360° Surround View camera solution using NVIDIA Jetson AGX Orin
e-con Systems’ ArniCAM20 is a synchronized multi-camera solution that provides 360-degree field of view. This HDR camera solution with LFM comprises of four full HD camera module which is based on a 1/2.5" AR0233AT CMOS image sensor from onsemi®.
pdf Download Datasheet here
It uses GMSL2 interface with FAKRA connector to transmit power and data up to 15m when connected to NVIDIA® Jetson AGX Orin™ developer kit.It also comes with dust and waterproof IP67-rated enclosure.
Highlights of ArniCAM20:
  • ArniCAM20 - 360° Surround View | 360° Bird view
  • Houses 4 x STURDeCAM21 - Full HD AR0233 Camera Module
  • Proprietary 360° image stitching algorithm
  • Plugs into NVIDIA® Jetson AGX Orin™ developer kits
  • Gigabit Multimedia Serial Link 2 (GMSL2) interface with FAKRA connector
  • Shielded coaxial cables to transmit power and data up to 15m
  • External Trigger support for synchronized multi-camera streaming
  • High Dynamic Range (HDR) with LFM
  • On-board high performance ISP
  • Dust and waterproof IP67-rated enclosure
Know more »
