I tried enabling the tiler or the sinks but neither one of the solutions worked. I still get a floating point exception (core dumped).
This is the new output:
WARNING: [TRT]: If this is not the desired behavior, please modify the weights or retrain with regularization to reduce the magnitude of the weights.
WARNING: [TRT]: Weights [name=/model/model.105/m.1/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: - Subnormal FP16 values detected.
WARNING: [TRT]: Weights [name=/model/model.105/m.2/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: - Values less than smallest positive FP16 Subnormal value detected. Converting to FP16 minimum subnormalized value.
WARNING: [TRT]: Weights [name=/model/model.1/conv/Conv + PWN(PWN(/model/model.1/act/Sigmoid), /model/model.1/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.2/conv/Conv + PWN(PWN(/model/model.2/act/Sigmoid), /model/model.2/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.3/conv/Conv + PWN(PWN(/model/model.3/act/Sigmoid), /model/model.3/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.4/conv/Conv || /model/model.5/conv/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.6/conv/Conv + PWN(PWN(/model/model.6/act/Sigmoid), /model/model.6/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.7/conv/Conv + PWN(PWN(/model/model.7/act/Sigmoid), /model/model.7/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.8/conv/Conv + PWN(PWN(/model/model.8/act/Sigmoid), /model/model.8/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.9/conv/Conv + PWN(PWN(/model/model.9/act/Sigmoid), /model/model.9/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.11/conv/Conv + PWN(PWN(/model/model.11/act/Sigmoid), /model/model.11/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.13/conv/Conv + PWN(PWN(/model/model.13/act/Sigmoid), /model/model.13/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.14/conv/Conv + PWN(PWN(/model/model.14/act/Sigmoid), /model/model.14/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.15/conv/Conv + PWN(PWN(/model/model.15/act/Sigmoid), /model/model.15/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.17/conv/Conv || /model/model.18/conv/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.19/conv/Conv + PWN(PWN(/model/model.19/act/Sigmoid), /model/model.19/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.20/conv/Conv + PWN(PWN(/model/model.20/act/Sigmoid), /model/model.20/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.21/conv/Conv + PWN(PWN(/model/model.21/act/Sigmoid), /model/model.21/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.22/conv/Conv + PWN(PWN(/model/model.22/act/Sigmoid), /model/model.22/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.24/conv/Conv + PWN(PWN(/model/model.24/act/Sigmoid), /model/model.24/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.26/conv/Conv + PWN(PWN(/model/model.26/act/Sigmoid), /model/model.26/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.27/conv/Conv || /model/model.66/conv/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.28/conv/Conv + PWN(PWN(/model/model.28/act/Sigmoid), /model/model.28/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.30/conv/Conv || /model/model.31/conv/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.32/conv/Conv + PWN(PWN(/model/model.32/act/Sigmoid), /model/model.32/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.33/conv/Conv + PWN(PWN(/model/model.33/act/Sigmoid), /model/model.33/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.34/conv/Conv + PWN(PWN(/model/model.34/act/Sigmoid), /model/model.34/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.35/conv/Conv + PWN(PWN(/model/model.35/act/Sigmoid), /model/model.35/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.37/conv/Conv + PWN(PWN(/model/model.37/act/Sigmoid), /model/model.37/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.39/conv/Conv + PWN(PWN(/model/model.39/act/Sigmoid), /model/model.39/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.40/conv/Conv || /model/model.54/conv/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.41/conv/Conv + PWN(PWN(/model/model.41/act/Sigmoid), /model/model.41/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.43/conv/Conv || /model/model.44/conv/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.45/conv/Conv + PWN(PWN(/model/model.45/act/Sigmoid), /model/model.45/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.46/conv/Conv + PWN(PWN(/model/model.46/act/Sigmoid), /model/model.46/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.47/conv/Conv + PWN(PWN(/model/model.47/act/Sigmoid), /model/model.47/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.48/conv/Conv + PWN(PWN(/model/model.48/act/Sigmoid), /model/model.48/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.50/conv/Conv + PWN(PWN(/model/model.50/act/Sigmoid), /model/model.50/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.51/cv1/conv/Conv || /model/model.51/cv2/conv/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.51/cv3/conv/Conv + PWN(PWN(/model/model.51/cv3/act/Sigmoid), /model/model.51/cv3/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.51/cv3/conv/Conv + PWN(PWN(/model/model.51/cv3/act/Sigmoid), /model/model.51/cv3/act/Mul).bias] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.51/cv4/conv/Conv + PWN(PWN(/model/model.51/cv4/act/Sigmoid), /model/model.51/cv4/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.51/cv5/conv/Conv + PWN(PWN(/model/model.51/cv5/act/Sigmoid), /model/model.51/cv5/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.51/cv6/conv/Conv + PWN(PWN(/model/model.51/cv6/act/Sigmoid), /model/model.51/cv6/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.51/cv7/conv/Conv + PWN(PWN(/model/model.51/cv7/act/Sigmoid), /model/model.51/cv7/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.52/conv/Conv + PWN(PWN(/model/model.52/act/Sigmoid), /model/model.52/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.56/conv/Conv || /model/model.57/conv/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.58/conv/Conv + PWN(PWN(/model/model.58/act/Sigmoid), /model/model.58/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.59/conv/Conv + PWN(PWN(/model/model.59/act/Sigmoid), /model/model.59/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.60/conv/Conv + PWN(PWN(/model/model.60/act/Sigmoid), /model/model.60/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.61/conv/Conv + PWN(PWN(/model/model.61/act/Sigmoid), /model/model.61/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.63/conv/Conv + PWN(PWN(/model/model.63/act/Sigmoid), /model/model.63/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.64/conv/Conv + PWN(PWN(/model/model.64/act/Sigmoid), /model/model.64/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.68/conv/Conv || /model/model.69/conv/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.70/conv/Conv + PWN(PWN(/model/model.70/act/Sigmoid), /model/model.70/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.71/conv/Conv + PWN(PWN(/model/model.71/act/Sigmoid), /model/model.71/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.72/conv/Conv + PWN(PWN(/model/model.72/act/Sigmoid), /model/model.72/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.73/conv/Conv + PWN(PWN(/model/model.73/act/Sigmoid), /model/model.73/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.75/conv/Conv + PWN(PWN(/model/model.75/act/Sigmoid), /model/model.75/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.77/conv/Conv + PWN(PWN(/model/model.77/act/Sigmoid), /model/model.77/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.78/conv/Conv + PWN(PWN(/model/model.78/act/Sigmoid), /model/model.78/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.79/conv/Conv + PWN(PWN(/model/model.79/act/Sigmoid), /model/model.79/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.81/conv/Conv || /model/model.82/conv/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.83/conv/Conv + PWN(PWN(/model/model.83/act/Sigmoid), /model/model.83/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.84/conv/Conv + PWN(PWN(/model/model.84/act/Sigmoid), /model/model.84/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.85/conv/Conv + PWN(PWN(/model/model.85/act/Sigmoid), /model/model.85/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.86/conv/Conv + PWN(PWN(/model/model.86/act/Sigmoid), /model/model.86/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.88/conv/Conv + PWN(PWN(/model/model.88/act/Sigmoid), /model/model.88/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.90/conv/Conv + PWN(PWN(/model/model.90/act/Sigmoid), /model/model.90/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.91/conv/Conv + PWN(PWN(/model/model.91/act/Sigmoid), /model/model.91/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.92/conv/Conv + PWN(PWN(/model/model.92/act/Sigmoid), /model/model.92/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.94/conv/Conv || /model/model.95/conv/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.96/conv/Conv + PWN(PWN(/model/model.96/act/Sigmoid), /model/model.96/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.97/conv/Conv + PWN(PWN(/model/model.97/act/Sigmoid), /model/model.97/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.98/conv/Conv + PWN(PWN(/model/model.98/act/Sigmoid), /model/model.98/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.99/conv/Conv + PWN(PWN(/model/model.99/act/Sigmoid), /model/model.99/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.101/conv/Conv + PWN(PWN(/model/model.101/act/Sigmoid), /model/model.101/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.102/rbr_reparam/Conv + PWN(PWN(/model/model.102/act/Sigmoid), /model/model.102/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.103/rbr_reparam/Conv + PWN(PWN(/model/model.103/act/Sigmoid), /model/model.103/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.104/rbr_reparam/Conv + PWN(PWN(/model/model.104/act/Sigmoid), /model/model.104/act/Mul).weight] had the following issues when converted to FP16:
WARNING: [TRT]: Weights [name=/model/model.105/m.0/Conv.weight] had the following issues when converted to FP16:
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
0:19:16.167766382 69 0x55ec88904210 INFO nvinfer gstnvinfer.cpp:646:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1955> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-6.1/samples/configs/tao_pretrained_models/best.onnx_b1_gpu0_fp16.engine successfully
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 5
0 INPUT kFLOAT images 3x1920x1088
1 OUTPUT kINT32 num_dets 1
2 OUTPUT kFLOAT det_boxes 1000x4
3 OUTPUT kFLOAT det_scores 1000
4 OUTPUT kINT32 det_classes 1000
0:19:16.206171155 69 0x55ec88904210 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.1/samples/configs/tao_pretrained_models/config_infer_primary_yolov4_lp.txt sucessfully
0:19:16.206782774 69 0x55ec88904210 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
