I’m trying to perform a simple addition with textures:
I have a mallocPitch Array
I bind my texture to this array
In a kernel I add one to every texel and write back to a cudaMalloc array (linear memory)
I don’t get the results I want (i.e. the results are not the previous plus 1)
#include<stdio.h>
#include<cuda.h>
#include<iostream>
#define height 16
#define width 11
#define BLOCKSIZE 16
using namespace std;
// Device Kernels
//Texture reference Declaration
texture<float,2> texRefEx;
__global__ void kernel_w_textures(float* devMPPtr, float * devMPtr, int pitch)
// Thread indexes
unsigned int idx = blockIdx.x*blockDim.x + threadIdx.x;
unsigned int idy = blockIdx.y*blockDim.y + threadIdx.y;
// Texutre Coordinates
float u=(idx)/float(width);
float v=(idy)/float(height);
devMPtr[idy*width+idx]=devMPPtr[idy*pitch/sizeof(float)+idx];
// Write Texture Contents to malloc array +1
devMPtr[idy*width+idx]= tex2D(texRefEx,u,v)+1.0f;
//Host Code
int main()
// memory size
size_t memsize=height*width;
float * data, // input from host
*h_out, // host space for output
*devMPPtr, // malloc Pitch ptr
*devMPtr; // malloc ptr
size_t pitch;
// Allocate space on the host
data=(float *)malloc(sizeof(float)*memsize);
h_out=(float *)malloc(sizeof(float)*memsize);
// Define data
for (int i = 0; i < height; i++)
for (int j=0; j < width; j++)
data[i*width+j]=float(j);
// Define the grid
dim3 grid((int)(width/BLOCKSIZE)+1,(int)(height/BLOCKSIZE)+1), threads(BLOCKSIZE,BLOCKSIZE);
// allocate Malloc Pitch
cudaMallocPitch((void**)&devMPPtr,&pitch, width * sizeof(float), height);
// Print the pitch
printf("The pitch is %d \n",pitch/sizeof(float));
// Texture Channel Description
cudaChannelFormatDesc channelDesc = cudaCreateChannelDesc<float>();
// Bind texture to pitch mem:
cudaBindTexture2D(0,&texRefEx,devMPPtr,&channelDesc,width,height,pitch);
// Set mutable properties:
texRefEx.normalized=true;
texRefEx.addressMode[0]=cudaAddressModeWrap;
texRefEx.addressMode[1]=cudaAddressModeWrap;
texRefEx.filterMode= cudaFilterModePoint;
// Allocate cudaMalloc memory
cudaMalloc((void**)&devMPtr,memsize*sizeof(float));
// Read data from host to device
cudaMemcpy2D((void*)devMPPtr,pitch,(void*)data,sizeof(float)*width,
sizeof(float)*width,height,cudaMemcpyHostToDevice);
//Read back and check this memory
cudaMemcpy2D((void*)h_out,width*sizeof(float),(void*)devMPPtr,pitch,
sizeof(float)*width,height,cudaMemcpyDeviceToHost);
// Print the memory
for (int i=0; i<height; i++){
for (int j=0; j<width; j++){
printf("%2.2f ",h_out[i*width+j]);
cout << endl;
cout << "Done" << endl;
// Memory is fine...
kernel_w_textures<<<grid,threads>>>(devMPPtr, devMPtr, pitch);
// Copy back data to host
cudaMemcpy((void*)h_out,(void*)devMPtr,width*height*sizeof(float),cudaMemcpyDeviceToHost);
// Print the Result
cout << endl;
cout << endl;
return(0);
I can’t figure out why my results are wrong ( it looks like I’ve bound everything according to the programing guide). On a side note, this program works fine for square dimensions. I’ve been having issues with this for a while and have not seen a similar problem - Although I’m sure it’s something easy to fix.
