Start of NVIDIA bug report log file. Please include this file, along
with a detailed description of your problem, when reporting a graphics
driver bug via the NVIDIA Linux forum (see devtalk.nvidia.com)
or by sending email to ‘linux-bugs@nvidia.com’.
nvidia-bug-report.sh Version: 15313852
Date: Mon Sep 9 16:08:49 MDT 2013
uname: Linux localhost.localdomain 2.6.32-358.el6.x86_64 #1 SMP Fri Feb 22 00:31:26 UTC 2013 x86_64 x86_64 x86_64 GNU/Linux
command line flags:
*** /etc/issue
*** ls: -rw-r–r–. 1 root root 47 2013-02-25 01:57:43.000000000 -0700 /etc/issue
CentOS release 6.4 (Final)
Kernel \r on an \m
*** /etc/redhat-release
*** ls: lrwxrwxrwx. 1 root root 14 2013-08-27 17:55:06.062952960 -0600 /etc/redhat-release → centos-release
*** /var/log/nvidia-installer.log
*** ls: -rw-r–r-- 1 root root 51653 2013-09-09 15:40:26.985293448 -0600 /var/log/nvidia-installer.log
nvidia-installer log file ‘/var/log/nvidia-installer.log’
creation time: Mon Sep 9 15:39:29 2013
installer version: 319.49
PATH: /usr/lib64/qt-3.3/bin:/opt/intel/composer_xe_2013.5.192/bin/intel64:/opt/intel/composer_xe_2013.5.192/mpirt/bin/intel64:/opt/intel/composer_xe_2013.5.192/bin/intel64:/opt/intel/composer_xe_2013.5.192/bin/intel64_mic:/opt/intel/composer_xe_2013.5.192/debugger/gui/intel64:/usr/NX/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/cuda-5.5/bin:/opt/intel/mic/bin:/root/bin
nvidia-installer command line:
./nvidia-installer
Using: nvidia-installer ncurses user interface
→ License accepted.
→ Installing NVIDIA driver version 319.49.
→ There appears to already be a driver installed on your system (version: 319.49). As part of installing this driver (version: 319.49), the existing driver will be uninstalled. Are you sure you want to continue? (‘no’ will abort installation) (Answer: Yes)
→ Performing CC sanity check with CC=“cc”.
→ Kernel source path: ‘/lib/modules/2.6.32-358.el6.x86_64/source’
→ Kernel output path: ‘/lib/modules/2.6.32-358.el6.x86_64/build’
→ Performing rivafb check.
→ Performing nvidiafb check.
→ Performing Xen check.
→ Cleaning kernel module build directory.
executing: ‘cd ./kernel; make clean’…
→ Building kernel module:
executing: ‘cd ./kernel; make module SYSSRC=/lib/modules/2.6.32-358.el6.x86_64/source SYSOUT=/lib/modules/2.6.32-358.el6.x86_64/build’…
NVIDIA: calling KBUILD…
make -C /lib/modules/2.6.32-358.el6.x86_64/build
KBUILD_SRC=/usr/src/kernels/2.6.32-358.el6.x86_64
KBUILD_EXTMOD=“/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel” -f /usr/src/kernels/2.6.32-358.el6.x86_64/Makefile
modules
test -e include/linux/autoconf.h -a -e include/config/auto.conf || (
echo;
echo " ERROR: Kernel configuration is invalid.“;
echo " include/linux/autoconf.h or include/config/auto.conf are missing.”;
echo " Run ‘make oldconfig && make prepare’ on kernel src to fix it.“;
echo;
/bin/false)
mkdir -p /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_versions ; rm -f /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_versions/*
make -f /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/Makefile.build obj=/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODUL
E -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s” -D"KBUILD_BASENAME=KBUILD_STR(nv)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-acpi.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trig
raphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_acpi)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBU
G_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-acpi.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-acpi.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-acpi.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-chrdev.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-prot
ector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_chrdev)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-chrdev.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-chrdev.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-chrdev.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-cray.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fn
o-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_cray)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-cray.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-cray.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-cray.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-drm.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -
Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_drm)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-drm.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-drm.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-drm.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-gvi.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/ker
nel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_
STR(nv_gvi)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-gvi.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-gvi.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-gvi.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-i2c.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -fu
nit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_i2c)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-i2c.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-i2c.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-i2c.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-mempool.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-large
r-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_mempool)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-mempool.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-mempool.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-mempool.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-mlock.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NV
IDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_mlock)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-mlock.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-mlock.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-mlock.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-mmap.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/l
inux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D
linux -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_mmap)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-mmap.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-mmap.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-mmap.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-p2p.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-p
ointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_p2p)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-p2p.o /tmp/selfgz12662
/NVIDIA-Linux-x86_64-319.49/kernel/nv-p2p.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-p2p.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-pat.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous
-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_pat)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-pat.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-pat.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-pat.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-procfs.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwa
