Hi, I am trying to train MobileNet_v2.hdf5 which is from DetectNet_v2 using tlt-train. After running ‘tlt-train’ command, the mAP does not increase from 0 over 120 epochs. I followed the guideline and created the config file from here (https://docs.nvidia.com/metropolis/TLT/tlt-getting-started-guide/index.html#spec_file_gridbox_topic). In addition, I have already trained and exported TrafficCamNet successfully, and deployed it on Jetson AGX Xavier. I am not sure if it is something wrong with mobilenet itself or with my config. I am attaching the log and command line and config files. I do appreciate your help. Thank you.
Command line
tlt-train detectnet_v2 -e /workspace/models/mobile_v2_config.txt -r /workspace/result_mobile_lr -k sycho --gpus 1
Config file
model_config {
arch: “mobilenet_v2”
pretrained_model_file: “/workspace/models/mobilenet_v2.hdf5”
freeze_blocks: 0
freeze_blocks: 1
all_projections: True
use_pooling: False
use_batch_norm: True
dropout_rate: 0.0
training_precision: {
backend_floatx: FLOAT32
objective_set: {
cov {}
bbox {
scale: 35.0
offset: 0.5
training_config {
batch_size_per_gpu: 8
num_epochs: 120
enable_qat: true
learning_rate {
soft_start_annealing_schedule {
min_learning_rate: 5e-6
max_learning_rate: 5e-4
soft_start: 0.1
annealing: 0.7
regularizer {
type: L1
weight: 3e-9
optimizer {
adam {
epsilon: 1e-08
beta1: 0.9
beta2: 0.999
cost_scaling {
enabled: False
initial_exponent: 20.0
increment: 0.005
decrement: 1.0
bbox_rasterizer_config {
target_class_config {
key: “car”
value: {
cov_center_x: 0.5
cov_center_y: 0.5
cov_radius_x: 0.4
cov_radius_y: 0.4
bbox_min_radius: 1.0
deadzone_radius: 0.67
augmentation_config {
preprocessing {
output_image_width: 960
output_image_height: 544
output_image_channel: 3
min_bbox_width: 1.0
min_bbox_height: 1.0
spatial_augmentation {
hflip_probability: 0.5
vflip_probability: 0.0
zoom_min: 1.0
zoom_max: 1.0
translate_max_x: 8.0
translate_max_y: 8.0
color_augmentation {
color_shift_stddev: 0.0
hue_rotation_max: 25.0
saturation_shift_max: 0.2
contrast_scale_max: 0.1
contrast_center: 0.5
evaluation_config {
average_precision_mode: INTEGRATE
validation_period_during_training: 10
first_validation_epoch: 1
minimum_detection_ground_truth_overlap {
key: “car”
value: 0.7
evaluation_box_config {
key: “car”
value {
minimum_height: 4
maximum_height: 9999
minimum_width: 4
maximum_width: 9999
postprocessing_config {
key: “car”
value: {
clustering_config {
coverage_threshold: 0.005
dbscan_eps: 0.15
dbscan_min_samples: 0.05
minimum_bounding_box_height: 20
cost_function_config {
target_classes {
class_weight: 1.0
coverage_foreground_weight: 0.05
objectives {
initial_weight: 1.0
weight_target: 1.0
objectives {
initial_weight: 10.0
weight_target: 1.0
enable_autoweighting: True
max_objective_weight: 0.9999
min_objective_weight: 0.0001
dataset_config {
data_sources: {
tfrecords_path: “/workspace/data/tf_records/*”
image_directory_path: “/workspace/data/day_all”
image_extension: “jpg”
target_class_mapping {
key: “car”
value: “car”
validation_fold: 0
Log
Using TensorFlow backend.
2020-09-23 09:43:34,925 [INFO] iva.detectnet_v2.scripts.train: Loading experiment spec at /workspace/models/mobile_v2_config.txt.
