Hi Linuxdev! Thank you so much for taking the time.
When I do ifconfig here is what I get. As you can see eth4 has received few pieces of data from the camera :
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 00:04:4b:f7:84:5e txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 41
eth1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 78:d0:04:28:bd:5d txqueuelen 1000 (Ethernet)
device memory 0x40100000-4011ffff
eth2: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 78:d0:04:28:bd:5e txqueuelen 1000 (Ethernet)
device memory 0x40120000-4013ffff
eth3: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 78:d0:04:28:bd:5f txqueuelen 1000 (Ethernet)
device memory 0x40140000-4015ffff
eth4: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 78:d0:04:28:bd:60 txqueuelen 1000 (Ethernet)
RX packets 119 bytes 39910 (39.9 KB)
TX packets 223 bytes 39707 (39.7 KB)
device memory 0x40160000-4017ffff
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 1884 bytes 122074 (122.0 KB)
TX packets 1884 bytes 122074 (122.0 KB)
rndis0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 86:d4:b2:5d:47:6d txqueuelen 1000 (Ethernet)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 86:d4:b2:5d:47:6f txqueuelen 1000 (Ethernet)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 172.20.10.5 netmask 255.255.255.240 broadcast 172.20.10.15
inet6 fe80::a2b7:84dc:e79d:88c0 prefixlen 64 scopeid 0x20<link>
ether 00:04:4b:f7:84:5c txqueuelen 1000 (Ethernet)
RX packets 652 bytes 210419 (210.4 KB)
TX packets 766 bytes 145160 (145.1 KB)
When I do route
I am getting:
novo_jetson@novo-jetson-desktop:~/Desktop$ route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default _gateway 0.0.0.0 UG 600 0 0 wlan0
link-local 0.0.0.0 255.255.0.0 U 1000 0 0 wlan0
172.20.10.0 0.0.0.0 255.255.255.240 U 600 0 0 wlan0
When I type lspci
I am getting what looks like the port on the expansion board:
novo_jetson@novo-jetson-desktop:~/Desktop$ lspci
00:01.0 PCI bridge: NVIDIA Corporation Device 10e5 (rev a1)
01:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
01:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
01:00.2 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
01:00.3 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
If I check out one of ports (where I believe the camera is attached):
sudo lspci -s 01:00.3 -vvv
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 128 bytes
Interrupt: pin D routed to IRQ 381
Region 0: Memory at 40160000 (32-bit, non-prefetchable) [size=128K]
Region 2: I/O ports at 1060 [disabled] [size=32]
Region 3: Memory at 4018c000 (32-bit, non-prefetchable) [size=16K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable+ Count=10 Masked-
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00002000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 5GT/s, Width x4, ASPM L0s L1, Exit Latency L0s <4us, L1 <32us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM L0s L1 Enabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout+ NonFatalErr+
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] Device Serial Number 78-d0-04-ff-ff-28-bd-5d
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 0
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
IOVCap: Migration-, Interrupt Message Number: 000
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy-
IOVSta: Migration-
Initial VFs: 8, Total VFs: 8, Number of VFs: 0, Function Dependency Link: 03
VF offset: 384, stride: 4, Device ID: 1520
Supported Page Size: 00000553, System Page Size: 00000001
Region 0: Memory at 00000000480c0000 (64-bit, prefetchable)
Region 3: Memory at 00000000480e0000 (64-bit, prefetchable)
VF Migration: offset: 00000000, BIR: 0
Capabilities: [1a0 v1] Transaction Processing Hints
Device specific mode supported
Steering table in TPH capability structure
Capabilities: [1d0 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Kernel driver in use: igb
Thanks for those sleek commands :-) → ‘’’ ‘’’ looks really neat indeed.
I managed to find some sub-pages from the manufacture (FLIR), stating stating that their SDKs did not support my GigE camera on ARM processors :-( Does this mean I am completely screwed?
