Hi mohammadi sajad,
You have a number of issues with this code.
Your array bounds are incorrect. Since the loops go from 1 to <= N but the arrays only have N members, you’re writing off the end of the array.
Your loop isn’t parallelizable since you’re writing to each element from multiple loop iterations. To fix, I’d make these three separate loops.
The loop index variables shouldn’t be made static. This puts them in global storage and thus causes a dependency. While you can fix this by putting them in private clause, it’s better to remove the static and let the compiler implicitly privatize them.
No need to copy the loop index variables.
Try something like the following:
% cat test2.c
#include <stdio.h>
#include <math.h>
#include <stdlib.h>
#include <assert.h>
#include <openacc.h>
#include<time.h>
#include <string.h>
#include <malloc.h>
// #include <cuda_runtime_api.h>
#define NX 2
#define NY 2
#define NZ 2
int main(void)
int i, j, k;
static double A[NX+1][NY+1][NZ+1]=2 ,B[NX+1][NY+1][NZ+1]=10.,C[NX+1]=10.,D[NY+1]=10.,E[NZ+1]=10.;
FILE *file;
file = fopen("BB-and-A.csv", "w");
#pragma acc data copy(A,B,C,D,E)
#pragma acc kernels
for (i = 0; i <= NX; i++) C[i]=i;
for (j =0; j <= NY ; j++) D[j]=j;
for (k =0; k <= NZ ; k++) E[k]=k;
for (i = 0; i <= NX; i++) {
for (j =0; j <= NY ; j++) {
for (k =0; k <= NZ ; k++) {
fprintf(file,"%e, %e, %e \n", C[i], D[j],E[k] );
fclose(file);
% pgcc test2.c -ta=tesla:cc60 -Minfo=accel
main:
23, Generating copy(A[:][:][:],B[:][:][:],C[:],E[:],D[:])
27, Loop is parallelizable
Accelerator kernel generated
Generating Tesla code
27, #pragma acc loop gang, vector(32) /* blockIdx.x threadIdx.x */
28, Loop is parallelizable
28, #pragma acc loop gang, vector(32) /* blockIdx.x threadIdx.x */
29, Loop is parallelizable
29, #pragma acc loop gang, vector(32) /* blockIdx.x threadIdx.x */
% a.out
% cat BB-and-A.csv
0.000000e+00, 0.000000e+00, 0.000000e+00
0.000000e+00, 0.000000e+00, 1.000000e+00
0.000000e+00, 0.000000e+00, 2.000000e+00
0.000000e+00, 1.000000e+00, 0.000000e+00
0.000000e+00, 1.000000e+00, 1.000000e+00
0.000000e+00, 1.000000e+00, 2.000000e+00
0.000000e+00, 2.000000e+00, 0.000000e+00
0.000000e+00, 2.000000e+00, 1.000000e+00
0.000000e+00, 2.000000e+00, 2.000000e+00
1.000000e+00, 0.000000e+00, 0.000000e+00
1.000000e+00, 0.000000e+00, 1.000000e+00
1.000000e+00, 0.000000e+00, 2.000000e+00
1.000000e+00, 1.000000e+00, 0.000000e+00
1.000000e+00, 1.000000e+00, 1.000000e+00
1.000000e+00, 1.000000e+00, 2.000000e+00
1.000000e+00, 2.000000e+00, 0.000000e+00
1.000000e+00, 2.000000e+00, 1.000000e+00
1.000000e+00, 2.000000e+00, 2.000000e+00
2.000000e+00, 0.000000e+00, 0.000000e+00
2.000000e+00, 0.000000e+00, 1.000000e+00
2.000000e+00, 0.000000e+00, 2.000000e+00
2.000000e+00, 1.000000e+00, 0.000000e+00
2.000000e+00, 1.000000e+00, 1.000000e+00
2.000000e+00, 1.000000e+00, 2.000000e+00
2.000000e+00, 2.000000e+00, 0.000000e+00
2.000000e+00, 2.000000e+00, 1.000000e+00
2.000000e+00, 2.000000e+00, 2.000000e+00
Hope this helps,
Mat