2020-09-23 09:43:34,927 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /workspace/models/mobile_v2_config.txt
File “/usr/local/bin/tlt-train-g1”, line 8, in
sys.exit(main())
File “/home/vpraveen/.cache/dazel/_dazel_vpraveen/715c8bafe7816f3bb6f309cd506049bb/execroot/ai_infra/bazel-out/k8-py3-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infr$
/iva/common/magnet_train.py”, line 55, in main
File “”, line 2, in main
/iva/detectnet_v2/utilities/timer.py”, line 46, in wrapped_fn
/iva/detectnet_v2/scripts/train.py”, line 773, in main
/iva/detectnet_v2/scripts/train.py”, line 680, in run_experiment
/iva/detectnet_v2/model/utilities.py”, line 81, in get_pretrained_model_path
AssertionError: Pretrained model file not found: /workspace/models/mobilenet_v2.tlt
root@7293f29a2091:/workspace# tlt-train detectnet_v2 -e /workspace/models/mobile_v2_config.txt -r /workspace/result_mobile -k sycho --gpus 1
2020-09-23 09:43:55,108 [INFO] iva.detectnet_v2.scripts.train: Loading experiment spec at /workspace/models/mobile_v2_config.txt.
2020-09-23 09:43:55,111 [INFO] iva.detectnet_v2.spec_handler.spec_loader: Merging specification from /workspace/models/mobile_v2_config.txt
2020-09-23 09:43:55,211 [INFO] iva.detectnet_v2.scripts.train: Cannot iterate over exactly 630 samples with a batch size of 8; each epoch will therefore take one extra step.
Layer (type) Output Shape Param # Connected to
input_1 (InputLayer) (None, 3, 544, 960) 0
conv1_pad (ZeroPadding2D) (None, 3, 546, 962) 0 input_1[0][0]
conv1 (Conv2D) (None, 32, 272, 480) 864 conv1_pad[0][0]
bn_conv1 (BatchNormalization) (None, 32, 272, 480) 128 conv1[0][0]
re_lu_1 (ReLU) (None, 32, 272, 480) 0 bn_conv1[0][0]
expanded_conv_depthwise_pad (Ze (None, 32, 274, 482) 0 re_lu_1[0][0]
expanded_conv_depthwise (Depthw (None, 32, 272, 480) 288 expanded_conv_depthwise_pad[0][0]
expanded_conv_depthwise_bn (Bat (None, 32, 272, 480) 128 expanded_conv_depthwise[0][0]
expanded_conv_relu (ReLU) (None, 32, 272, 480) 0 expanded_conv_depthwise_bn[0][0]
expanded_conv_project (Conv2D) (None, 16, 272, 480) 512 expanded_conv_relu[0][0]
expanded_conv_project_bn (Batch (None, 16, 272, 480) 64 expanded_conv_project[0][0]
block_1_expand (Conv2D) (None, 96, 272, 480) 1536 expanded_conv_project_bn[0][0]
block_1_expand_bn (BatchNormali (None, 96, 272, 480) 384 block_1_expand[0][0]
re_lu_2 (ReLU) (None, 96, 272, 480) 0 block_1_expand_bn[0][0]
block_1_depthwise_pad (ZeroPadd (None, 96, 274, 482) 0 re_lu_2[0][0]
block_1_depthwise (DepthwiseCon (None, 96, 136, 240) 864 block_1_depthwise_pad[0][0]
block_1_depthwise_bn (BatchNorm (None, 96, 136, 240) 384 block_1_depthwise[0][0]
block_1_relu (ReLU) (None, 96, 136, 240) 0 block_1_depthwise_bn[0][0]
block_1_project (Conv2D) (None, 24, 136, 240) 2304 block_1_relu[0][0]
block_1_project_bn (BatchNormal (None, 24, 136, 240) 96 block_1_project[0][0]
block_2_expand (Conv2D) (None, 144, 136, 240 3456 block_1_project_bn[0][0]
block_2_expand_bn (BatchNormali (None, 144, 136, 240 576 block_2_expand[0][0]
re_lu_3 (ReLU) (None, 144, 136, 240 0 block_2_expand_bn[0][0]
block_2_depthwise_pad (ZeroPadd (None, 144, 138, 242 0 re_lu_3[0][0]
