Not in general, no. An obvious counterexample is if you have a GTX280 with 30 SMs, and a kernel with a grid of 50 blocks. Every SM will end up getting an initial assignment of only 1 or 2 blocks, even though they could hold 3.
Some blocks may terminate early (depending on the algorithm in the kernel) so typically you can not expect blocks to be scheduled in sequence on the SMs.
Also any CUDA update may change the scheduling mechanism, so relying on undocumented behavior will get you in trouble eventually.
Never try to guess where your blocks will go. You may be wrong!
(and if you ever write any code that depends on block scheduling, I will sit in the corner and be sad. or maybe yell at you a lot. actually yeah, probably the second)
