effepi
1
I got a piece of code that works when I do not use interpolation:
g_table_texture.addressMode[0] = cudaAddressModeClamp;
g_table_texture.addressMode[1] = cudaAddressModeClamp;
g_table_texture.filterMode = cudaFilterModePoint;
g_table_texture.normalized = false;
And I fetch a texture element using:
return tex1Dfetch(g_table_texture, int_texture_coordinate);
with 0 <= int_texture_coordinate < N
Now I change it to:
g_table_texture.filterMode = cudaFilterModeLinear;
g_table_texture.normalized = true;
return tex1D(g_table_texture, float_texture_coordinate);
with float float_texture_coordinate = int_texture_coordinate;
float_texture_coordinate /= N;
so that 0 <= float_texture_coordinate <= 1
Now the return value is always 0.
Any idea what I am doing wrong?
Failing to check for error codes. If you had, it would have said invalid texture reference.
tex1D can only read textures bound to cudaArrays.
effepi
4
I check for errors after each run of the kernel.
There is no error.
effepi
5
There is no error.
effepi
6
It wasn’t a cudaArray. No runtime error, tho.
Moving from 1D to 2D worked with liner memory…
effepi
7
