I really need some expertise here:
For the current situation see update 2 below.
Update: I tested with Windows 2012 Clients to verify and I still get about 5.5 Gbit/s max.
Maybe someone has other 40Gbit adapters what are the speeds for you?
Update 2: The mainboard had 16x physical and only 2x electrical connection. (Special thx to Erez support admin for a quick and good answer)
After changing to a PCIe 3.0 8x lane I now get the following speed: (should still be 3x faster)
Update 3: One support admin suggested to not use passive copper, but to use optic fibre. After getting an 56Gbit Optical fibre IB cable I now get these results:
Which is still way below the advertised 40Gbit!
The story goes like this: Advertised 40Gbit , 32Gbit theoretical which is really only 25.6 Gbit according to Enez from Mellanox which turns out to be in Reality HALF-DUPLEX 16Gbit!
Do I make something wrong or is it just the way it works for customers of mellanox :/
If there is still something wrong how do i fix it?
OLD PART DO NOT READ: (READ UPDATE 3 instead)
I have two Windows 10 Machines with two MHQH19B-XTR 40 Gbit Adapters and a QSFP cable in between. The Vlan manager is opensm.
The connection should be about 32Gbits Lan. In reality i only get 5 Gbit performance. So clearly something is very wrong.
C:\Program Files\Mellanox\MLNX_VPI\IB\Tools>iblinkinfo
CA: E8400:
0x0002c903004cdfb1 2 1 ==( 4X 10.0 Gbps Active/ LinkUp)==> 1 1 “IP35” ( )
CA: IP35:
0x0002c903004ef325 1 1 ==( 4X 10.0 Gbps Active/ LinkUp)==> 2 1 “E8400” ( )
I tested my IPoIB with a program called lanbench and nd_read_bw:
nd_read_bw -a -n 100 -C 169.254.195.189
#qp #bytes #iterations MR [Mmps] Gb/s CPU Util.
0 512 100 0.843 3.45 0.00
0 1024 100 0.629 5.15 0.00
0 2048 100 0.313 5.13 0.00
0 4096 100 0.165 5.39 0.00
0 8192 100 0.083 5.44 0.00
0 16384 100 0.042 5.47 0.00
0 32768 100 0.021 5.47 100.00
…stays at 5.47 after that. with CPU util 100%
The processor is an intel core I7 4790k so it should not be at 100%. According to Taskmanager only 1 Core is actively used.
Firmware, Drivers, Windows 10 are up to date.
My goal is to get the fastest possible File sharing between two windows 10 machines.
What could be the problem here and how do I fix it?
After endless hours of searching I found out that vstat showed that I have a 10GBit connection.
C:\Users\Daniel>“C:\Program Files\Mellanox\MLNX_VPI\IB\Tools\vstat.exe”
hca_idx=0
uplink={BUS=PCI_E Gen2, SPEED=5.0 Gbps, WIDTH=x8, CAPS=5.0*x8} → Looks good
MSI-X={ENABLED=1, SUPPORTED=128, GRANTED=10, ALL_MASKED=N}
vendor_id=0x02c9
vendor_part_id=26428
hw_ver=0xb0
fw_ver=2.09.1000
PSID=MT_0D90110009
node_guid=0002:c903:004e:f324
num_phys_ports=1
port=1
port_guid=0002:c903:004e:f325
port_state=PORT_ACTIVE (4)
link_speed=10.00 Gbps
link_width=4x (2)
rate=40.00 Gbps
real_rate=32.00 Gbps (QDR)
port_phys_state=LINK_UP (5)
active_speed=10.00 Gbps → WHY?
sm_lid=0x0001
port_lid=0x0001
port_lmc=0x0
transport=IB
max_mtu=4096 (5)
active_mtu=4096 (5)
GID[0]=fe80:0000:0000:0000:0002:c903:004e:f325
What I should get is : (thx to erez)
PCI_LANES(8)*PCI_SPEED(5)*PCI_ENCODING(0.8)*PCI_HEADERS(128/152)*PCI_FLOW_CONT(0.95) = 25.6 Gbit
Can anyone help me with this problem?
