Hello, all.
I am porting my program from CUDA to OpenCL.
And now I am troubled by the difference of pointer size between host and device.
In CUDA x64, the pointer size is same. (Host=Device=64-bit)
But, in OpenCL x64, the pointer size is different. (Host=64-bit, Device=32-bit)
I tested it using the following test program in OpenCL.
I will appreciate any help.
My Environment
OS : Windows7 64-bit
CPU : Intel Xeon E5620
GPU : NVIDIA Tesla C2050
SDK : NVIDIA GPU Computing SDK 4.0, Visual Studio2010 express
Test Program:
/* host.c */
#include <stdio.h>
#include <stdlib.h>
#include <CL/cl.h>
#define BUF_SIZE (32)
#define MAX_SOURCE_SIZE (0x100000)
int main()
cl_device_id device_id = NULL;
cl_context context = NULL;
cl_command_queue command_queue = NULL;
cl_mem memobj = NULL;
cl_program program = NULL;
cl_kernel kernel = NULL;
cl_platform_id platform_id = NULL;
cl_uint ret_num_devices;
cl_uint ret_num_platforms;
cl_int ret;
char buf[BUF_SIZE];
FILE *fp;
char fileName[] = "./device.cl";
char *source_str;
size_t source_size;
/* Load Kernel Source Code */
fp = fopen(fileName, "r");
if (!fp)
fprintf(stderr, "Failed to load kernel.\n");
exit(1);
source_str = (char*)malloc(MAX_SOURCE_SIZE);
source_size = fread(source_str, 1, MAX_SOURCE_SIZE, fp);
fclose(fp);
ret = clGetPlatformIDs(1, &platform_id, &ret_num_platforms);
ret = clGetDeviceIDs(platform_id, CL_DEVICE_TYPE_GPU, 1, &device_id, &ret_num_devices);
context = clCreateContext(NULL, 1, &device_id, NULL, NULL, &ret);
command_queue = clCreateCommandQueue(context, device_id, 0, &ret);
memobj = clCreateBuffer(context, CL_MEM_READ_WRITE, BUF_SIZE * sizeof(char), NULL, &ret);
program = clCreateProgramWithSource(context, 1, (const char **)&source_str,
(const size_t *)&source_size, &ret);
ret = clBuildProgram(program, 1, &device_id, NULL, NULL, NULL);
kernel = clCreateKernel(program, "device_func", &ret);
ret = clSetKernelArg(kernel, 0, sizeof(cl_mem), (void*)&memobj);
ret = clEnqueueTask(command_queue, kernel, 0, NULL, NULL);
ret = clEnqueueReadBuffer(command_queue, memobj, CL_TRUE, 0,
BUF_SIZE * sizeof(char), buf, 0, NULL, NULL);
printf("Host Pointer Size : %d byte\n", sizeof(char *));
printf("Device Pointer Size: %d byte\n", buf[0]);
ret = clFlush(command_queue);
ret = clFinish(command_queue);
ret = clReleaseKernel(kernel);
ret = clReleaseProgram(program);
ret = clReleaseMemObject(memobj);
ret = clReleaseCommandQueue(command_queue);
ret = clReleaseContext(context);
free(source_str);
return 0;
/* device.cl */
__kernel void device_func(__global char* buf)
buf[0] = sizeof(char*);
Test Program Result:
Host Pointer Size : 8 byte
Device Pointer Size: 4 byte
