I have installed ubuntu16.04 on the PC with Intel I210 NIC.
The PC with ubuntu can finish the test ,although the NIC has auto reset(link down and link up) severl times by itself.
Here is the cmd output
Before test
The Jetson
nvidia@tegra-tx2:~$ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.79 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::204:4bff:fec5:38c0 prefixlen 64 scopeid 0x20<link>
ether 00:04:4b:c5:38:c0 txqueuelen 1000 (Ethernet)
RX packets 453288189 bytes 625542007384 (625.5 GB)
RX errors 0 dropped 489389 overruns 0 frame 0
TX packets 102128283 bytes 423575933622 (423.5 GB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 41
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 40172803 bytes 1252581996656 (1.2 TB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 40172803 bytes 1252581996656 (1.2 TB)
rndis0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether c6:17:de:67:c1:8d txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether c6:17:de:67:c1:8f txqueuelen 1000 (Ethernet)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 00:04:4b:c5:38:be txqueuelen 1000 (Ethernet)
The PC
kxxxx@kxxxx-a:~$ ifconfig enp3s0
enp3s0 Link encap:Ethernet HWaddr 80:7b:85:50:12:61
inet addr:192.168.1.67 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::827b:85ff:fe50:1261/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:6304032 errors:0 dropped:0 overruns:3 frame:0
TX packets:5407398 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:8733655154 (8.7 GB) TX bytes:7472257412 (7.4 GB)
Memory:df200000-df27ffff
kxxxx@kxxxx-a:~$ route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.1.1 0.0.0.0 UG 0 0 0 enp3s0
169.254.0.0 0.0.0.0 255.255.0.0 U 1000 0 0 enp3s0
192.168.1.0 0.0.0.0 255.255.255.0 U 0 0 0 enp3s0
After test
The Jetson TX2
RX packets 533679780 bytes 737085329072 (737.0 GB)
TX packets 113363948 bytes 531685319031 (531.6 GB)
device interrupt 41
RX packets 40177375 bytes 1252582347357 (1.2 TB)
TX packets 40177375 bytes 1252582347357 (1.2 TB)
The PC
kxxxxx@kxxxxx-a:~$ ifconfig enp3s0
RX packets:83655958 errors:0 dropped:0 overruns:8 frame:0
TX packets:80392689 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:112889113253 (112.8 GB) TX bytes:112668277180 (112.6 GB)
The Jeston dmesg
nvidia@tegra-tx2:~$ dmesg --follow
[三 12月 18 19:00:53 2019] tegra_wdt_t18x 30c0000.watchdog: Watchdog(0): wdt timeout set to 1200 sec
[三 12月 18 19:00:53 2019] watchdog: watchdog0: watchdog did not stop!
[三 12月 18 19:03:26 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:03:29 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:05:54 2019] tegra_wdt_t18x 30c0000.watchdog: Watchdog(0): wdt timeout set to 1200 sec
[三 12月 18 19:05:54 2019] watchdog: watchdog0: watchdog did not stop!
[三 12月 18 19:08:04 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:08:07 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:08:28 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:08:45 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:08:51 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:09:01 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:09:08 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:09:11 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:09:33 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:09:42 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:09:45 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:09:51 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:09:58 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:10:04 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:10:06 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:10:17 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:10:20 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:10:36 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:11:01 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:11:04 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:11:10 2019] tegra_wdt_t18x 30c0000.watchdog: Watchdog(0): wdt timeout set to 1200 sec
[三 12月 18 19:11:10 2019] watchdog: watchdog0: watchdog did not stop!
[三 12月 18 19:11:12 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:11:20 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:11:23 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:11:28 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:11:38 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:11:46 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:11:47 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:12:05 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:12:11 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:12:19 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:12:23 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:12:26 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:12:34 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:12:37 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:12:59 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:13:19 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:13:22 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:13:43 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:13:46 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:14:19 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:14:26 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:14:33 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:14:36 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:14:46 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:14:56 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:15:02 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:15:05 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:15:14 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:15:37 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:15:40 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:15:53 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:16:06 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:16:09 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:16:11 2019] tegra_wdt_t18x 30c0000.watchdog: Watchdog(0): wdt timeout set to 1200 sec
[三 12月 18 19:16:11 2019] watchdog: watchdog0: watchdog did not stop!
[三 12月 18 19:16:22 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:16:23 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:16:36 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:16:39 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:16:51 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:16:56 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:17:02 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:17:04 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:17:05 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:17:30 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:17:33 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:17:46 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:18:05 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:18:08 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:18:35 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:18:39 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:18:54 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:18:57 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:19:04 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:19:28 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:19:31 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:19:42 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:19:48 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:19:51 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:19:58 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:20:12 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:20:15 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:20:37 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:20:57 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:21:00 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:21:12 2019] tegra_wdt_t18x 30c0000.watchdog: Watchdog(0): wdt timeout set to 1200 sec
[三 12月 18 19:21:12 2019] watchdog: watchdog0: watchdog did not stop!