block_2_depthwise (DepthwiseCon (None, 144, 136, 240 1296 block_2_depthwise_pad[0][0]
block_2_depthwise_bn (BatchNorm (None, 144, 136, 240 576 block_2_depthwise[0][0]
block_2_relu (ReLU) (None, 144, 136, 240 0 block_2_depthwise_bn[0][0]
block_2_project (Conv2D) (None, 24, 136, 240) 3456 block_2_relu[0][0]
block_2_projected_inputs (Conv2 (None, 24, 136, 240) 576 block_1_project_bn[0][0]
block_2_project_bn (BatchNormal (None, 24, 136, 240) 96 block_2_project[0][0]
block_2_add (Add) (None, 24, 136, 240) 0 block_2_projected_inputs[0][0]
block_2_project_bn[0][0]
__________________________________________________________________________________________________ [1461/1818]
block_3_expand (Conv2D) (None, 144, 136, 240 3456 block_2_add[0][0]
block_3_expand_bn (BatchNormali (None, 144, 136, 240 576 block_3_expand[0][0]
re_lu_4 (ReLU) (None, 144, 136, 240 0 block_3_expand_bn[0][0]
block_3_depthwise_pad (ZeroPadd (None, 144, 138, 242 0 re_lu_4[0][0]
block_3_depthwise (DepthwiseCon (None, 144, 68, 120) 1296 block_3_depthwise_pad[0][0]
block_3_depthwise_bn (BatchNorm (None, 144, 68, 120) 576 block_3_depthwise[0][0]
block_3_relu (ReLU) (None, 144, 68, 120) 0 block_3_depthwise_bn[0][0]
block_3_project (Conv2D) (None, 32, 68, 120) 4608 block_3_relu[0][0]
block_3_project_bn (BatchNormal (None, 32, 68, 120) 128 block_3_project[0][0]
block_4_expand (Conv2D) (None, 192, 68, 120) 6144 block_3_project_bn[0][0]
block_4_expand_bn (BatchNormali (None, 192, 68, 120) 768 block_4_expand[0][0]
re_lu_5 (ReLU) (None, 192, 68, 120) 0 block_4_expand_bn[0][0]
block_4_depthwise_pad (ZeroPadd (None, 192, 70, 122) 0 re_lu_5[0][0]
block_4_depthwise (DepthwiseCon (None, 192, 68, 120) 1728 block_4_depthwise_pad[0][0]
block_4_depthwise_bn (BatchNorm (None, 192, 68, 120) 768 block_4_depthwise[0][0]
block_4_relu (ReLU) (None, 192, 68, 120) 0 block_4_depthwise_bn[0][0]
block_4_project (Conv2D) (None, 32, 68, 120) 6144 block_4_relu[0][0]
block_4_projected_inputs (Conv2 (None, 32, 68, 120) 1024 block_3_project_bn[0][0]
block_4_project_bn (BatchNormal (None, 32, 68, 120) 128 block_4_project[0][0]
block_4_add (Add) (None, 32, 68, 120) 0 block_4_projected_inputs[0][0]
block_4_project_bn[0][0]
block_5_expand (Conv2D) (None, 192, 68, 120) 6144 block_4_add[0][0]
block_5_expand_bn (BatchNormali (None, 192, 68, 120) 768 block_5_expand[0][0]
re_lu_6 (ReLU) (None, 192, 68, 120) 0 block_5_expand_bn[0][0]
block_5_depthwise_pad (ZeroPadd (None, 192, 70, 122) 0 re_lu_6[0][0]
block_5_depthwise (DepthwiseCon (None, 192, 68, 120) 1728 block_5_depthwise_pad[0][0]
block_5_depthwise_bn (BatchNorm (None, 192, 68, 120) 768 block_5_depthwise[0][0]
block_5_relu (ReLU) (None, 192, 68, 120) 0 block_5_depthwise_bn[0][0]
block_5_project (Conv2D) (None, 32, 68, 120) 6144 block_5_relu[0][0]
block_5_projected_inputs (Conv2 (None, 32, 68, 120) 1024 block_4_add[0][0]
block_5_project_bn (BatchNormal (None, 32, 68, 120) 128 block_5_project[0][0]
block_5_add (Add) (None, 32, 68, 120) 0 block_5_projected_inputs[0][0]
block_5_project_bn[0][0]
block_6_expand (Conv2D) (None, 192, 68, 120) 6144 block_5_add[0][0]
