1 lane mipi sensor + UB953/UB960 not streaming on Orin (works on Xavier)
Hi everyone,
I’m bringing up an 1 lane sensor connected via TI UB953/UB960 SerDes on a Jetson Orin, and I’m not getting any video output — even though the exact same setup and configuration works fine on Jetson Xavier Setup details
  • Sensor: 1 lane mipi sensor
  • Serializer: TI UB953
  • Deserializer: TI UB960
  • Connection: 1 CSI lane (YUYV 16-bit format)
  • Platform: Jetson Orin Jetpack 6.2
  • Same device tree and initialization sequence that worked on Xavier
Device tree snippet
mode0 {
    mclk = "extperiph1";
    mclk_khz = "25000";
    num_lanes = "1";
    tegra_sinterface = "serial_g";
    lane_polarity = "0";
    discontinuous_clk = "no";
    set_mode_delay_ms = "800";
    dpcm_enable = "false";
    cil_settletime = "0";
    csi_pixel_bit_depth = "16";
    pixel_phase = "yuyv";
    active_w = "640";
    active_h = "480";
    readout_orientation = "0";
    inherent_gain = "1";
    serdes_pix_clk_hz = "50000000";
    pix_clk_hz = "54000000";
    embedded_metadata_height = "0";
    vc_id = "0";
    mode_type = "yuv";
i am getting “invalid frames“ error with debug trace. rtcpu_nvcsi_intr: … status:0x0a000000.
Based on the provided context, it appears that you are experiencing issues with bringing up a camera on a Jetson AGX Orin platform, specifically with a GMSL camera setup. Despite using the same setup and configuration that worked fine on a Jetson Xavier platform, you are not getting any video output on the Jetson AGX Orin.
Here are a few potential issues to consider:
  1. Virtual Channel Configuration: The Jetson AGX Orin series supports a maximum of 16 virtual channels with ISP, or 24 virtual channels without ISP. Ensure that your virtual channel configuration is correct and matches the stream’s virtual channel ID programmed on the receiver side in the NVIDIA SoC.
  2. CSI Lane Configuration: The Jetson AGX Orin series has 4 CSI bricks, each with x4, x2, or x1 possible lane configurations. Verify that your CSI lane configuration is correct and matches the sensor’s output format (YUYV 16bit format in your case).
  3. Deserializer Connection: Ensure that the deserializer connection is correct, and the GMSL links are properly connected to the serializer and deserializer devices.
  4. Device Tree and Initialization Sequence: Although you mentioned that you are using the same device tree and initialization sequence that worked on Xavier, it’s possible that there are some differences in the device tree or initialization sequence that need to be accounted for on the Jetson AGX Orin platform.
  5. Debug Trace: The debug trace rtcpunvcsiintr: status 0x0a000000 indicates an invalid frame error. This could be related to a misconfiguration of the virtual channels, CSI lane configuration, or deserializer connection.
To troubleshoot the issue, you can try the following:
  1. Verify the virtual channel configuration and ensure that it matches the stream’s virtual channel ID programmed on the receiver side in the NVIDIA SoC.
  2. Check the CSI lane configuration and ensure that it matches the sensor’s output format (YUYV 16bit format in your case).
  3. Verify the deserializer connection and ensure that the GMSL links are properly connected to the serializer and deserializer devices.
  4. Review the device tree and initialization sequence to ensure that they are correct and account for any differences between the Jetson Xavier and Jetson AGX Orin platforms.
  5. Use the debug trace to identify the source of the invalid frame error and adjust the configuration accordingly.
In comparison to the Jetson Xavier platform, the Jetson AGX Orin platform has some differences in terms of virtual channel configuration, CSI lane configuration, and deserializer connection. Therefore, it’s essential to ensure that the configuration is correct and accounts for these differences.
Additionally, you can refer to the provided context, which includes information on the Jetson Virtual Channel with GMSL Camera Framework, to ensure that your setup and configuration are correct.
If you are still experiencing issues, please provide more details about your setup and configuration, and I’ll be happy to help you troubleshoot the problem.
i have already tried all the suggestions. how to identify source of invalid frame error?
HI @shivlal12345 ,
I hope you are doing well.
Can you please share the full dmesg output from a fresh boot up to where the camera streaming fails?
Also, can you try getting video output using the UB960’s internal test pattern generator ? This will help us identify whether the error is in the Deserializer/Jetson connection or on the sensor side.
Best regards,
Nico
Get the trace log to check.
dmesg log.
[ 424.154076] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request tim ed out after 2500 ms
[ 424.154100] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 424.155183] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully r eset the capture channel
debug trace log.
cat /sys/kernel/debug/tracing/trace
 kworker/5:2-369     [005] .......   955.811752: rtcpu_string: tstamp:30761515997 id:0x04010000 str:"VM0 deactivating."
gst-launch-1.0-2461 [000] … 959.473607: tegra_channel_open: vi-output, ov5693 2-006d
gst-launch-1.0-2461 [000] … 959.473702: tegra_channel_close: vi-output, ov5693 2-006d
gst-launch-1.0-2461 [000] … 959.473714: tegra_channel_open: vi-output, ov5693 2-006c
gst-launch-1.0-2461 [000] … 959.473803: tegra_channel_close: vi-output, ov5693 2-006c
gst-launch-1.0-2461 [000] … 959.473813: tegra_channel_open: vi-output, ov5693 2-006e
gst-launch-1.0-2461 [000] … 959.473830: tegra_channel_close: vi-output, ov5693 2-006e
gst-launch-1.0-2461 [002] … 962.372733: tegra_channel_open: vi-output, ov5693 2-006d
v4l2src0:src-2464 [005] … 963.173541: tegra_channel_set_power: ov5693 2-006d : 0x1
v4l2src0:src-2464 [005] … 963.173553: camera_common_s_power: status : 0x1
v4l2src0:src-2464 [005] … 963.173559: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2src0:src-2464 [005] … 963.173562: csi_s_power: enable : 0x1
v4l2src0:src-2464 [005] … 963.174206: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 10
vi-output, ov56-2466 [000] … 963.186152: vi_task_submit: class_id:48 ch:0 syncpt_id:37 syncpt_thresh:0 pid:2466 tid:2466
vi-output, ov56-2466 [000] … 963.186170: vi_task_submit: class_id:48 ch:0 syncpt_id:37 syncpt_thresh:0 pid:2466 tid:2466
v4l2src0:src-2464 [006] … 963.186441: tegra_channel_set_stream: enable : 0x1
v4l2src0:src-2464 [006] … 963.188342: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x1
v4l2src0:src-2464 [006] … 963.188346: csi_s_stream: enable : 0x1
v4l2src0:src-2464 [006] … 963.188677: tegra_channel_set_stream: ov5693 2-006d : 0x1
kworker/5:2-369 [005] … 963.207270: rtcpu_string: tstamp:30993131889 id:0x04010000 str:“VM0 activating.”