0:19:16.206990617 69 0x55ec88904210 WARN basesrc gstbasesrc.c:3600:gst_base_src_start_complete:<source> pad not activated yet
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:194>: Pipeline ready
0:19:16.247176165 69 0x55ec8898dde0 WARN qtdemux qtdemux_types.c:239:qtdemux_type_get: unknown QuickTime node type Xtra
0:19:16.247243036 69 0x55ec8898dde0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 1
0:19:16.247294037 69 0x55ec8898dde0 WARN qtdemux qtdemux.c:3250:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 2
0:19:16.373778133 69 0x55ec8898dde0 WARN uridecodebin gsturidecodebin.c:920:unknown_type_cb:<src_elem> warning: No decoder available for type 'audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1190, rate=(int)48000, channels=(int)2'.
WARNING from src_elem: No decoder available for type 'audio/mpeg, mpegversion=(int)4, framed=(boolean)true, stream-format=(string)raw, level=(string)2, base-profile=(string)lc, profile=(string)lc, codec_data=(buffer)1190, rate=(int)48000, channels=(int)2'.
Debug info: gsturidecodebin.c(920): unknown_type_cb (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstURIDecodeBin:src_elem
0:19:16.479752618 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479767788 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MJPG
0:19:16.479771608 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479778958 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MJPG
0:19:16.479792019 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479796929 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat AV10
0:19:16.479800269 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479803749 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat AV10
0:19:16.479813659 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479819219 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat DVX5
0:19:16.479824069 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479829399 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat DVX5
0:19:16.479836759 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479841659 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat DVX4
0:19:16.479846389 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479852169 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat DVX4
0:19:16.479860660 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479865610 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG4
0:19:16.479868770 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479875330 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG4
0:19:16.479883250 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479888170 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat MPG2
0:19:16.479892550 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479896630 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat MPG2
0:19:16.479905470 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479909870 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H265
0:19:16.479914770 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479919110 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H265
0:19:16.479926011 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479930371 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP90
0:19:16.479933631 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479939271 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP90
0:19:16.479945851 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479951061 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat VP80
0:19:16.479954401 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479959191 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat VP80
0:19:16.479968361 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479973071 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe minimum capture size for pixelformat H264
0:19:16.479976621 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:sink> Unable to try format: Unknown error -1
0:19:16.479981071 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:sink> Could not probe maximum capture size for pixelformat H264
0:19:16.480268686 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:19:16.480275156 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2942:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe minimum capture size for pixelformat NM12
0:19:16.480278566 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:3057:gst_v4l2_object_get_nearest_size:<nvv4l2decoder0:src> Unable to try format: Unknown error -1
0:19:16.480283196 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2948:gst_v4l2_object_probe_caps_for_format:<nvv4l2decoder0:src> Could not probe maximum capture size for pixelformat NM12
0:19:16.480289856 69 0x7f0eb8052360 WARN v4l2 gstv4l2object.c:2395:gst_v4l2_object_add_interlace_mode:0x7f0eb01133a0 Failed to determine interlace mode
** INFO: <bus_callback:180>: Pipeline running
0:19:16.589704795 69 0x7f0eb8052360 WARN v4l2videodec gstv4l2videodec.c:1847:gst_v4l2_video_dec_decide_allocation:<nvv4l2decoder0> Duration invalid, not setting latency
0:19:16.590136161 69 0x7f0eb8052360 WARN v4l2bufferpool gstv4l2bufferpool.c:1082:gst_v4l2_buffer_pool_start:<nvv4l2decoder0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:19:16.592131711 69 0x7f0eac008ea0 WARN v4l2bufferpool gstv4l2bufferpool.c:1533:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:src> Driver should never set v4l2_buffer.field to ANY
Floating point exception (core dumped)
