n"); print(tBgB.stride());
    print("\n\nsB\n");
    print(sB.shape()); print("\n"); print(sB.stride());
    print("\n\ntBsB\n");
    print(tBsB.shape()); print("\n"); print(tBsB.stride());
    print("\n\n");
#endif
#if 0
  if(thread0()) {
    print("mC\n");
    print(mC.shape()); print("\n"); print(mC.stride());
    print("\n\ngC\n");
    print(gC.shape()); print("\n"); print(gC.stride());
    print("\n\ntCsA\n");
    print(tCsA.shape()); print("\n"); print(tCsA.stride());
    print("\n\ntCsB\n");
    print(tCsB.shape()); print("\n"); print(tCsB.stride());
    print("\n\ntCgC\n");
    print(tCgC.shape()); print("\n"); print(tCgC.stride());
    print("\n\ntCrC\n");
    print(tCrC.shape()); print("\n"); print(tCrC.stride());
    print("\n\n");
#endif
#if 1
  // TUTORIAL: Example of a very simple compute loop
  //   Data is read from global to shared memory via the tA|tB partitioning
  //   gemm(.) operates on the shared memory directly via the tC partitioning
  auto k_max = size<2>(tAgA);
  for (int k = 0; k < k_max; ++k)
    // Copy gmem to smem
    copy(tAgA(_,_,k), tAsA);
    copy(tBgB(_,_,k), tBsB);
    // In case copy uses cp.async, make sure that the cp.async
    // instructions are ordered with respect to other cp.async
    // instructions (fence), then wait on all the outstanding copy
    // operations (wait<0>()).  __syncthreads() alone does not do
    // this.
    // NOTE: cp_async_wait<0>() currently issues cp.async.wait_all.
    // This is equivalent to cp.async.commit_group followed by
    // cp.async_wait_group 0.  This should make the first
    // cp_async_fence() (which also issues cp.async.commit_group)
    // redundant.  The tutorial works as-is, so we'll leave the
    // redundant fence in for now and study its removal later.
    cp_async_fence();
    cp_async_wait<0>();
    __syncthreads();
    // Compute gemm on smem
    gemm(tCsA, tCsB, tCrC);
    __syncthreads();
#endif
  // Epilogue
  axpby(alpha, tCrC, beta, tCgC);
template <typename TA, typename TB, typename TC,
          typename Alpha, typename Beta>
void
gemm(int m, int n, int k,
     Alpha alpha,
     TA const* A, int ldA,
     TB const* B, int ldB,
     Beta beta,
     TC      * C, int ldC,
     cudaStream_t stream = 0)
  // Define shapes (dynamic)
  auto M = int(m);
  auto N = int(n);
  auto K = int(k);
  // Define strides (mixed)
  auto dA = make_stride(Int<1>{}, ldA);
  auto dB = make_stride(Int<1>{}, ldB);
  auto dC = make_stride(Int<1>{}, ldC);
  // Define block sizes (static)
  auto bM = Int<128>{};
  auto bN = Int<128>{};
  auto bK = Int<  8>{};
  // Define the block layouts (static)
  auto sA = make_layout(make_shape(bM,bK));
  auto sB = make_layout(make_shape(bN,bK));
  auto sC = make_layout(make_shape(bM,bN));
  // Define the thread layouts (static)
  auto tA = make_layout(make_shape(Int<32>{}, Int< 8>{}));
  auto tB = make_layout(make_shape(Int<32>{}, Int< 8>{}));
  auto tC = make_layout(make_shape(Int<16>{}, Int<16>{}));
  dim3 dimBlock(size(tC));
  dim3 dimGrid(ceil_div(size(M), size(bM)),
               ceil_div(size(N), size(bN)));
  gemm_device
      <<< dimGrid, dimBlock, 0, stream >>>
      (M,  N,  K,
       A, dA, sA, tA,
       B, dB, sB, tB,
       C, dC, sC, tC,
       alpha, beta);
#include <cstdlib>
#include <cstdio>
#include <cassert>
void test_gemm(int m, int n, int k)
  cute::device_init(0);
  std::cout << "M = " << m << std::endl;
  std::cout << "N = " << n << std::endl;
  std::cout << "K = " << k << std::endl;
  using TA = float;
  using TB = float;
  using TC = float;
  using TI = float;
  thrust::host_vector<TA> h_A(m*k);
  thrust::host_vector<TB> h_B(n*k);
  thrust::host_vector<TC> h_C(m*n);
  for (int j = 0; j < m*k; ++j) h_A[j] = static_cast<TA>( 2*(rand() / double(RAND_MAX)) - 1 );
  for (int j = 0; j < n*k; ++j) h_B[j] = static_cast<TB>( 2*(rand() / double(RAND_MAX)) - 1 );
  for (int j = 0; j < m*n; ++j) h_C[j] = static_cast<TC>(-1);
  thrust::device_vector<TA> d_A = h_A;
  thrust::device_vector<TB> d_B = h_B;
  thrust::device_vector<TC> d_C = h_C;
  TI alpha = 1.0;
  TI beta  = 0.0;
  double gflops = (2.0*m*n*k) * 1e-9;
  const int timing_iterations = 100;
  GPU_Clock timer;
  // cuBLas
  cublasHandle_t handle;
  cublasCreate(&handle);
  // Run once
  d_C = h_C;
  blam::cublas::gemm(handle, CUBLAS_OP_N, CUBLAS_OP_T,
                     m, n, k,
