Hello, I am working on displaying images using CSI camera(e-CAM20_CUXVR, e-con systems) which is applicable to Xavier. I want to use this camera to stream multi-camera images on OpenCV.
First of all, based on GStreamer, I ran the following command on terminal with single camera and it works!
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12" ! nvoverlaysink -e
So I coded it to stream in OpenCV based on that command.
But I had a “camera open error” problem.
#include <iostream>
#include <opencv2/opencv.hpp>
int main(int argc, char** argv)
cv::Mat frame;
bool frame_flag = false;
const char* cam = "nvarguscamerasrc ! video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12, framerate=(fraction)30/1 ! nvvidconv flip-method=2 ! video/x-raw, format=(string)NV12 ! videoconvert ! video/x-raw, format=(string)BGR ! nvoverlaysink -e";
cv::VideoCapture cap(cam);
if(!cap.isOpened())
std::cout<<"Failed to open the camera" <<std::endl;
return -1;
Please let me know what I coded wrong.
The additional information is written below
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'GB10'
Name : 10-bit Bayer GBGB/RGRG
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.017s (60.000 fps)
Index : 1
Pixel Format: 'GB12'
Name : 12-bit Bayer GBGB/RGRG
This is an additional question.(You don’t have to answer this.)
I tried multi-streaming as below command and it failed. I want you to tell me what the problem is.
gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12" ! nvoverlaysink -e nvarguscamerasrc sensor-id=1 ! "video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12" ! nvoverlaysink -e nvarguscamerasrc sensor-id=2 ! "video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12" ! nvoverlaysink -e nvarguscamerasrc sensor-id=3 ! "video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, format=(string)NV12" ! nvoverlaysink -e
Error message
nvdc: open: Too many open files
nvdc: failed to open '/dev/tegra_dc_2'.
NvxBaseWorkerFunction[2575] comp OMX.Nvidia.std.iv_renderer.overlay.yuv420 Error -2147479552
Thanks in advance!