[三 12月 18 19:21:18 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:21:28 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:21:31 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:21:32 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:21:33 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:21:39 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:21:42 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:21:56 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:21:59 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:22:14 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:22:16 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:22:18 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:22:25 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:22:28 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:22:40 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:23:05 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:23:08 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:23:18 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:23:34 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:23:37 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:24:15 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:24:39 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:24:46 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:24:49 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[三 12月 18 19:24:53 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:25:14 2019] eqos 2490000.ether_qos eth0: eqos_start_xmit(): TX ring full for queue 0
[三 12月 18 19:25:20 2019] eqos 2490000.ether_qos eth0: Link is Down
[三 12月 18 19:25:23 2019] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
The PC dmesg
[三 12月 18 19:03:26 2019] ------------[ cut here ]------------
[三 12月 18 19:03:26 2019] NETDEV WATCHDOG: enp3s0 (igb): transmit queue 0 timed out
[三 12月 18 19:03:26 2019] WARNING: CPU: 2 PID: 0 at /build/linux-hwe-ngR1Rd/linux-hwe-4.15.0/net/sched/sch_generic.c:323 dev_watchdog+0x222/0x230
[三 12月 18 19:03:26 2019] Modules linked in: joydev input_leds hid_generic usbhid hid nls_iso8859_1 snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic intel_rapl x86_pkg_temp_thermal snd_soc_skl intel_powerclamp snd_soc_skl_ipc coretemp snd_hda_ext_core snd_soc_sst_dsp snd_soc_sst_ipc snd_soc_acpi kvm_intel kvm snd_soc_core snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel irqbypass snd_hda_codec crct10dif_pclmul crc32_pclmul snd_hda_core snd_hwdep ghash_clmulni_intel pcbc snd_pcm aesni_intel snd_seq_midi snd_seq_midi_event aes_x86_64 crypto_simd snd_rawmidi glue_helper cryptd intel_cstate intel_rapl_perf snd_seq snd_seq_device snd_timer snd soundcore shpchp mei_me mei intel_pch_thermal acpi_pad mac_hid parport_pc ppdev lp parport autofs4 i915 e1000e drm_kms_helper syscopyarea sysfillrect sysimgblt
[三 12月 18 19:03:26 2019] fb_sys_fops uas igb dca i2c_algo_bit ahci ptp pps_core drm usb_storage libahci video pinctrl_sunrisepoint
[三 12月 18 19:03:26 2019] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.15.0-72-generic #81~16.04.1-Ubuntu
[三 12月 18 19:03:26 2019] Hardware name: Default string AIMG/V2C, BIOS 1.10 06/18/2019
[三 12月 18 19:03:26 2019] RIP: 0010:dev_watchdog+0x222/0x230
[三 12月 18 19:03:26 2019] RSP: 0018:ffff9e7dedd03e68 EFLAGS: 00010282
[三 12月 18 19:03:26 2019] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 000000000000083f
[三 12月 18 19:03:26 2019] RDX: 0000000000000000 RSI: 00000000000000f6 RDI: 000000000000083f
[三 12月 18 19:03:26 2019] RBP: ffff9e7dedd03e98 R08: 0000000000000001 R09: 000000000000037d
[三 12月 18 19:03:26 2019] R10: 0000000000000000 R11: 000000000000037d R12: 0000000000000008
[三 12月 18 19:03:26 2019] R13: ffff9e7dd9fa4000 R14: ffff9e7dd9fa4478 R15: ffff9e7dda052940
[三 12月 18 19:03:26 2019] FS: 0000000000000000(0000) GS:ffff9e7dedd00000(0000) knlGS:0000000000000000
[三 12月 18 19:03:26 2019] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[三 12月 18 19:03:26 2019] CR2: 00007f35802b1018 CR3: 000000013360a003 CR4: 00000000003606e0
[三 12月 18 19:03:26 2019] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[三 12月 18 19:03:26 2019] DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
[三 12月 18 19:03:26 2019] Call Trace:
[三 12月 18 19:03:26 2019] <IRQ>
[三 12月 18 19:03:26 2019] ? dev_deactivate_queue.constprop.33+0x60/0x60
[三 12月 18 19:03:26 2019] call_timer_fn+0x32/0x140
[三 12月 18 19:03:26 2019] run_timer_softirq+0x1e9/0x430
[三 12月 18 19:03:26 2019] ? ktime_get+0x3e/0xb0
[三 12月 18 19:03:26 2019] ? lapic_next_deadline+0x26/0x30
[三 12月 18 19:03:26 2019] __do_softirq+0xf5/0x2a8
[三 12月 18 19:03:26 2019] irq_exit+0xca/0xd0
[三 12月 18 19:03:26 2019] smp_apic_timer_interrupt+0x79/0x150
[三 12月 18 19:03:26 2019] apic_timer_interrupt+0x8c/0xa0
[三 12月 18 19:03:26 2019] </IRQ>
[三 12月 18 19:03:26 2019] RIP: 0010:cpuidle_enter_state+0xa7/0x300
[三 12月 18 19:03:26 2019] RSP: 0018:ffffb17dc0d03e60 EFLAGS: 00000246 ORIG_RAX: ffffffffffffff11
[三 12月 18 19:03:26 2019] RAX: ffff9e7dedd21840 RBX: 0000000000000006 RCX: 000000000000001f
[三 12月 18 19:03:26 2019] RDX: 0000000000000000 RSI: 00000000378e38e3 RDI: 0000000000000000
[三 12月 18 19:03:26 2019] RBP: ffffb17dc0d03e98 R08: fffffffb26d74a95 R09: 0000000000000018
[三 12月 18 19:03:26 2019] R10: ffffb17dc0d03e30 R11: 0000000000003429 R12: 0000000000000006
[三 12月 18 19:03:26 2019] R13: ffff9e7dedd2b900 R14: ffffffffbb973498 R15: 000000a49e694ed4
[三 12月 18 19:03:26 2019] cpuidle_enter+0x17/0x20
[三 12月 18 19:03:26 2019] call_cpuidle+0x23/0x40