rf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_procfs)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-procfs.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-procfs.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-procfs.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-usermap.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized
-mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_usermap)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-usermap.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-usermap.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-usermap.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-vm.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror
-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_vm)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz1
2662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-vm.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-vm.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-vm.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-vtophys.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=
1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nv_vtophys)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_nv-vtophys.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-vtophys.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-vtophys.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.os-interface.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-c
alls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_interface)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_os-interface.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-interface.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-interface.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.os-pci.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error
-D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_pci)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_os-pci.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-pci.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-pci.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.os-registry.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -W
all -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_registry)"
-D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_os-registry.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-registry.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-registry.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.os-smp.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -f
unit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_smp)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_os-smp.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-smp.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-smp.o”;
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.os-usermap.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larg
er-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statement -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -DMODULE -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(os_usermap)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.tmp_os-usermap.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-usermap.c
set -e ; perl /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/recordmcount.pl “x86_64” “64” “objdump” “objcopy” “cc” “ld” “nm” “” “” “1” “/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-usermap.o”;
ld -m elf_x86_64 -r -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nvidia.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-kernel.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-acpi.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-chrdev.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-cray.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-drm.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-gvi.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-i2c.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-mempool.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-mlock.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-mmap.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-p2p.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-pat.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-procfs.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-usermap.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-vm.o /tmp/selfgz1
2662/NVIDIA-Linux-x86_64-319.49/kernel/nv-vtophys.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-interface.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-pci.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-registry.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-smp.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/os-usermap.o ; scripts/mod/modpost /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nvidia.o
(cat /dev/null; echo kernel//tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nvidia.ko;) > /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/modules.order
make -f /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/Makefile.modpost
scripts/mod/modpost -m -a -i /usr/src/kernels/2.6.32-358.el6.x86_64/Module.symvers -I /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/Module.symvers -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/Module.symvers -w -s
WARNING: could not find /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nv-kernel.o.cmd for /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nv-kernel.o
cc -Wp,-MD,/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/.nvidia.mod.o.d -nostdinc -isystem /usr/lib/gcc/x86_64-redhat-linux/4.4.7/include -Iinclude -Iinclude2 -I/usr/src/kernels/2.6.32-358.el6.x86_64/include -I/usr/src/kernels/2.6.32-358.el6.x86_64/arch/x86/include -include include/linux/autoconf.h -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -D__KERNEL__ -Wall -Wundef -Wstrict-prototypes -Wno-trigraphs -fno-strict-aliasing -fno-common -Werror-implicit-function-declaration -Wno-format-security -fno-delete-null-pointer-checks -O2 -m64 -mtune=generic -mno-red-zone -mcmodel=kernel -funit-at-a-time -maccumulate-outgoing-args -fstack-protector -DCONFIG_AS_CFI=1 -DCONFIG_AS_CFI_SIGNAL_FRAME=1 -DCONFIG_AS_CFI_SECTIONS=1 -pipe -Wno-sign-compare -fno-asynchronous-unwind-tables -mno-sse -mno-mmx -mno-sse2 -mno-3dnow -Wframe-larger-than=2048 -Wno-unused-but-set-variable -fno-omit-frame-pointer -fno-optimize-sibling-calls -g -pg -Wdeclaration-after-statem
ent -Wno-pointer-sign -fno-strict-overflow -fno-dwarf2-cfi-asm -fconserve-stack -I/tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel -Wall -MD -Wsign-compare -Wno-cast-qual -Wno-error -D__KERNEL__ -DMODULE -DNVRM -DNV_VERSION_STRING="319.49" -Wno-unused-function -Wuninitialized -mno-red-zone -mcmodel=kernel -UDEBUG -U_DEBUG -DNDEBUG -D__linux__ -D"KBUILD_STR(s)=#s" -D"KBUILD_BASENAME=KBUILD_STR(nvidia.mod)" -D"KBUILD_MODNAME=KBUILD_STR(nvidia)" -D"DEBUG_HASH=51" -D"DEBUG_HASH2=53" -DMODULE -c -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nvidia.mod.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nvidia.mod.c
ld -r -m elf_x86_64 -T /usr/src/kernels/2.6.32-358.el6.x86_64/scripts/module-common.lds --build-id -o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nvidia.ko.unsigned /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nvidia.o /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nvidia.mod.o
cp /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nvidia.ko.unsigned /tmp/selfgz12662/NVIDIA-Linux-x86_64-319.49/kernel/nvidia.ko
NVIDIA: left KBUILD.