block_6_expand_bn (BatchNormali (None, 192, 68, 120) 768 block_6_expand[0][0]
re_lu_7 (ReLU) (None, 192, 68, 120) 0 block_6_expand_bn[0][0]
block_6_depthwise_pad (ZeroPadd (None, 192, 70, 122) 0 re_lu_7[0][0]
block_6_depthwise (DepthwiseCon (None, 192, 34, 60) 1728 block_6_depthwise_pad[0][0]
block_6_depthwise_bn (BatchNorm (None, 192, 34, 60) 768 block_6_depthwise[0][0]
block_6_relu (ReLU) (None, 192, 34, 60) 0 block_6_depthwise_bn[0][0]
block_6_project (Conv2D) (None, 64, 34, 60) 12288 block_6_relu[0][0]
block_6_project_bn (BatchNormal (None, 64, 34, 60) 256 block_6_project[0][0]
block_7_expand (Conv2D) (None, 384, 34, 60) 24576 block_6_project_bn[0][0]
block_7_expand_bn (BatchNormali (None, 384, 34, 60) 1536 block_7_expand[0][0]
re_lu_8 (ReLU) (None, 384, 34, 60) 0 block_7_expand_bn[0][0]
block_7_depthwise_pad (ZeroPadd (None, 384, 36, 62) 0 re_lu_8[0][0]
block_7_depthwise (DepthwiseCon (None, 384, 34, 60) 3456 block_7_depthwise_pad[0][0]
block_7_depthwise_bn (BatchNorm (None, 384, 34, 60) 1536 block_7_depthwise[0][0]
block_7_relu (ReLU) (None, 384, 34, 60) 0 block_7_depthwise_bn[0][0]
block_7_project (Conv2D) (None, 64, 34, 60) 24576 block_7_relu[0][0]
block_7_projected_inputs (Conv2 (None, 64, 34, 60) 4096 block_6_project_bn[0][0]
block_7_project_bn (BatchNormal (None, 64, 34, 60) 256 block_7_project[0][0]
block_7_add (Add) (None, 64, 34, 60) 0 block_7_projected_inputs[0][0]
block_7_project_bn[0][0]
block_8_expand (Conv2D) (None, 384, 34, 60) 24576 block_7_add[0][0]
block_8_expand_bn (BatchNormali (None, 384, 34, 60) 1536 block_8_expand[0][0]
re_lu_9 (ReLU) (None, 384, 34, 60) 0 block_8_expand_bn[0][0]
block_8_depthwise_pad (ZeroPadd (None, 384, 36, 62) 0 re_lu_9[0][0]
block_8_depthwise (DepthwiseCon (None, 384, 34, 60) 3456 block_8_depthwise_pad[0][0]
__________________________________________________________________________________________________ [1344/1818]
block_8_relu (ReLU) (None, 384, 34, 60) 0 block_8_depthwise_bn[0][0]
block_8_project (Conv2D) (None, 64, 34, 60) 24576 block_8_relu[0][0]
block_8_projected_inputs (Conv2 (None, 64, 34, 60) 4096 block_7_add[0][0]
block_8_project_bn (BatchNormal (None, 64, 34, 60) 256 block_8_project[0][0]
block_8_add (Add) (None, 64, 34, 60) 0 block_8_projected_inputs[0][0]
block_8_project_bn[0][0]
block_9_expand (Conv2D) (None, 384, 34, 60) 24576 block_8_add[0][0]
block_9_expand_bn (BatchNormali (None, 384, 34, 60) 1536 block_9_expand[0][0]
re_lu_10 (ReLU) (None, 384, 34, 60) 0 block_9_expand_bn[0][0]
block_9_depthwise_pad (ZeroPadd (None, 384, 36, 62) 0 re_lu_10[0][0]
block_9_depthwise (DepthwiseCon (None, 384, 34, 60) 3456 block_9_depthwise_pad[0][0]
block_9_depthwise_bn (BatchNorm (None, 384, 34, 60) 1536 block_9_depthwise[0][0]
block_9_relu (ReLU) (None, 384, 34, 60) 0 block_9_depthwise_bn[0][0]
block_9_project (Conv2D) (None, 64, 34, 60) 24576 block_9_relu[0][0]
block_9_projected_inputs (Conv2 (None, 64, 34, 60) 4096 block_8_add[0][0]
block_9_project_bn (BatchNormal (None, 64, 34, 60) 256 block_9_project[0][0]
block_9_add (Add) (None, 64, 34, 60) 0 block_9_projected_inputs[0][0]
block_9_project_bn[0][0]