                     &alpha,
                     d_A.data().get(), m,
                     d_B.data().get(), n,
                     &beta,
                     d_C.data().get(), m);
  CUTE_CHECK_LAST();
  thrust::host_vector<TC> cublas_result = d_C;
  // Timing iterations
  timer.start();
  for (int i = 0; i < timing_iterations; ++i) {
                       m, n, k,
                       &alpha,
                       &beta,
  double cublas_time = timer.seconds() / timing_iterations;
  CUTE_CHECK_LAST();
  printf("CUBLAS_GEMM:   [%6.1f]GFlop/s  (%6.4f)ms\n", gflops / cublas_time, cublas_time*1000);
#else
  std::cout << "Verification by comparison with cuBLAS is disabled, "
    "either because the CMake option CUTLASS_ENABLE_CUBLAS "
    "was explicitly set to OFF, or because CMake could not find cuBLAS.  "
    "If you would like to enable verification with cuBLAS, "
    "please set the CMake option CUTLASS_ENABLE_CUBLAS to ON, "
    "rerun CMake, and recompile this example.\n";
#endif // CUTLASS_ENABLE_CUBLAS
  // CuTe
  // Run once (and check)
  d_C = h_C;
  gemm(m, n, k,
       alpha,
       beta,
  CUTE_CHECK_LAST();
  thrust::host_vector<TC> cute_result = d_C;
  timer.start();
    gemm(m, n, k,
         alpha,
         beta,
  double cute_time = timer.seconds() / timing_iterations;
  CUTE_CHECK_LAST();
  printf("CUTE_GEMM:     [%6.1f]GFlop/s  (%6.4f)ms\n", gflops / cute_time, cute_time*1000);
  printf("Empirical Perf: %.1f%%\n", (cublas_time / cute_time) * 100);
  auto host_matrix_to_const_column_major_cute_tensor =
    [](const auto& X, int num_rows, int num_cols, int LDX) {
      const auto shape = cute::Shape<int, int>{num_rows, num_cols};
      const auto strides = cute::Stride<int, int>{1, LDX};
      return cute::make_tensor(X.data(), cute::make_layout(shape, strides));
  const auto A_view = host_matrix_to_const_column_major_cute_tensor(h_A, m, k, m);
  // B^T is k x n, so B is n x k.
  const auto B_view = host_matrix_to_const_column_major_cute_tensor(h_B, n, k, n);
  const auto C_computed_view = host_matrix_to_const_column_major_cute_tensor(cute_result, m, n, m);
  const auto C_expected_view = host_matrix_to_const_column_major_cute_tensor(cublas_result, m, n, m);
  print_matrix_multiply_mollified_relative_error("float", A_view, B_view, C_computed_view, C_expected_view);
int main(int argc, char** argv)
  int m = 5120;
  if (argc >= 2)
    sscanf(argv[1], "%d", &m);
  int n = 5120;
  if (argc >= 3)
    sscanf(argv[2], "%d", &n);
  int k = 4096;
  if (argc >= 4)
    sscanf(argv[3], "%d", &k);
  test_gemm(m, n, k);
  return 0;
What does “it will be blocked” mean? In the log output provided, I see a ^C, as if the execution was manually halted by the user.
Code produced by a debug build can run very slowly, and depending on your runtime environment, this means that the execution time of kernels may exceed the limit imposed by the operating system’s GUI watchdog timer. Typically this limit is set to something like 2 seconds. Does the GPU you are running on also service the GUI?
An A100 GPU does not service a display. However it’s possible that the -G switch has caused a significant increase in execution time.
Emmm, I am using the server, so I think no GUI is provided… “It will be blocked” mean, it is verrrrrry slow, about 5-10min… So I mannually shut it down.
I didn’t look at the type of GPU involved; my bad.
With CUDA, debug builds can expected to be very slow. In order to allow the reliable tracking of the value of all variables and precise breakpoints, the compiler turns off all optimizations when compiling device code in a debug build. If you look at the generated machine code (SASS) for a debug build, you will even see code idioms that I call “pessimizations”, like nonsensical looking redundant data moves.
Conversely, if you look at the machine code generated for a release build (which by default uses full optimizations), you will have trouble following the code even for fairly simple kernels. Variables from the high-level CUDA C++ code may have disappeared, while others may have been synthesized by the compiler, or the same variable lives in different registers over the lifetime of a kernel. Code from one line of source code may be dispersed over dozens of individual instructions appearing over longish stretches of code that mix code from different inlined functions.