[三 12月 18 19:03:26 2019] do_idle+0x197/0x200
[三 12月 18 19:03:26 2019] cpu_startup_entry+0x73/0x80
[三 12月 18 19:03:26 2019] start_secondary+0x1ab/0x200
[三 12月 18 19:03:26 2019] secondary_startup_64+0xa5/0xb0
[三 12月 18 19:03:26 2019] Code: 36 00 49 63 4e e8 eb 92 4c 89 ef c6 05 69 fa d6 00 01 e8 12 19 fd ff 89 d9 48 89 c2 4c 89 ee 48 c7 c7 d0 e8 58 bb e8 2e e6 7e ff <0f> 0b eb c0 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48
[三 12月 18 19:03:26 2019] ---[ end trace 16ded2ffbe14c72d ]---
[三 12月 18 19:03:26 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:03:29 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:08:03 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:08:03 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:08:05 2019] igb 0000:03:00.0: exceed max 2 second
[三 12月 18 19:08:05 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Down
[三 12月 18 19:08:07 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:09:07 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:09:07 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:09:09 2019] igb 0000:03:00.0: exceed max 2 second
[三 12月 18 19:09:09 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Down
[三 12月 18 19:09:11 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:09:41 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:09:45 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:10:16 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:10:20 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:11:00 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:11:04 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:11:19 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:11:23 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:12:19 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:12:23 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:12:33 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:12:37 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:13:18 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:13:22 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:13:42 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:13:46 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:14:32 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:14:36 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:15:01 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:15:05 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:15:36 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:16:05 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:16:09 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:16:35 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:16:35 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:16:37 2019] igb 0000:03:00.0: exceed max 2 second
[三 12月 18 19:16:37 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Down
[三 12月 18 19:16:39 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:17:29 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:17:29 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:17:31 2019] igb 0000:03:00.0: exceed max 2 second
[三 12月 18 19:17:31 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Down
[三 12月 18 19:17:33 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:18:04 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:18:08 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:18:53 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:18:53 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:18:55 2019] igb 0000:03:00.0: exceed max 2 second
[三 12月 18 19:18:55 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Down
[三 12月 18 19:18:57 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:19:27 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:19:31 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:19:47 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:19:47 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:19:49 2019] igb 0000:03:00.0: exceed max 2 second
[三 12月 18 19:19:49 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Down
[三 12月 18 19:19:51 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:20:11 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:20:15 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:20:56 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:21:00 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:21:55 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:21:59 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:22:24 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:22:28 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:23:04 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:23:08 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:23:33 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:23:37 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:24:46 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:24:49 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[三 12月 18 19:25:19 2019] igb 0000:03:00.0 enp3s0: Reset adapter
[三 12月 18 19:25:23 2019] igb 0000:03:00.0 enp3s0: igb: enp3s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
kxxxxx@kxxxxx-a:~$ ethtool enp3s0
Settings for enp3s0:
Supported ports: [ TP ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: Twisted Pair
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
MDI-X: off (auto)
Cannot get wake-on-lan settings: Operation not permitted
Current message level: 0x00000007 (7)
drv probe link
Link detected: yes