block_10_expand (Conv2D) (None, 384, 34, 60) 24576 block_9_add[0][0]
block_10_expand_bn (BatchNormal (None, 384, 34, 60) 1536 block_10_expand[0][0]
re_lu_11 (ReLU) (None, 384, 34, 60) 0 block_10_expand_bn[0][0]
block_10_depthwise_pad (ZeroPad (None, 384, 36, 62) 0 re_lu_11[0][0]
block_10_depthwise (DepthwiseCo (None, 384, 34, 60) 3456 block_10_depthwise_pad[0][0]
block_10_depthwise_bn (BatchNor (None, 384, 34, 60) 1536 block_10_depthwise[0][0]
block_10_relu (ReLU) (None, 384, 34, 60) 0 block_10_depthwise_bn[0][0]
block_10_project (Conv2D) (None, 96, 34, 60) 36864 block_10_relu[0][0]
block_10_project_bn (BatchNorma (None, 96, 34, 60) 384 block_10_project[0][0]
block_11_expand (Conv2D) (None, 576, 34, 60) 55296 block_10_project_bn[0][0]
block_11_expand_bn (BatchNormal (None, 576, 34, 60) 2304 block_11_expand[0][0]
re_lu_12 (ReLU) (None, 576, 34, 60) 0 block_11_expand_bn[0][0]
block_11_depthwise_pad (ZeroPad (None, 576, 36, 62) 0 re_lu_12[0][0]
block_11_depthwise (DepthwiseCo (None, 576, 34, 60) 5184 block_11_depthwise_pad[0][0]
block_11_depthwise_bn (BatchNor (None, 576, 34, 60) 2304 block_11_depthwise[0][0]
block_11_relu (ReLU) (None, 576, 34, 60) 0 block_11_depthwise_bn[0][0]
block_11_project (Conv2D) (None, 96, 34, 60) 55296 block_11_relu[0][0]
block_11_projected_inputs (Conv (None, 96, 34, 60) 9216 block_10_project_bn[0][0]
block_11_project_bn (BatchNorma (None, 96, 34, 60) 384 block_11_project[0][0]
block_11_add (Add) (None, 96, 34, 60) 0 block_11_projected_inputs[0][0]
block_11_project_bn[0][0]
block_12_expand (Conv2D) (None, 576, 34, 60) 55296 block_11_add[0][0]
block_12_expand_bn (BatchNormal (None, 576, 34, 60) 2304 block_12_expand[0][0]
re_lu_13 (ReLU) (None, 576, 34, 60) 0 block_12_expand_bn[0][0]
block_12_depthwise_pad (ZeroPad (None, 576, 36, 62) 0 re_lu_13[0][0]
block_12_depthwise (DepthwiseCo (None, 576, 34, 60) 5184 block_12_depthwise_pad[0][0]
block_12_depthwise_bn (BatchNor (None, 576, 34, 60) 2304 block_12_depthwise[0][0]
block_12_relu (ReLU) (None, 576, 34, 60) 0 block_12_depthwise_bn[0][0]
block_12_project (Conv2D) (None, 96, 34, 60) 55296 block_12_relu[0][0]
block_12_projected_inputs (Conv (None, 96, 34, 60) 9216 block_11_add[0][0]
block_12_project_bn (BatchNorma (None, 96, 34, 60) 384 block_12_project[0][0]
block_12_add (Add) (None, 96, 34, 60) 0 block_12_projected_inputs[0][0]
block_12_project_bn[0][0]
output_bbox (Conv2D) (None, 4, 34, 60) 388 block_12_add[0][0]
output_cov (Conv2D) (None, 1, 34, 60) 97 block_12_add[0][0]
Total params: 592,485
Trainable params: 574,693
Non-trainable params: 17,792
2020-09-23 09:44:19,254 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2020-09-23 09:44:19,254 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2020-09-23 09:44:19,254 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2020-09-23 09:44:19,254 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 4, io threads: 8, compute threads: 4, buffered batches: 4
2020-09-23 09:44:19,254 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 630, number of sources: 1, batch size per gpu: 8, steps: 79
d to polygon coordinates.
