the screenshot above shows 6-9 Gb/s that means the Ethernet Converged Network Adapter X540-T2 cards work with AGX PCI
BTW , do we know any working solutinos for 10Gb networking for NX Xavier also?
Looks like a fun thing to do except need to use a different adapter for the NX machine. I have been real excited getting the two headless machines working between the house and garage. Underground cables with two crossover adapters bought off amazon so I can use standard cat6 cables without making crossover cables.
Recompiled the kernel so now the two ports are in a bond. Disconnected each cable to see it fail over. eth1 and eth2 with eth0 being the 1GbE connection.
bond0
1GbE Interface eth0
10GbE Interface
Turns out it is 10 times faster lol
Now I just need some ideas to use the speed, beside file server
@vincef
is it conenctivity AGX-AGX with two X540-T2 ?
or AGX-NX?
If the latter - which adapters were used at each side?
AGX-AGX there are not 10GbE usb ethernet cards for NX, that I can find
Update: been testing a little through some switches with 10G Base-T and Copper SFP+, here is a screenshot going through three switches with LAG 802.3ad 2 port links through the entire link between two AGX Dev kits. These will make the perfect NAS, Web, Docker Dev Environment for the beginner. Only wish there were 2 PCI Express slots one for a good raid card and one for the 10G Network Adapter.
-Vince