kworker/5:2-369 [005] … 963.207274: rtcpu_nvcsi_intr: tstamp:30993666365 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.207274: rtcpu_nvcsi_intr: tstamp:30993679103 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.207275: rtcpu_nvcsi_intr: tstamp:30993681517 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.207277: rtcpu_vinotify_event: tstamp:30993861842 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:991787065792 data:0x359e300010000000
kworker/5:2-369 [005] … 963.207277: rtcpu_vinotify_event: tstamp:30993861980 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:991787107872 data:0x0000000031000001
kworker/5:2-369 [005] … 963.207278: rtcpu_vinotify_event: tstamp:30993862136 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:991787126080 data:0x359e2d0010000000
kworker/5:2-369 [005] … 963.207278: rtcpu_vinotify_event: tstamp:30993862268 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:991787146368 data:0x0000000007020001
kworker/5:2-369 [005] … 963.207279: rtcpu_vinotify_event: tstamp:30993862420 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:991787188736 data:0x0000000031000002
kworker/5:2-369 [005] … 963.263286: rtcpu_nvcsi_intr: tstamp:30994272255 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.263287: rtcpu_nvcsi_intr: tstamp:30994285001 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.263288: rtcpu_nvcsi_intr: tstamp:30994287408 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.263288: rtcpu_nvcsi_intr: tstamp:30994878147 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.263289: rtcpu_nvcsi_intr: tstamp:30994890896 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.263290: rtcpu_nvcsi_intr: tstamp:30994893298 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.263291: rtcpu_nvcsi_intr: tstamp:30995484036 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.263291: rtcpu_nvcsi_intr: tstamp:30995496795 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.263292: rtcpu_nvcsi_intr: tstamp:30995499189 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.319286: rtcpu_nvcsi_intr: tstamp:30996089927 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.319289: rtcpu_nvcsi_intr: tstamp:30996102694 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.319289: rtcpu_nvcsi_intr: tstamp:30996105078 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.319290: rtcpu_nvcsi_intr: tstamp:30996695817 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.319291: rtcpu_nvcsi_intr: tstamp:30996708590 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.319292: rtcpu_nvcsi_intr: tstamp:30996710969 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.319293: rtcpu_nvcsi_intr: tstamp:30997301708 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.319294: rtcpu_nvcsi_intr: tstamp:30997314485 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.319295: rtcpu_nvcsi_intr: tstamp:30997316859 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.375455: rtcpu_nvcsi_intr: tstamp:30997907598 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.375458: rtcpu_nvcsi_intr: tstamp:30997920383 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.375458: rtcpu_nvcsi_intr: tstamp:30997922750 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.375460: rtcpu_nvcsi_intr: tstamp:30998513487 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.375461: rtcpu_nvcsi_intr: tstamp:30998526282 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.375461: rtcpu_nvcsi_intr: tstamp:30998528640 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.375462: rtcpu_nvcsi_intr: tstamp:30999119375 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.375463: rtcpu_nvcsi_intr: tstamp:30999132178 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.375464: rtcpu_nvcsi_intr: tstamp:30999134529 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.431460: rtcpu_nvcsi_intr: tstamp:30999725266 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.431462: rtcpu_nvcsi_intr: tstamp:30999738295 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.431463: rtcpu_nvcsi_intr: tstamp:30999740417 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.431463: rtcpu_nvcsi_intr: tstamp:31000331156 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.431464: rtcpu_nvcsi_intr: tstamp:31000344191 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.431465: rtcpu_nvcsi_intr: tstamp:31000346308 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.431466: rtcpu_nvcsi_intr: tstamp:31000937047 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.431466: rtcpu_nvcsi_intr: tstamp:31000950089 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.431467: rtcpu_nvcsi_intr: tstamp:31000952202 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.487286: rtcpu_nvcsi_intr: tstamp:31001542937 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.487289: rtcpu_nvcsi_intr: tstamp:31001555984 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.487289: rtcpu_nvcsi_intr: tstamp:31001558092 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.487291: rtcpu_nvcsi_intr: tstamp:31002148828 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.487292: rtcpu_nvcsi_intr: tstamp:31002161883 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.487292: rtcpu_nvcsi_intr: tstamp:31002163982 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.543503: rtcpu_nvcsi_intr: tstamp:31002754718 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.543506: rtcpu_nvcsi_intr: tstamp:31002767782 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.543506: rtcpu_nvcsi_intr: tstamp:31002769870 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.543508: rtcpu_nvcsi_intr: tstamp:31003360608 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.543509: rtcpu_nvcsi_intr: tstamp:31003373677 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.543509: rtcpu_nvcsi_intr: tstamp:31003375760 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.543510: rtcpu_nvcsi_intr: tstamp:31003966498 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.543511: rtcpu_nvcsi_intr: tstamp:31003979573 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.543512: rtcpu_nvcsi_intr: tstamp:31003981653 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.599494: rtcpu_nvcsi_intr: tstamp:31004572389 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.599497: rtcpu_nvcsi_intr: tstamp:31004585472 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.599498: rtcpu_nvcsi_intr: tstamp:31004587541 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.599499: rtcpu_nvcsi_intr: tstamp:31005178280 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.599500: rtcpu_nvcsi_intr: tstamp:31005191366 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.599500: rtcpu_nvcsi_intr: tstamp:31005193431 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.599502: rtcpu_nvcsi_intr: tstamp:31005784170 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.599503: rtcpu_nvcsi_intr: tstamp:31005797747 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.599503: rtcpu_nvcsi_intr: tstamp:31005799321 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.655282: rtcpu_nvcsi_intr: tstamp:31006390057 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.655285: rtcpu_nvcsi_intr: tstamp:31006403161 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.655286: rtcpu_nvcsi_intr: tstamp:31006405212 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.655287: rtcpu_nvcsi_intr: tstamp:31006995942 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.655288: rtcpu_nvcsi_intr: tstamp:31007009056 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.655289: rtcpu_nvcsi_intr: tstamp:31007011103 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.655290: rtcpu_nvcsi_intr: tstamp:31007601841 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.655291: rtcpu_nvcsi_intr: tstamp:31007614959 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.655291: rtcpu_nvcsi_intr: tstamp:31007616992 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.711262: rtcpu_nvcsi_intr: tstamp:31008207731 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.711262: rtcpu_nvcsi_intr: tstamp:31008220854 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.711263: rtcpu_nvcsi_intr: tstamp:31008222883 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.711264: rtcpu_nvcsi_intr: tstamp:31008813618 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.711265: rtcpu_nvcsi_intr: tstamp:31008826749 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.711267: rtcpu_nvcsi_intr: tstamp:31008828773 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.711268: rtcpu_nvcsi_intr: tstamp:31009419509 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.711269: rtcpu_nvcsi_intr: tstamp:31009432647 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.711269: rtcpu_nvcsi_intr: tstamp:31009434663 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.767283: rtcpu_nvcsi_intr: tstamp:31010025399 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.767285: rtcpu_nvcsi_intr: tstamp:31010038543 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.767286: rtcpu_nvcsi_intr: tstamp:31010040555 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.767286: rtcpu_nvcsi_intr: tstamp:31010631293 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.767287: rtcpu_nvcsi_intr: tstamp:31010644442 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.767288: rtcpu_nvcsi_intr: tstamp:31010646445 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 963.767289: rtcpu_nvcsi_intr: tstamp:31011237183 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 965.839455: rtcpu_nvcsi_intr: tstamp:31076082586 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
vi-output, ov56-2467 [001] … 965.848351: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 10
kworker/5:2-369 [005] … 965.895263: rtcpu_nvcsi_intr: tstamp:31076673330 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 965.895266: rtcpu_nvcsi_intr: tstamp:31076687422 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.231277: rtcpu_nvcsi_intr: tstamp:31088200387 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
vi-output, ov56-2466 [000] … 966.238635: vi_task_submit: class_id:48 ch:0 syncpt_id:37 syncpt_thresh:0 pid:2466 tid:2466
kworker/5:2-369 [005] … 966.287268: rtcpu_nvcsi_intr: tstamp:31088791222 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.287271: rtcpu_nvcsi_intr: tstamp:31088805254 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.287271: rtcpu_nvcsi_intr: tstamp:31088806277 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.287274: rtcpu_vinotify_event: tstamp:31088820797 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:994839520992 data:0x359e300010000000
kworker/5:2-369 [005] … 966.287275: rtcpu_vinotify_event: tstamp:31088820952 cch:0 vi:1 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:994839563104 data:0x0000000031000001
kworker/5:2-369 [005] … 966.287276: rtcpu_vinotify_event: tstamp:31088821086 cch:0 vi:1 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:994839584768 data:0x0000000007020001
kworker/5:2-369 [005] … 966.287277: rtcpu_nvcsi_intr: tstamp:31089397113 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.287278: rtcpu_nvcsi_intr: tstamp:31089411144 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.287279: rtcpu_nvcsi_intr: tstamp:31089412167 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.287279: rtcpu_nvcsi_intr: tstamp:31090003003 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.287280: rtcpu_nvcsi_intr: tstamp:31090017035 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.287281: rtcpu_nvcsi_intr: tstamp:31090018054 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.343443: rtcpu_nvcsi_intr: tstamp:31090608898 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.343446: rtcpu_nvcsi_intr: tstamp:31090622929 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.343447: rtcpu_nvcsi_intr: tstamp:31090623949 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.343448: rtcpu_nvcsi_intr: tstamp:31091214788 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.343448: rtcpu_nvcsi_intr: tstamp:31091228820 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.343449: rtcpu_nvcsi_intr: tstamp:31091229839 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.343449: rtcpu_nvcsi_intr: tstamp:31091820682 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.343450: rtcpu_nvcsi_intr: tstamp:31091834714 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.343451: rtcpu_nvcsi_intr: tstamp:31091835729 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.399447: rtcpu_nvcsi_intr: tstamp:31092426573 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.399450: rtcpu_nvcsi_intr: tstamp:31092440601 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.399451: rtcpu_nvcsi_intr: tstamp:31092441618 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.399452: rtcpu_nvcsi_intr: tstamp:31093032463 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.399453: rtcpu_nvcsi_intr: tstamp:31093046495 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.399454: rtcpu_nvcsi_intr: tstamp:31093047510 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.399455: rtcpu_nvcsi_intr: tstamp:31093638354 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.399456: rtcpu_nvcsi_intr: tstamp:31093652386 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.399457: rtcpu_nvcsi_intr: tstamp:31093653400 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.455428: rtcpu_nvcsi_intr: tstamp:31094244730 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.455431: rtcpu_nvcsi_intr: tstamp:31094258279 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.455432: rtcpu_nvcsi_intr: tstamp:31094259287 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.455433: rtcpu_nvcsi_intr: tstamp:31094850139 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.455434: rtcpu_nvcsi_intr: tstamp:31094864171 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.455434: rtcpu_nvcsi_intr: tstamp:31094865177 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.455434: rtcpu_nvcsi_intr: tstamp:31095456030 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.455435: rtcpu_nvcsi_intr: tstamp:31095470062 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.455436: rtcpu_nvcsi_intr: tstamp:31095471067 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.511447: rtcpu_nvcsi_intr: tstamp:31096061920 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.511451: rtcpu_nvcsi_intr: tstamp:31096075952 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.511451: rtcpu_nvcsi_intr: tstamp:31096076958 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.511452: rtcpu_nvcsi_intr: tstamp:31096667811 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.511453: rtcpu_nvcsi_intr: tstamp:31096681843 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.511454: rtcpu_nvcsi_intr: tstamp:31096682849 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.567452: rtcpu_nvcsi_intr: tstamp:31097273705 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.567455: rtcpu_nvcsi_intr: tstamp:31097287738 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.567456: rtcpu_nvcsi_intr: tstamp:31097288738 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.567457: rtcpu_nvcsi_intr: tstamp:31097879596 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.567457: rtcpu_nvcsi_intr: tstamp:31097893627 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.567458: rtcpu_nvcsi_intr: tstamp:31097894629 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.567459: rtcpu_nvcsi_intr: tstamp:31098485487 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.567460: rtcpu_nvcsi_intr: tstamp:31098499519 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.567460: rtcpu_nvcsi_intr: tstamp:31098500520 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.623449: rtcpu_nvcsi_intr: tstamp:31099091381 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.623453: rtcpu_nvcsi_intr: tstamp:31099105411 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.623454: rtcpu_nvcsi_intr: tstamp:31099106409 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.623455: rtcpu_nvcsi_intr: tstamp:31099697272 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.623456: rtcpu_nvcsi_intr: tstamp:31099711303 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.623456: rtcpu_nvcsi_intr: tstamp:31099712297 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.623457: rtcpu_nvcsi_intr: tstamp:31100303162 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.623457: rtcpu_nvcsi_intr: tstamp:31100317194 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.623458: rtcpu_nvcsi_intr: tstamp:31100318187 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.679450: rtcpu_nvcsi_intr: tstamp:31100909053 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.679454: rtcpu_nvcsi_intr: tstamp:31100923089 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.679456: rtcpu_nvcsi_intr: tstamp:31100924081 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.679457: rtcpu_nvcsi_intr: tstamp:31101514948 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.679457: rtcpu_nvcsi_intr: tstamp:31101528986 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.679458: rtcpu_nvcsi_intr: tstamp:31101529970 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.679459: rtcpu_nvcsi_intr: tstamp:31102120838 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.679460: rtcpu_nvcsi_intr: tstamp:31102134883 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.679460: rtcpu_nvcsi_intr: tstamp:31102135861 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.735274: rtcpu_nvcsi_intr: tstamp:31102726728 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.735278: rtcpu_nvcsi_intr: tstamp:31102740777 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.735279: rtcpu_nvcsi_intr: tstamp:31102741753 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.735280: rtcpu_nvcsi_intr: tstamp:31103332621 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.735281: rtcpu_nvcsi_intr: tstamp:31103346676 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.735282: rtcpu_nvcsi_intr: tstamp:31103347639 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.735282: rtcpu_nvcsi_intr: tstamp:31103938513 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.735283: rtcpu_nvcsi_intr: tstamp:31103952572 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.735284: rtcpu_nvcsi_intr: tstamp:31103953529 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.791263: rtcpu_nvcsi_intr: tstamp:31104544405 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.791266: rtcpu_nvcsi_intr: tstamp:31104558467 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.791267: rtcpu_nvcsi_intr: tstamp:31104559420 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.791267: rtcpu_nvcsi_intr: tstamp:31105150294 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.791268: rtcpu_nvcsi_intr: tstamp:31105164364 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.791269: rtcpu_nvcsi_intr: tstamp:31105165314 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.791269: rtcpu_nvcsi_intr: tstamp:31105756186 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.791270: rtcpu_nvcsi_intr: tstamp:31105770261 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.791270: rtcpu_nvcsi_intr: tstamp:31105771210 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.847263: rtcpu_nvcsi_intr: tstamp:31106362079 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.847266: rtcpu_nvcsi_intr: tstamp:31106376155 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.847267: rtcpu_nvcsi_intr: tstamp:31106377105 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.847268: rtcpu_nvcsi_intr: tstamp:31106967970 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.847269: rtcpu_nvcsi_intr: tstamp:31106982051 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.847269: rtcpu_nvcsi_intr: tstamp:31106983003 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.847271: rtcpu_nvcsi_intr: tstamp:31107573861 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.847272: rtcpu_nvcsi_intr: tstamp:31107587950 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.847272: rtcpu_nvcsi_intr: tstamp:31107588899 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
gst-launch-1.0-2461 [006] … 966.893112: tegra_channel_close: vi-output, ov5693 2-006d
kworker/5:2-369 [005] … 966.907258: rtcpu_nvcsi_intr: tstamp:31108179752 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.907260: rtcpu_nvcsi_intr: tstamp:31108193844 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.907261: rtcpu_nvcsi_intr: tstamp:31108194796 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.907262: rtcpu_nvcsi_intr: tstamp:31108785646 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.907262: rtcpu_nvcsi_intr: tstamp:31108799743 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.907263: rtcpu_nvcsi_intr: tstamp:31108800692 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.907264: rtcpu_nvcsi_intr: tstamp:31109391537 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.907264: rtcpu_nvcsi_intr: tstamp:31109405638 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.907265: rtcpu_nvcsi_intr: tstamp:31109406588 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.963249: rtcpu_nvcsi_intr: tstamp:31109997427 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.963250: rtcpu_nvcsi_intr: tstamp:31110011533 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.963250: rtcpu_nvcsi_intr: tstamp:31110012485 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.963251: rtcpu_nvcsi_intr: tstamp:31110603321 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.963251: rtcpu_nvcsi_intr: tstamp:31110617428 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.963252: rtcpu_nvcsi_intr: tstamp:31110618381 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.963253: rtcpu_nvcsi_intr: tstamp:31111209212 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.963253: rtcpu_nvcsi_intr: tstamp:31111223327 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 966.963254: rtcpu_nvcsi_intr: tstamp:31111224276 