2020-09-23 09:44:19,778 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: shuffle: True - shard 0 of 1
2020-09-23 09:44:19,787 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: sampling 1 datasets with weights:
2020-09-23 09:44:19,787 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: source: 0 weight: 1.000000
2020-09-23 09:44:20,474 [INFO] iva.detectnet_v2.scripts.train: Found 630 samples in training set
2020-09-23 09:44:24,252 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2020-09-23 09:44:24,252 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2020-09-23 09:44:24,253 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2020-09-23 09:44:24,253 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 4, io threads: 8, compute threads: 4, buffered batches: 4
2020-09-23 09:44:24,253 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 270, number of sources: 1, batch size per gpu: 8, steps: 34
2020-09-23 09:44:24,302 [INFO] iva.detectnet_v2.dataloader.default_dataloader: Bounding box coordinates were detected in the input specification! Bboxes will be automatically converte
2020-09-23 09:44:24,633 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: shuffle: False - shard 0 of 1
2020-09-23 09:44:24,641 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: sampling 1 datasets with weights:
2020-09-23 09:44:24,641 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: source: 0 weight: 1.000000
2020-09-23 09:44:25,099 [INFO] iva.detectnet_v2.scripts.train: Found 270 samples in validation set
2020-09-23 09:45:30,538 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 0/80: loss: 0.18326 Time taken: 0:00:00 ETA: 0:00:00
2020-09-23 09:45:30,539 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 1.172
2020-09-23 09:45:47,247 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 8.499
2020-09-23 09:45:58,143 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.357
2020-09-23 09:46:08,984 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.448
2020-09-23 09:46:11,116 [INFO] iva.detectnet_v2.evaluation.evaluation: step 0 / 33, 0.00s/step
2020-09-23 09:46:40,000 [INFO] iva.detectnet_v2.evaluation.evaluation: step 10 / 33, 2.89s/step
2020-09-23 09:47:07,359 [INFO] iva.detectnet_v2.evaluation.evaluation: step 20 / 33, 2.74s/step
2020-09-23 09:47:34,436 [INFO] iva.detectnet_v2.evaluation.evaluation: step 30 / 33, 2.71s/step
Matching predictions to ground truth, class 1/1.: 100%|█████████████████████████████████████████████████████████████████████████████████████████| 6864/6864 [00:00<00:00, 10921.24it/s]
Epoch 1/80
Validation cost: 0.009540
Mean average_precision (in %): 0.0000
class name average precision (in %)
car 0
Median Inference Time: 0.017651
2020-09-23 09:47:43,804 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 1/80: loss: 0.01008 Time taken: 0:02:19.580743 ETA: 3:03:46.8
78684
2020-09-23 09:47:52,528 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 1.932
2020-09-23 09:48:03,706 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.892
2020-09-23 09:48:15,014 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.688
2020-09-23 09:48:18,988 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 2/80: loss: 0.01175 Time taken: 0:00:35.246779 ETA: 0:45:49.2
48741
2020-09-23 09:48:26,218 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.851
^[[B^[[B^[[B2020-09-23 09:48:37,359 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.953
2020-09-23 09:48:48,362 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.177
2020-09-23 09:48:53,997 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 3/80: loss: 0.01263 Time taken: 0:00:35.033285 ETA: 0:44:57.5
62956
2020-09-23 09:48:59,190 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.472
2020-09-23 09:49:10,280 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.036
2020-09-23 09:49:21,425 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.945
2020-09-23 09:49:29,018 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 4/80: loss: 0.00813 Time taken: 0:00:34.996720 ETA: 0:44:19.7
50726
2020-09-23 09:49:32,591 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.913
2020-09-23 09:49:43,910 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.670
2020-09-23 09:49:55,128 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.829
2020-09-23 09:50:04,484 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 5/80: loss: 0.00712 Time taken: 0:00:35.447932 ETA: 0:44:18.5
94865
2020-09-23 09:50:06,310 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.886
2020-09-23 09:50:17,359 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.104
2020-09-23 09:50:28,399 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.116
2020-09-23 09:50:39,556 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 6/80: loss: 0.00435 Time taken: 0:00:35.067025 ETA: 0:43:14.9
59864
2020-09-23 09:50:39,556 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.926
2020-09-23 09:50:50,602 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.108
2020-09-23 09:51:01,731 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.971
2020-09-23 09:51:12,790 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.085
2020-09-23 09:51:14,609 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 7/80: loss: 0.00237 Time taken: 0:00:35.048755 ETA: 0:42:38.5
59093
2020-09-23 09:51:23,846 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.091
2020-09-23 09:51:34,991 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.946
2020-09-23 09:51:46,040 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.103
2020-09-23 09:51:49,611 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 8/80: loss: 0.00084 Time taken: 0:00:35.014211 ETA: 0:42:01.0
23222
2020-09-23 09:51:57,094 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.093
2020-09-23 09:52:08,209 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.995
2020-09-23 09:52:19,296 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.040
2020-09-23 09:52:24,605 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 9/80: loss: 0.00085 Time taken: 0:00:35.023525 ETA: 0:41:26.6
70258
2020-09-23 09:52:30,518 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.823
2020-09-23 09:52:41,556 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.120
2020-09-23 09:52:52,559 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.177
2020-09-23 09:53:01,307 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 10/80: loss: 0.00082 Time taken: 0:00:36.697000 ETA: 0:42:48.
