Hi all,
sorry that I posted this message accidently before I was finished!
I have a problem with cudaBind Texture2D. I try to use CUDA for
image processing and texture access on the image seems to be a
good way, but unfortunately I have some problems with it and I
don’t get any error but it doesn’t work :-(.
I allocate memory for the image on the device (320 x 240 * sizeof(char))
The image is grayscale.
This is the code to allocate memory on the gpu:
// malloc memory on gpu
CUDA_SAFE_CALL(cudaMalloc((void**) &d_data1, mem_size));
Now I’m trying to bind this memory to a texture. The (test) kernel seems to stop
working after I bind this texture. ( it only sets all pixels to black == 0)
The kernel works again when I uncomment the texture binding.
Where is the error? Might the memory pitch in the call
// cudaBindTexture2D(size_t *offset,const struct textureReference *tex,const void *devPtr, const struct cudaChannelFormatDesc *desc,size_t width, size_t height, size_t pitch);
have something to do with it?
Thank you in advance!!!
#include <cutil_inline.h>
texture<uchar, 2, cudaReadModeElementType> tex;
__global__ void kernel(uchar* in, uchar* out, int width)
unsigned int x = blockIdx.x*blockDim.x + threadIdx.x;
unsigned int y = blockIdx.y*blockDim.y + threadIdx.y;
out[y*width + x] = 0; // tex2D(tex, x, y) * 0.1;
extern "C" void
cudaStartKernel(char* in, char* out, IplImage* image_info)
cudaChannelFormatDesc channelDesc;
if (image_info->nChannels == 1) {
channelDesc = cudaCreateChannelDesc<unsigned char>();
} else {
channelDesc = cudaCreateChannelDesc<uchar4>();
// set texture parameters
tex.addressMode[0] = cudaAddressModeClamp;
tex.addressMode[1] = cudaAddressModeClamp;
tex.filterMode = cudaFilterModePoint;
tex.normalized = false; // access with normalized texture coordinates
const textureReference* texRefPtr=NULL;
cudaGetTextureReference(&texRefPtr, "tex");
CUDA_SAFE_CALL(cudaBindTexture2D(0, texRefPtr, (void*)in, &channelDesc, image_info->width, image_info->height, 1));
dim3 dimBlock(8, 8, 1);
dim3 dimGrid(image_info->width / dimBlock.x, image_info->height / dimBlock.y, 1);
kernel<<< dimGrid, dimBlock >>>((uchar*)in, (uchar*)out, image_info->width);
CUDA_SAFE_CALL(cudaThreadSynchronize());
CUDA_SAFE_CALL(cudaUnbindTexture(tex));