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.019435: rtcpu_nvcsi_intr: tstamp:31111815107 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.019439: rtcpu_nvcsi_intr: tstamp:31111829221 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.019440: rtcpu_nvcsi_intr: tstamp:31111830171 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.019441: rtcpu_nvcsi_intr: tstamp:31112420993 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.019441: rtcpu_nvcsi_intr: tstamp:31112435120 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.019442: rtcpu_nvcsi_intr: tstamp:31112436070 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.019443: rtcpu_nvcsi_intr: tstamp:31113026888 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.019443: rtcpu_nvcsi_intr: tstamp:31113041015 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.019444: rtcpu_nvcsi_intr: tstamp:31113041965 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.075445: rtcpu_nvcsi_intr: tstamp:31113632778 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.075449: rtcpu_nvcsi_intr: tstamp:31113646914 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.075450: rtcpu_nvcsi_intr: tstamp:31113647864 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.075450: rtcpu_nvcsi_intr: tstamp:31114238668 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.075451: rtcpu_nvcsi_intr: tstamp:31114253252 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.075451: rtcpu_nvcsi_intr: tstamp:31114253760 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.075452: rtcpu_nvcsi_intr: tstamp:31114844559 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.075453: rtcpu_nvcsi_intr: tstamp:31114859147 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.075454: rtcpu_nvcsi_intr: tstamp:31114859654 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.131243: rtcpu_nvcsi_intr: tstamp:31115450450 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.131247: rtcpu_nvcsi_intr: tstamp:31115465045 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.131248: rtcpu_nvcsi_intr: tstamp:31115465553 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.131249: rtcpu_nvcsi_intr: tstamp:31116056345 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.131250: rtcpu_nvcsi_intr: tstamp:31116070941 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.131251: rtcpu_nvcsi_intr: tstamp:31116071447 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.187447: rtcpu_nvcsi_intr: tstamp:31116662235 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.187451: rtcpu_nvcsi_intr: tstamp:31116676838 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.187452: rtcpu_nvcsi_intr: tstamp:31116677345 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.187453: rtcpu_nvcsi_intr: tstamp:31117268126 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.187454: rtcpu_nvcsi_intr: tstamp:31117282734 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.187455: rtcpu_nvcsi_intr: tstamp:31117283241 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.187455: rtcpu_nvcsi_intr: tstamp:31117874018 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.187456: rtcpu_nvcsi_intr: tstamp:31117888629 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.187456: rtcpu_nvcsi_intr: tstamp:31117889136 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.243440: rtcpu_nvcsi_intr: tstamp:31118479907 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.243444: rtcpu_nvcsi_intr: tstamp:31118494528 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.243445: rtcpu_nvcsi_intr: tstamp:31118495035 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.243446: rtcpu_nvcsi_intr: tstamp:31119085801 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.243446: rtcpu_nvcsi_intr: tstamp:31119100424 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.243447: rtcpu_nvcsi_intr: tstamp:31119100933 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.243449: rtcpu_nvcsi_intr: tstamp:31119691695 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.243451: rtcpu_nvcsi_intr: tstamp:31119706318 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.243452: rtcpu_nvcsi_intr: tstamp:31119706825 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.299476: rtcpu_nvcsi_intr: tstamp:31120297586 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.299480: rtcpu_nvcsi_intr: tstamp:31120312217 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.299481: rtcpu_nvcsi_intr: tstamp:31120312725 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.299482: rtcpu_nvcsi_intr: tstamp:31120903477 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.299482: rtcpu_nvcsi_intr: tstamp:31120918116 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.299483: rtcpu_nvcsi_intr: tstamp:31120918622 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.299483: rtcpu_nvcsi_intr: tstamp:31121509367 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.299484: rtcpu_nvcsi_intr: tstamp:31121524011 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.299485: rtcpu_nvcsi_intr: tstamp:31121524519 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.355439: rtcpu_nvcsi_intr: tstamp:31122115261 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.355443: rtcpu_nvcsi_intr: tstamp:31122129906 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.355444: rtcpu_nvcsi_intr: tstamp:31122130414 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.355445: rtcpu_nvcsi_intr: tstamp:31122721153 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.355446: rtcpu_nvcsi_intr: tstamp:31122735805 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.355446: rtcpu_nvcsi_intr: tstamp:31122736309 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.355448: rtcpu_nvcsi_intr: tstamp:31123327042 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.355448: rtcpu_nvcsi_intr: tstamp:31123341700 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.355449: rtcpu_nvcsi_intr: tstamp:31123342208 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.411441: rtcpu_nvcsi_intr: tstamp:31123932934 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.411445: rtcpu_nvcsi_intr: tstamp:31123947599 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.411446: rtcpu_nvcsi_intr: tstamp:31123948105 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.411447: rtcpu_nvcsi_intr: tstamp:31124538828 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.411448: rtcpu_nvcsi_intr: tstamp:31124553494 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.411448: rtcpu_nvcsi_intr: tstamp:31124554000 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.411449: rtcpu_nvcsi_intr: tstamp:31125144718 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.411450: rtcpu_nvcsi_intr: tstamp:31125159389 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.411450: rtcpu_nvcsi_intr: tstamp:31125159897 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.467445: rtcpu_nvcsi_intr: tstamp:31125750609 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.467450: rtcpu_nvcsi_intr: tstamp:31125765284 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.467450: rtcpu_nvcsi_intr: tstamp:31125765792 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.467451: rtcpu_nvcsi_intr: tstamp:31126356500 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.467452: rtcpu_nvcsi_intr: tstamp:31126371183 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.467453: rtcpu_nvcsi_intr: tstamp:31126371690 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.467453: rtcpu_nvcsi_intr: tstamp:31126962394 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.467454: rtcpu_nvcsi_intr: tstamp:31126977077 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.467455: rtcpu_nvcsi_intr: tstamp:31126977585 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.523258: rtcpu_nvcsi_intr: tstamp:31127568284 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.523261: rtcpu_nvcsi_intr: tstamp:31127582976 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.523261: rtcpu_nvcsi_intr: tstamp:31127583480 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.523262: rtcpu_nvcsi_intr: tstamp:31128174175 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.523262: rtcpu_nvcsi_intr: tstamp:31128188871 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.523263: rtcpu_nvcsi_intr: tstamp:31128189379 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.523264: rtcpu_nvcsi_intr: tstamp:31128780069 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.523265: rtcpu_nvcsi_intr: tstamp:31128794766 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.523265: rtcpu_nvcsi_intr: tstamp:31128795274 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.579268: rtcpu_nvcsi_intr: tstamp:31129385960 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.579272: rtcpu_nvcsi_intr: tstamp:31129400657 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.579273: rtcpu_nvcsi_intr: tstamp:31129401164 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.579274: rtcpu_nvcsi_intr: tstamp:31129991851 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.579275: rtcpu_nvcsi_intr: tstamp:31130006551 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.579275: rtcpu_nvcsi_intr: tstamp:31130007057 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.579276: rtcpu_nvcsi_intr: tstamp:31130597742 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.579277: rtcpu_nvcsi_intr: tstamp:31130612442 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.579277: rtcpu_nvcsi_intr: tstamp:31130612949 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.635443: rtcpu_nvcsi_intr: tstamp:31131203632 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.635446: rtcpu_nvcsi_intr: tstamp:31131218332 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.635447: rtcpu_nvcsi_intr: tstamp:31131218840 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.635447: rtcpu_nvcsi_intr: tstamp:31131809523 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.635448: rtcpu_nvcsi_intr: tstamp:31131824223 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.635449: rtcpu_nvcsi_intr: tstamp:31131824730 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.691236: rtcpu_nvcsi_intr: tstamp:31132415417 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.691236: rtcpu_nvcsi_intr: tstamp:31132430118 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.691237: rtcpu_nvcsi_intr: tstamp:31132430625 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.691237: rtcpu_nvcsi_intr: tstamp:31133021308 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.691238: rtcpu_nvcsi_intr: tstamp:31133036008 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.691238: rtcpu_nvcsi_intr: tstamp:31133036512 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.691238: rtcpu_nvcsi_intr: tstamp:31133627202 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.691239: rtcpu_nvcsi_intr: tstamp:31133641899 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.691240: rtcpu_nvcsi_intr: tstamp:31133642406 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.747432: rtcpu_nvcsi_intr: tstamp:31134233092 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.747436: rtcpu_nvcsi_intr: tstamp:31134247793 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.747437: rtcpu_nvcsi_intr: tstamp:31134248299 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.747438: rtcpu_nvcsi_intr: tstamp:31134838983 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.747438: rtcpu_nvcsi_intr: tstamp:31134853680 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.747439: rtcpu_nvcsi_intr: tstamp:31134854190 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.747440: rtcpu_nvcsi_intr: tstamp:31135444874 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.747441: rtcpu_nvcsi_intr: tstamp:31135459575 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.747441: rtcpu_nvcsi_intr: tstamp:31135460081 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.803444: rtcpu_nvcsi_intr: tstamp:31136050768 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.803449: rtcpu_nvcsi_intr: tstamp:31136065465 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.803449: rtcpu_nvcsi_intr: tstamp:31136065972 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.803450: rtcpu_nvcsi_intr: tstamp:31136656658 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.803451: rtcpu_nvcsi_intr: tstamp:31136671356 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.803452: rtcpu_nvcsi_intr: tstamp:31136671863 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.803453: rtcpu_nvcsi_intr: tstamp:31137262550 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.803453: rtcpu_nvcsi_intr: tstamp:31137277250 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.803454: rtcpu_nvcsi_intr: tstamp:31137277757 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.859437: rtcpu_nvcsi_intr: tstamp:31137868444 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.859442: rtcpu_nvcsi_intr: tstamp:31137883141 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.859442: rtcpu_nvcsi_intr: tstamp:31137883648 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.859445: rtcpu_nvcsi_intr: tstamp:31138474334 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.859446: rtcpu_nvcsi_intr: tstamp:31138489031 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.859446: rtcpu_nvcsi_intr: tstamp:31138489539 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.859447: rtcpu_nvcsi_intr: tstamp:31139080225 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.859448: rtcpu_nvcsi_intr: tstamp:31139094925 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.859448: rtcpu_nvcsi_intr: tstamp:31139095430 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.915266: rtcpu_nvcsi_intr: tstamp:31139686116 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.915270: rtcpu_nvcsi_intr: tstamp:31139700817 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.915271: rtcpu_nvcsi_intr: tstamp:31139701323 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.915272: rtcpu_nvcsi_intr: tstamp:31140292008 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.915273: rtcpu_nvcsi_intr: tstamp:31140306707 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.915273: rtcpu_nvcsi_intr: tstamp:31140307214 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.915274: rtcpu_nvcsi_intr: tstamp:31140897900 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.915275: rtcpu_nvcsi_intr: tstamp:31140912598 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.915276: rtcpu_nvcsi_intr: tstamp:31140913105 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.971440: rtcpu_nvcsi_intr: tstamp:31141503791 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.971444: rtcpu_nvcsi_intr: tstamp:31141518492 