→ done.
→ Kernel module compilation complete.
→ Unable to determine if Secure Boot is enabled: No such file or directory
→ Kernel messages:
usb 2-1.4: configuration #1 chosen from 1 choice
input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/input/input106
generic-usb 0003:046D:C05A.0060: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.0-1.4/input0
usb 2-1.4: USB disconnect, device number 97
usb 2-1.4: new low speed USB device number 98 using ehci_hcd
usb 2-1.4: New USB device found, idVendor=046d, idProduct=c05a
usb 2-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 2-1.4: Product: USB Optical Mouse
usb 2-1.4: Manufacturer: Logitech
input: Logitech USB Optical Mouse as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.4/2-1.4:1.0/input/input107
generic-usb 0003:046D:C05A.0061: input,hidraw2: USB HID v1.11 Mouse [Logitech USB Optical Mouse] on usb-0000:00:1d.0-1.4/input0
[drm] Initialized drm 1.1.0 20060810
nvidia: module license ‘NVIDIA’ taints kernel.
Disabling lock debugging due to kernel taint
nvidia 0000:03:00.0: PCI INT A → GSI 32 (level, low) → IRQ 32
nvidia 0000:03:00.0: setting latency timer to 64
nvidia 0000:06:00.0: PCI INT A → GSI 40 (level, low) → IRQ 40
nvidia 0000:06:00.0: setting latency timer to 64
nvidia 0000:07:00.0: PCI INT A → GSI 40 (level, low) → IRQ 40
nvidia 0000:07:00.0: setting latency timer to 64
NVRM: loading NVIDIA UNIX x86_64 Kernel Module 319.49 Tue Aug 13 21:15:53 PDT 2013
nvidia 0000:03:00.0: PCI INT A disabled
nvidia 0000:06:00.0: PCI INT A disabled
nvidia 0000:07:00.0: PCI INT A disabled
→ Installing both new and classic TLS OpenGL libraries.
→ Installing both new and classic TLS 32bit OpenGL libraries.
→ Install NVIDIA’s 32-bit compatibility OpenGL libraries? (Answer: Yes)
→ Parsing log file:
→ done.
→ Validating previous installation:
→ The previously installed file ‘/usr/lib64/libnvidia-glcore.so.319.49’ has a different checksum (1818438496l) after running prelink -u than when it was installed (865306691l).
→ Un-prelinking unsuccessful: ‘/usr/lib64/libnvidia-glcore.so.319.49’ will not be uninstalled.
→ The previously installed file ‘/usr/lib64/libGL.so.319.49’ has a different checksum (1797709605l) after running prelink -u than when it was installed (3653957337l).
→ Un-prelinking unsuccessful: ‘/usr/lib64/libGL.so.319.49’ will not be uninstalled.
→ The previously installed file ‘/usr/lib64/tls/libnvidia-tls.so.319.49’ has a different checksum (2322985291l) after running prelink -u than when it was installed (1889338259l).
→ Un-prelinking unsuccessful: ‘/usr/lib64/tls/libnvidia-tls.so.319.49’ will not be uninstalled.
→ The previously installed file ‘/usr/bin/nvidia-smi’ has a different checksum (3385889403l) after running prelink -u than when it was installed (316749630l).
→ Un-prelinking unsuccessful: ‘/usr/bin/nvidia-smi’ will not be uninstalled.
→ The previously installed file ‘/usr/lib64/libnvidia-ml.so.319.49’ has a different checksum (2424284001l) after running prelink -u than when it was installed (2359376131l).
→ Un-prelinking unsuccessful: ‘/usr/lib64/libnvidia-ml.so.319.49’ will not be uninstalled.
