On the other end of the fleet spectrum, same conclusion. I’ve been tracking this in Grafana for six months.
Setup: 4× GB10 Sparks + 2× RTX 5070 + 1× RTX 5080, ~$20K at the counter. Everything routes through LiteLLM, so my local token counts are exact and whatever still goes to cloud gets priced at API-equivalent updated weekly.
Six months in (May 20 → Nov 20): 16.8B tokens served locally, $68.8K avoided at API list prices (deepseek-v4-flash doing ~60% of the work, priced against Opus 4.8). Cloud API-equivalent spend over the same window was $61.8K — almost all of it from before the fleet was fully routed. I’ve been using cloud to bootstrap an enterprise lab stack at home.
Migration timeline approximates:
Jun: 14% local, $8.3K cloud
Jul: 20% local, $31.4K cloud ← peak
Aug: 71% local, $8.7K cloud ← routing flipped
Oct: 94% local, $1.0K cloud
Nov: 89% local, $1.1K cloud
Hardware “paid for itself” around August–September. At the current run rate it re-covers the whole fleet’s cost every month or two.
Usage: multi-agent dev crews, a 24/7 research agent, an OSINT enrichment pipeline over ~1,100 feeds, plus day-to-day coding. Same point as VCR — the workloads that burn tokens around the clock are exactly the ones you can’t put on a meter and are split between cpu and GPU work.
My “avoided cost” depends on which cloud model you call the analogue. Map deepseek-v4-flash to a mid-tier model instead of Opus and the dollar figure shrinks a lot. The number I’m focused on is the local, sovereign capture rate — 90%ish of the work now runs on hardware I own, and the cloud bill is down ~95%. Power isn’t on the dashboard but it’s low at NH rates. ( I use the higher numbers to justify boxes showing up with the wife ;) )
Congrats on the 10B on a single box. I can’t leave the stack alone long enough playing with other models to consolidate.
Large caveat hiding back in the closet: Majority of my cloud token usage outside of Anthropic is work subsidized. I front loaded a lot of that in June through August knowing they’d likely turn the tap to a trickle quickly.