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.971444: rtcpu_nvcsi_intr: tstamp:31141518998 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.971446: rtcpu_nvcsi_intr: tstamp:31142109682 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.971447: rtcpu_nvcsi_intr: tstamp:31142124382 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.971447: rtcpu_nvcsi_intr: tstamp:31142124889 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.971448: rtcpu_nvcsi_intr: tstamp:31142715572 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.971449: rtcpu_nvcsi_intr: tstamp:31142730273 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 967.971450: rtcpu_nvcsi_intr: tstamp:31142730781 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.027483: rtcpu_nvcsi_intr: tstamp:31143321463 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.027487: rtcpu_nvcsi_intr: tstamp:31143336167 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.027488: rtcpu_nvcsi_intr: tstamp:31143336674 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.027489: rtcpu_nvcsi_intr: tstamp:31143927353 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.027489: rtcpu_nvcsi_intr: tstamp:31143942058 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.027490: rtcpu_nvcsi_intr: tstamp:31143942565 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.027491: rtcpu_nvcsi_intr: tstamp:31144533240 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.027492: rtcpu_nvcsi_intr: tstamp:31144547949 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.027493: rtcpu_nvcsi_intr: tstamp:31144548456 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.083439: rtcpu_nvcsi_intr: tstamp:31145139134 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.083443: rtcpu_nvcsi_intr: tstamp:31145153840 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.083444: rtcpu_nvcsi_intr: tstamp:31145154347 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.083445: rtcpu_nvcsi_intr: tstamp:31145745028 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.083446: rtcpu_nvcsi_intr: tstamp:31145759734 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.083447: rtcpu_nvcsi_intr: tstamp:31145760240 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.083448: rtcpu_nvcsi_intr: tstamp:31146350915 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.083449: rtcpu_nvcsi_intr: tstamp:31146365624 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.083450: rtcpu_nvcsi_intr: tstamp:31146366130 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.139439: rtcpu_nvcsi_intr: tstamp:31146956806 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.139443: rtcpu_nvcsi_intr: tstamp:31146971515 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.139444: rtcpu_nvcsi_intr: tstamp:31146972022 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.139445: rtcpu_nvcsi_intr: tstamp:31147562700 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.139446: rtcpu_nvcsi_intr: tstamp:31147577406 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.139447: rtcpu_nvcsi_intr: tstamp:31147577913 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.195438: rtcpu_nvcsi_intr: tstamp:31148168590 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.195442: rtcpu_nvcsi_intr: tstamp:31148183296 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.195443: rtcpu_nvcsi_intr: tstamp:31148183804 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.195445: rtcpu_nvcsi_intr: tstamp:31148774483 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.195445: rtcpu_nvcsi_intr: tstamp:31148789187 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.195446: rtcpu_nvcsi_intr: tstamp:31148789697 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.195447: rtcpu_nvcsi_intr: tstamp:31149380375 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.195448: rtcpu_nvcsi_intr: tstamp:31149395081 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.195449: rtcpu_nvcsi_intr: tstamp:31149395588 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.251267: rtcpu_nvcsi_intr: tstamp:31149986266 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.251272: rtcpu_nvcsi_intr: tstamp:31150000972 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.251273: rtcpu_nvcsi_intr: tstamp:31150001479 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.251274: rtcpu_nvcsi_intr: tstamp:31150592156 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.251274: rtcpu_nvcsi_intr: tstamp:31150606867 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.251275: rtcpu_nvcsi_intr: tstamp:31150607373 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.251277: rtcpu_nvcsi_intr: tstamp:31151198051 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.251277: rtcpu_nvcsi_intr: tstamp:31151212757 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.251278: rtcpu_nvcsi_intr: tstamp:31151213264 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.307495: rtcpu_nvcsi_intr: tstamp:31151803941 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.307499: rtcpu_nvcsi_intr: tstamp:31151818648 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.307501: rtcpu_nvcsi_intr: tstamp:31151819155 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.307502: rtcpu_nvcsi_intr: tstamp:31152409833 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.307503: rtcpu_nvcsi_intr: tstamp:31152424541 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.307504: rtcpu_nvcsi_intr: tstamp:31152425045 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.307504: rtcpu_nvcsi_intr: tstamp:31153015725 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.307505: rtcpu_nvcsi_intr: tstamp:31153030433 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.307506: rtcpu_nvcsi_intr: tstamp:31153030939 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.363243: rtcpu_nvcsi_intr: tstamp:31153621616 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.363244: rtcpu_nvcsi_intr: tstamp:31153636323 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.363245: rtcpu_nvcsi_intr: tstamp:31153636830 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.363246: rtcpu_nvcsi_intr: tstamp:31154227508 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.363246: rtcpu_nvcsi_intr: tstamp:31154242214 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.363247: rtcpu_nvcsi_intr: tstamp:31154242720 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.363247: rtcpu_nvcsi_intr: tstamp:31154833399 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.363248: rtcpu_nvcsi_intr: tstamp:31154848108 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.363249: rtcpu_nvcsi_intr: tstamp:31154848616 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.419437: rtcpu_nvcsi_intr: tstamp:31155439289 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.419442: rtcpu_nvcsi_intr: tstamp:31155454004 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.419443: rtcpu_nvcsi_intr: tstamp:31155454510 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.419444: rtcpu_nvcsi_intr: tstamp:31156045184 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.419445: rtcpu_nvcsi_intr: tstamp:31156060121 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.419446: rtcpu_nvcsi_intr: tstamp:31156060475 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.419446: rtcpu_nvcsi_intr: tstamp:31156651074 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.419447: rtcpu_nvcsi_intr: tstamp:31156666018 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.419449: rtcpu_nvcsi_intr: tstamp:31156666374 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.475432: rtcpu_nvcsi_intr: tstamp:31157256965 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.475436: rtcpu_nvcsi_intr: tstamp:31157271915 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.475437: rtcpu_nvcsi_intr: tstamp:31157272268 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.475437: rtcpu_nvcsi_intr: tstamp:31157862859 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.475438: rtcpu_nvcsi_intr: tstamp:31157877810 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.475439: rtcpu_nvcsi_intr: tstamp:31157878164 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.475439: rtcpu_nvcsi_intr: tstamp:31158468750 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.475440: rtcpu_nvcsi_intr: tstamp:31158483708 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.475441: rtcpu_nvcsi_intr: tstamp:31158484062 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.531437: rtcpu_nvcsi_intr: tstamp:31159074640 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.531441: rtcpu_nvcsi_intr: tstamp:31159089603 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.531442: rtcpu_nvcsi_intr: tstamp:31159089954 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.531443: rtcpu_nvcsi_intr: tstamp:31159680530 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.531444: rtcpu_nvcsi_intr: tstamp:31159695499 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.531444: rtcpu_nvcsi_intr: tstamp:31159695853 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.531445: rtcpu_nvcsi_intr: tstamp:31160286422 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.531445: rtcpu_nvcsi_intr: tstamp:31160301398 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.531446: rtcpu_nvcsi_intr: tstamp:31160301752 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.587442: rtcpu_nvcsi_intr: tstamp:31160892316 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.587447: rtcpu_nvcsi_intr: tstamp:31160907296 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.587448: rtcpu_nvcsi_intr: tstamp:31160907651 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.587449: rtcpu_nvcsi_intr: tstamp:31161498209 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.587449: rtcpu_nvcsi_intr: tstamp:31161513191 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.587450: rtcpu_nvcsi_intr: tstamp:31161513546 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.587451: rtcpu_nvcsi_intr: tstamp:31162104101 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.587452: rtcpu_nvcsi_intr: tstamp:31162119087 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.587453: rtcpu_nvcsi_intr: tstamp:31162119441 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.643482: rtcpu_nvcsi_intr: tstamp:31162709991 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.643486: rtcpu_nvcsi_intr: tstamp:31162724982 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.643487: rtcpu_nvcsi_intr: tstamp:31162725336 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.643488: rtcpu_nvcsi_intr: tstamp:31163315882 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.643489: rtcpu_nvcsi_intr: tstamp:31163330881 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.643490: rtcpu_nvcsi_intr: tstamp:31163331235 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.699439: rtcpu_nvcsi_intr: tstamp:31163921773 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.699443: rtcpu_nvcsi_intr: tstamp:31163936776 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.699444: rtcpu_nvcsi_intr: tstamp:31163937130 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.699445: rtcpu_nvcsi_intr: tstamp:31164527663 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.699446: rtcpu_nvcsi_intr: tstamp:31164542674 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.699447: rtcpu_nvcsi_intr: tstamp:31164543028 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.699448: rtcpu_nvcsi_intr: tstamp:31165133554 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.699449: rtcpu_nvcsi_intr: tstamp:31165148573 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.699449: rtcpu_nvcsi_intr: tstamp:31165148918 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.755434: rtcpu_nvcsi_intr: tstamp:31165739448 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.755439: rtcpu_nvcsi_intr: tstamp:31165754469 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.755440: rtcpu_nvcsi_intr: tstamp:31165754818 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.755441: rtcpu_nvcsi_intr: tstamp:31166345339 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.755442: rtcpu_nvcsi_intr: tstamp:31166360364 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.755443: rtcpu_nvcsi_intr: tstamp:31166360721 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.755444: rtcpu_nvcsi_intr: tstamp:31166951234 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.755444: rtcpu_nvcsi_intr: tstamp:31166966262 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.755445: rtcpu_nvcsi_intr: tstamp:31166966617 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
vi-output, ov56-2467 [001] … 968.760412: tegra_channel_capture_setup: vnc_id 0 W 640 H 480 fmt 10
gst-launch-1.0-2461 [006] … 968.760711: tegra_channel_set_stream: enable : 0x0
gst-launch-1.0-2461 [006] … 968.760714: tegra_channel_set_stream: ov5693 2-006d : 0x0
gst-launch-1.0-2461 [006] … 968.760717: tegra_channel_set_stream: 13e00000.host1x:nvcsi@15a00000- : 0x0
gst-launch-1.0-2461 [006] … 968.760720: csi_s_stream: enable : 0x0
gst-launch-1.0-2461 [002] … 968.763627: tegra_channel_set_power: ov5693 2-006d : 0x0
gst-launch-1.0-2461 [002] … 968.763639: camera_common_s_power: status : 0x0
gst-launch-1.0-2461 [002] … 968.763645: tegra_channel_set_power: 13e00000.host1x:nvcsi@15a00000- : 0x0
gst-launch-1.0-2461 [002] … 968.763648: csi_s_power: enable : 0x0
kworker/5:2-369 [005] … 968.811282: rtcpu_nvcsi_intr: tstamp:31167556905 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.811292: rtcpu_nvcsi_intr: tstamp:31167562472 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x00000010
kworker/5:2-369 [005] … 968.811294: rtcpu_nvcsi_intr: tstamp:31167572175 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
kworker/5:2-369 [005] … 968.811294: rtcpu_nvcsi_intr: tstamp:31167572664 class:GLOBAL type:PHY_INTR0 phy:3 cil:0 st:0 vc:0 status:0x0a000000
Looks like deskew calibration issue.
Skew calibration is required if sensor or deserializer is using DPHY, and the output data rate is > 1.5Gbps.
An initiation deskew signal should be sent by sensor or deserializer to perform the skew calibration. If the deskew signals is not sent, the receiver will stall, and the capture will time out.
You can calculate the output data rate with the following equation:
Output data rate = (sensor or deserializer pixel clock in hertz) * (bits per pixel) / (number of CSI lanes)
is deskew calibration required for above configuration? how to configure it?
Modify the serdes_pix_clk_hz and pix_clk_hz to make the output data rate > 1.5
setting serdes_pix_clk_hz equal to pix_clk_hz worked. now i am getting video. how to calculate serdes_pix_clk_hz?
You can remove the serdes_pix_clk_hz but only use pix_clk_hz for Orin on your case.