789985
2020-09-23 09:53:05,336 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 15.653
2020-09-23 09:53:16,557 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.826
2020-09-23 09:53:27,764 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.847
2020-09-23 09:53:36,188 [INFO] iva.detectnet_v2.evaluation.evaluation: step 0 / 33, 0.00s/step
2020-09-23 09:53:51,062 [INFO] iva.detectnet_v2.evaluation.evaluation: step 10 / 33, 1.49s/step
2020-09-23 09:54:05,819 [INFO] iva.detectnet_v2.evaluation.evaluation: step 20 / 33, 1.48s/step
2020-09-23 09:54:20,485 [INFO] iva.detectnet_v2.evaluation.evaluation: step 30 / 33, 1.47s/step
Epoch 11/80
Validation cost: 0.002639
car 0
Median Inference Time: 0.016214
2020-09-23 09:54:25,404 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 11/80: loss: 0.00093 Time taken: 0:01:24.045210 ETA: 1:36:39.
119466
2020-09-23 09:54:27,651 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 3.340
2020-09-23 09:54:38,731 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.051
2020-09-23 09:54:50,061 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.653
2020-09-23 09:55:00,918 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 12/80: loss: 0.00059 Time taken: 0:00:35.541067 ETA: 0:40:16.
792548
2020-09-23 09:55:01,347 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.722
2020-09-23 09:55:12,603 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.769
2020-09-23 09:55:23,766 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.917
2020-09-23 09:55:34,679 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.329
2020-09-23 09:55:35,990 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 13/80: loss: 0.00071 Time taken: 0:00:35.101220 ETA: 0:39:11.
781749
2020-09-23 09:55:45,698 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.150
2020-09-23 09:55:56,674 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.223
2020-09-23 09:56:07,776 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.016
2020-09-23 09:56:10,847 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 14/80: loss: 0.00061 Time taken: 0:00:34.828262 ETA: 0:38:18.
665282
2020-09-23 09:56:18,880 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.012
2020-09-23 09:56:29,919 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.118
2020-09-23 09:56:41,122 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.853
2020-09-23 09:56:46,071 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 15/80: loss: 0.00078 Time taken: 0:00:35.244284 ETA: 0:38:10.
878485
2020-09-23 09:56:52,284 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.918
2020-09-23 09:57:03,374 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.035
2020-09-23 09:57:14,467 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.030
2020-09-23 09:57:21,046 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 16/80: loss: 0.00089 Time taken: 0:00:34.942158 ETA: 0:37:16.
298096
2020-09-23 09:57:25,410 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.277
2020-09-23 09:57:36,475 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.076
2020-09-23 09:57:47,634 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.925
2020-09-23 09:57:56,111 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 17/80: loss: 0.00069 Time taken: 0:00:35.072267 ETA: 0:36:49.
552840
2020-09-23 09:57:58,730 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.025
2020-09-23 09:58:09,920 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.874
2020-09-23 09:58:21,016 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.024
2020-09-23 09:58:31,135 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 18/80: loss: 0.00067 Time taken: 0:00:35.048826 ETA: 0:36:13.
