Can I use the Yolo detector via CSI camera ?
which code files should I change ?
Thank you very much !
can I use Resnet10 inclusive weights within other projects ?
Thank you, very much!
You probably should ask this in the DeepStream forum. I missed it, too. For some reason, it’s under the Accelerated Computing section.
