Hi SivaRamaKrishnaNV,
I was able to run the device query on both target and host and the main difference I see is at “memory clock rate” (1440 MHz on target vs 7000MHz on host)
could that explain difference (857[ms] VS 123[ms]) I see in my Kernel execution time?
attached are the deviceQuery plots:
Xavier target:
Device 0: “Graphics Device”
CUDA Driver Version / Runtime Version 10.2 / 10.2
CUDA Capability Major/Minor version number: 7.5
Total amount of global memory: 7680 MBytes (8052998144 bytes)
(44) Multiprocessors, ( 64) CUDA Cores/MP: 2816 CUDA Cores
GPU Max Clock rate: 1500 MHz (1.50 GHz)
Memory Clock rate: 1440 Mhz
Memory Bus Width: 256-bit
L2 Cache Size: 4194304 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
Maximum Layered 1D Texture Size, (num) layers 1D=(32768), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(32768, 32768), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 1024
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 3 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: Yes
Supports Cooperative Kernel Launch: Yes
Supports MultiDevice Co-op Kernel Launch: Yes
Device PCI Domain ID / Bus ID / location ID: 1 / 1 / 0
host:
Device 0: “GeForce RTX 2080”
CUDA Driver Version / Runtime Version 11.0 / 10.2
Total amount of global memory: 7979 MBytes (8366784512 bytes)
(46) Multiprocessors, ( 64) CUDA Cores/MP: 2944 CUDA Cores
GPU Max Clock rate: 1710 MHz (1.71 GHz)
Memory Clock rate: 7000 Mhz
Warp size: 32
Run time limit on kernels: Yes
Device PCI Domain ID / Bus ID / location ID: 0 / 2 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
