In my cuda.h I see CUdeviceptr is typedef’d to an unsigned int, but if I have a kernel write sizeof(void *) out [not in device emulation] it returns 8. How do I get the correct size?
thanks in advance,
Nicholas
btw, my uname is
uname -a
Linux oliver 2.6.27.7-9-default #1 SMP 2008-12-04 18:10:04 +0100 x86_64 x86_64 x86_64 GNU/Linux
My understanding is that GPU code uses the same pointer sizes as CPU code, to ensure compatibility. That is, if you are trying to create a binary-compatible structure on the CPU, use “something *”, rather than CUdeviceptr. CUdeviceptr currently seems to be restricted to 32 bits, which matches up with current hardware limits, but I expect this limitation to go away soon. In any case, CUdeviceptr should not be assumed to be layout-compatible with pointers on the device.
Thanks. Any nVidia employees – please verify this. It seems interesting that there isn’t another layer of abstraction for int’s; are GPUs unlikely to be used with big-endian CPUs?
So the compiler author is at least paying attention to this attribute, although it’s not clear what would happen if they wanted to add a big-endian target. (If the next-generation of game consoles are still using PPC cores, there might be a market for big-endian support in CUDA.)
Since there’s a 256 byte limit on the size of kernels’ parameter lists, does compiling on a 64-bit platform reduce the amount of pointers we can pass to a kernel?