027240
2020-09-23 09:58:31,998 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.212
2020-09-23 09:58:43,121 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.982
2020-09-23 09:58:54,269 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.942
2020-09-23 09:59:05,328 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.085
2020-09-23 09:59:06,199 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 19/80: loss: 0.00066 Time taken: 0:00:35.064729 ETA: 0:35:38.
948453
2020-09-23 09:59:16,484 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.928
2020-09-23 09:59:27,493 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.167
2020-09-23 09:59:38,485 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.197
2020-09-23 09:59:42,666 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 20/80: loss: 0.00072 Time taken: 0:00:36.439418 ETA: 0:36:26.
365070
2020-09-23 09:59:51,065 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 15.899
2020-09-23 10:00:02,255 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.874
2020-09-23 10:00:13,371 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.993
2020-09-23 10:00:17,297 [INFO] iva.detectnet_v2.evaluation.evaluation: step 0 / 33, 0.00s/step
2020-09-23 10:00:31,883 [INFO] iva.detectnet_v2.evaluation.evaluation: step 10 / 33, 1.46s/step
2020-09-23 10:00:46,720 [INFO] iva.detectnet_v2.evaluation.evaluation: step 20 / 33, 1.48s/step
2020-09-23 10:01:01,567 [INFO] iva.detectnet_v2.evaluation.evaluation: step 30 / 33, 1.48s/step
Epoch 21/80
Validation cost: 0.001487
car 0
Median Inference Time: 0.016736
2020-09-23 10:01:06,552 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 21/80: loss: 0.00067 Time taken: 0:01:23.846728 ETA: 1:22:26.
956971
2020-09-23 10:01:13,175 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 3.344
2020-09-23 10:01:24,340 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.913
2020-09-23 10:01:35,585 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.787
2020-09-23 10:01:41,952 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 22/80: loss: 0.00047 Time taken: 0:00:35.437569 ETA: 0:34:15.
379010
2020-09-23 10:01:46,820 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.802
2020-09-23 10:01:57,917 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.023
2020-09-23 10:02:09,101 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.885
2020-09-23 10:02:17,082 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 23/80: loss: 0.00052 Time taken: 0:00:35.134397 ETA: 0:33:22.
660644
2020-09-23 10:02:20,128 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.138
2020-09-23 10:02:31,116 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.203
2020-09-23 10:02:42,140 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.142
2020-09-23 10:02:51,820 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 24/80: loss: 0.00065 Time taken: 0:00:34.753177 ETA: 0:32:26.
177935
2020-09-23 10:02:53,184 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.110
2020-09-23 10:03:04,347 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.917
2020-09-23 10:03:15,399 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.097
2020-09-23 10:03:26,390 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.198
2020-09-23 10:03:26,852 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 25/80: loss: 0.00050 Time taken: 0:00:34.998227 ETA: 0:32:04.
902478
2020-09-23 10:03:37,513 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.982
2020-09-23 10:03:48,404 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.364
2020-09-23 10:03:59,345 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.281
2020-09-23 10:04:01,559 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 26/80: loss: 0.00032 Time taken: 0:00:34.747539 ETA: 0:31:16.
367121
2020-09-23 10:04:10,564 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.827
2020-09-23 10:04:21,535 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.231
2020-09-23 10:04:32,776 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.793
2020-09-23 10:04:36,708 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 27/80: loss: 0.00056 Time taken: 0:00:35.141604 ETA: 0:31:02.
504997
2020-09-23 10:04:43,786 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.166
2020-09-23 10:04:54,851 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.076
2020-09-23 10:05:06,069 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.829
2020-09-23 10:05:11,801 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 28/80: loss: 0.00045 Time taken: 0:00:35.056081 ETA: 0:30:22.
916227
2020-09-23 10:05:17,194 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 17.978
2020-09-23 10:05:28,259 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.076
2020-09-23 10:05:39,322 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.079
2020-09-23 10:05:46,813 [INFO] /usr/local/lib/python3.6/dist-packages/modulus/hooks/task_progress_monitor_hook.pyc: Epoch 29/80: loss: 0.00081 Time taken: 0:00:35.031645 ETA: 0:29:46.
613910
2020-09-23 10:05:50,350 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.135
2020-09-23 10:06:01,449 [INFO] modulus.hooks.sample_counter_hook: Train Samples / sec: 18.021