→ The previously installed file ‘/usr/bin/nvidia-debugdump’ has a different checksum (1463836253l) after running prelink -u than when it was installed (3201024422l).
→ Un-prelinking unsuccessful: ‘/usr/bin/nvidia-debugdump’ will not be uninstalled.
→ The previously installed file ‘/usr/bin/nvidia-xconfig’ has a different checksum (2247261526l) after running prelink -u than when it was installed (2981228000l).
→ Un-prelinking unsuccessful: ‘/usr/bin/nvidia-xconfig’ will not be uninstalled.
→ The previously installed file ‘/usr/bin/nvidia-settings’ has a different checksum (1685712032l) after running prelink -u than when it was installed (1036688736l).
→ Un-prelinking unsuccessful: ‘/usr/bin/nvidia-settings’ will not be uninstalled.
→ The previously installed file ‘/usr/bin/nvidia-installer’ has a different checksum (505391532l) after running prelink -u than when it was installed (4060222043l).
→ Un-prelinking unsuccessful: ‘/usr/bin/nvidia-installer’ will not be uninstalled.
→ The previously installed file ‘/usr/bin/nvidia-persistenced’ has a different checksum (502568592l) after running prelink -u than when it was installed (4142514473l).
→ Un-prelinking unsuccessful: ‘/usr/bin/nvidia-persistenced’ will not be uninstalled.
→ The previously installed file ‘/usr/bin/nvidia-modprobe’ has a different checksum (4270827926l) after running prelink -u than when it was installed (1949043823l).
→ Un-prelinking unsuccessful: ‘/usr/bin/nvidia-modprobe’ will not be uninstalled.
→ The previously installed file ‘/usr/bin/nvidia-cuda-mps-control’ has a different checksum (376783785l) after running prelink -u than when it was installed (2189106902l).
→ Un-prelinking unsuccessful: ‘/usr/bin/nvidia-cuda-mps-control’ will not be uninstalled.
→ The previously installed file ‘/usr/bin/nvidia-cuda-mps-server’ has a different checksum (421073012l) after running prelink -u than when it was installed (3152863439l).
→ Un-prelinking unsuccessful: ‘/usr/bin/nvidia-cuda-mps-server’ will not be uninstalled.
→ The previously installed file ‘/usr/lib64/libGL.la’ has a different checksum (1291305003l) after running prelink -u than when it was installed (3873987999l).
→ Un-prelinking unsuccessful: ‘/usr/lib64/libGL.la’ will not be uninstalled.
→ done.
WARNING: Your driver installation has been altered since it was initially installed; this may happen, for example, if you have since installed the NVIDIA driver through a mechanism other than nvidia-installer (such as your distribution’s native package management system). nvidia-installer will attempt to uninstall as best it can. Please see the file ‘/var/log/nvidia-installer.log’ for details.
→ Uninstalling NVIDIA Accelerated Graphics Driver for Linux-x86_64 (1.0-31949 (319.49)):
→ done.
→ Uninstallation of existing driver: NVIDIA Accelerated Graphics Driver for Linux-x86_64 (319.49) is complete.
→ Searching for conflicting X files:
→ done.
→ Searching for conflicting OpenGL files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (319.49):
executing: ‘/sbin/ldconfig’…
executing: ‘/sbin/depmod -aq’…
→ done.
→ Driver file installation is complete.
→ Running post-install sanity check:
→ done.
→ Post-install sanity check passed.
→ Shared memory test passed.
→ Running runtime sanity check:
→ done.
→ Runtime sanity check passed.
→ Installation of the kernel module for the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version 319.49) is now complete.
*** /var/log/Xorg.0.log
*** ls: -rw-r–r-- 1 root root 5528 2013-09-09 16:02:09.931291064 -0600 /var/log/Xorg.0.log
[ 9886.137]
X.Org X Server 1.13.0
Release Date: 2012-09-05
[ 9886.137] X Protocol Version 11, Revision 0
[ 9886.137] Build Operating System: c6b7 2.6.32-220.el6.x86_64
[ 9886.137] Current Operating System: Linux localhost.localdomain 2.6.32-358.el6.x86_64 #1 SMP Fri Feb 22 00:31:26 UTC 2013 x86_64
[ 9886.137] Kernel command line: ro root=UUID=d29baf6b-77ef-4613-a767-27fd3cabd9d9 rd_NO_LUKS rd_NO_LVM LANG=en_US.UTF-8 rd_NO_MD SYSFONT=latarcyrheb-sun16 crashkernel=133M@0M KEYBOARDTYPE=pc KEYTABLE=us rd_NO_DM rhgb quiet rdblacklist=nouveau
[ 9886.137] Build Date: 22 February 2013 11:30:37AM
[ 9886.139] Build ID: xorg-x11-server 1.13.0-11.el6.centos
[ 9886.139] Current version of pixman: 0.26.2
[ 9886.139] Before reporting problems, check http://wiki.centos.org/Documentation
to make sure that you have the latest version.
[ 9886.140] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 9886.142] (==) Log file: “/var/log/Xorg.0.log”, Time: Mon Sep 9 16:02:09 2013
[ 9886.142] (==) Using config file: “/etc/X11/xorg.conf”
[ 9886.142] (==) ServerLayout “Layout0”
[ 9886.142] () |–>Screen “Screen0” (0)
[ 9886.142] () | |–>Monitor “Monitor0”
[ 9886.143] () | |–>Device “Device0”
[ 9886.143] () |–>Input Device “Keyboard0”
[ 9886.143] () |–>Input Device “Mouse0”
[ 9886.143] (==) Automatically adding devices
[ 9886.143] (==) Automatically enabling devices
[ 9886.143] (==) Not automatically adding GPU devices
[ 9886.143] (**) FontPath set to:
/usr/share/fonts/default/Type1,
catalogue:/etc/X11/fontpath.d,
built-ins
[ 9886.143] (==) ModulePath set to “/usr/lib64/xorg/modules”
[ 9886.143] (WW) Hotplugging is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
[ 9886.143] (WW) Disabling Keyboard0
[ 9886.143] (WW) Disabling Mouse0
[ 9886.143] (II) Loader magic: 0x810020
[ 9886.143] (II) Module ABI versions:
[ 9886.143] X.Org ANSI C Emulation: 0.4
[ 9886.143] X.Org Video Driver: 13.1
[ 9886.143] X.Org XInput driver : 18.0
[ 9886.143] X.Org Server Extension : 7.0
[ 9886.147] (–) PCI: (0:3:0:0) 10de:1022:10de:0982 rev 161, Mem @ 0xb6000000/16777216, 0x380fe0000000/268435456, 0x380ff0000000/33554432, BIOS @ 0x???/524288
[ 9886.147] (–) PCI: (0:6:0:0) 10de:118f:10de:097f rev 161, Mem @ 0xb2000000/16777216, 0x380fc0000000/268435456, 0x380fd0000000/33554432, BIOS @ 0x???/65536
[ 9886.147] (–) PCI: (0:7:0:0) 10de:118f:10de:097f rev 161, Mem @ 0xb1000000/16777216, 0x380fa0000000/268435456, 0x380fb0000000/33554432, BIOS @ 0x???/65536
[ 9886.147] (–) PCI:*(0:15:0:0) 1a03:2000:1043:84eb rev 33, Mem @ 0xb4000000/16777216, 0xb5000000/131072, I/O @ 0x00006000/128, BIOS @ 0x???/131072
[ 9886.147] Initializing built-in extension Generic Event Extension
[ 9886.147] Initializing built-in extension SHAPE
[ 9886.148] Initializing built-in extension MIT-SHM
[ 9886.148] Initializing built-in extension XInputExtension
[ 9886.148] Initializing built-in extension XTEST
[ 9886.148] Initializing built-in extension BIG-REQUESTS
[ 9886.149] Initializing built-in extension SYNC
[ 9886.149] Initializing built-in extension XKEYBOARD
[ 9886.149] Initializing built-in extension XC-MISC
[ 9886.150] Initializing built-in extension XINERAMA
[ 9886.150] Initializing built-in extension XFIXES
[ 9886.150] Initializing built-in extension RENDER
[ 9886.150] Initializing built-in extension RANDR
[ 9886.151] Initializing built-in extension COMPOSITE
[ 9886.151] Initializing built-in extension DAMAGE
[ 9886.151] Initializing built-in extension MIT-SCREEN-SAVER
[ 9886.151] Initializing built-in extension DOUBLE-BUFFER
[ 9886.152] Initializing built-in extension RECORD
[ 9886.152] Initializing built-in extension DPMS
[ 9886.152] Initializing built-in extension X-Resource
[ 9886.152] Initializing built-in extension XVideo
[ 9886.153] Initializing built-in extension XVideo-MotionCompensation
[ 9886.153] Initializing built-in extension SELinux
[ 9886.153] Initializing built-in extension XFree86-VidModeExtension
[ 9886.153] Initializing built-in extension XFree86-DGA
[ 9886.154] Initializing built-in extension XFree86-DRI
[ 9886.154] Initializing built-in extension DRI2
[ 9886.154] (II) LoadModule: “glx”
[ 9886.154] (II) Loading /usr/lib64/xorg/modules/extensions/libglx.so
[ 9886.166] (II) Module glx: vendor=“NVIDIA Corporation”
[ 9886.166] compiled for 4.0.2, module version = 1.0.0
[ 9886.166] Module class: X.Org Server Extension
[ 9886.166] (II) NVIDIA GLX Module 319.49 Tue Aug 13 19:53:22 PDT 2013
[ 9886.166] Loading extension GLX
[ 9886.166] (II) LoadModule: “nvidia”
[ 9886.167] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 9886.167] (II) Module nvidia: vendor=“NVIDIA Corporation”
[ 9886.167] compiled for 4.0.2, module version = 1.0.0
[ 9886.167] Module class: X.Org Video Driver
[ 9886.167] (II) NVIDIA dlloader X Driver 319.49 Tue Aug 13 19:34:58 PDT 2013
[ 9886.167] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 9886.167] (–) using VT number 7
[ 9886.171] (EE) No devices detected.
[ 9886.171]
Fatal server error:
[ 9886.171] no screens found
[ 9886.171] (EE)
Please consult the CentOS support
at http://wiki.centos.org/Documentation
for help.
[ 9886.171] (EE) Please also check the log file at “/var/log/Xorg.0.log” for additional information.
[ 9886.171] (EE)
*** /etc/X11/xorg.conf
*** ls: -rw-r–r-- 1 root root 1483 2013-09-09 15:54:01.433291946 -0600 /etc/X11/xorg.conf
nvidia-xconfig: X configuration file generated by nvidia-xconfig
nvidia-xconfig: version 319.49 (buildmeister@swio-display-x64-rhel04-03) Tue Aug 13 20:42:18 PDT 2013
Section “ServerLayout”
Identifier “Layout0”
Screen 0 “Screen0”
InputDevice “Keyboard0” “CoreKeyboard”
InputDevice “Mouse0” “CorePointer”
EndSection
Section “Files”
FontPath “/usr/share/fonts/default/Type1”
EndSection
Section “InputDevice”
# generated from default
Identifier “Mouse0”
Driver “mouse”
Option “Protocol” “auto”
Option “Device” “/dev/input/mice”
Option “Emulate3Buttons” “no”
Option “ZAxisMapping” “4 5”
EndSection
# generated from data in “/etc/sysconfig/keyboard”
Identifier “Keyboard0”
Driver “kbd”
Option “XkbLayout” “us”
Option “XkbModel” “pc105”
EndSection
Section “Monitor”
Identifier “Monitor0”
VendorName “Unknown”
ModelName “Unknown”
HorizSync 28.0 - 33.0
VertRefresh 43.0 - 72.0
Option “DPMS”
EndSection
Section “Device”
Identifier “Device0”
Driver “nvidia”
VendorName “NVIDIA Corporation”
EndSection
Section “Screen”
Identifier “Screen0”
Device “Device0”
Monitor “Monitor0”
DefaultDepth 24
SubSection “Display”
Depth 24
EndSubSection
EndSection
*** /var/log/Xorg.0.log.old
*** ls: -rw-r–r-- 1 root root 5528 2013-09-09 16:01:04.780291181 -0600 /var/log/Xorg.0.log.old
[ 9820.983]
[ 9820.984] X Protocol Version 11, Revision 0
[ 9820.985] Build Operating System: c6b7 2.6.32-220.el6.x86_64
[ 9820.985] Current Operating System: Linux localhost.localdomain 2.6.32-358.el6.x86_64 #1 SMP Fri Feb 22 00:31:26 UTC 2013 x86_64
[ 9820.985] Kernel command line: ro root=UUID=d29baf6b-77ef-4613-a767-
